Results 1 to 20 of 33
    Jul 2010
    Gordons Bay as a base - travelling Africa
    Thanked: 241
    Default Pajero Diesel suddenly smoking
    SOLVED ❤️
    Were in Addo this morning on an early game drive, when suddenly the Diesel engine sound louder and a few minutes later dark smokes coming out of the exhaust.
    It's a 2009 model, DID, service was done about 2000 km ago.
    It seems that a bit oil is missing.
    Should we rather search for a workshop in Kirkwood?
    We drove about 4-5 km to main Camp now and are a bit clueless...
    Update, driving back to accomodation in Nyathi now, no more smoke. Ignore it? What could be the reason?
    Johannesburg/Prague
    Thanked: 120
    Default Re: Pajero Diesel suddenly smoking
    Has it stopped now ? could be the DPF (diesel particle filter) doing a regeneration process which is normal
    If it has not stopped you can check the air filter perhaps its a bit blocked , if not then best to take to a garage as it could a lot of things related to diesel/air mixture
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
    Thanked: 716
    How much oil seems to be missing?
    Blue or black smoke?
    Does your radiator water look normal? No bubbles while idling the engine?
    Did you maybe recently fill up somewhere dodgy?
    Thanked: 716
    If it is dark smoke I assume it is black. Then check air and maybe the diesel filter as mentioned above, for a start.
    Jul 2010
    Thanked: 241
    Sorry for late reply, we've had no cellphone reception.
    It's blue smoke. We'll check for radiator water bubbles right now.
    Jul 2010
    Thanked: 241
    We can't check it here, need to find a workshop. Just thinking if we should go to Kirkwood or Colchester...
    Thanked: 716
    Maybe Colchester? If you can't get help there you are not too far away from PE with a Mitsubishi dealership.
    Jul 2010
    Thanked: 241
    So it's blue smoke, no bubbles in radiator water, smoking occurs when accelerating, then nothing. Sound of the engine is louder than normal.
    We'll drive to Colchester now to find a workshop to check the diesel and the diesel filter.
  9. The Following User Says Thank You to Southerndreams For This Useful Post:
    Thanked: 1183
    Contaminated fuel maybe..Could be water contamination.Check your filter for signs of water
    Feb 2019
    Thanked: 331
    Quote Originally Posted by Southerndreams View Post
    Hi, only saw your post this morning. If you need help in the PE area contact Bossie from Magic Auto 084 three-seven-seven 6671. He's looked after my Dad's gen 3 for many years. Speak to his son. They know their Mitsu's.
    Dark (Black?) smoke sounds like over fueling (bad AFR ratio) which could point to a few things. Maybe have them read the injectors and do a small quantity relearn. Change the filters (maybe bad diesel). Else have you ever replaced MAF, MAP or SCV and is it decatted? I'm guessing the Kilo's are getting high so maybe time to clean the intake manifold. Maybe some gunk worked loosed and out the exhaust. If the cat is still there then it may have gotten stuck there and burnt causing the smoke. Many possibilities.
    I find the oil level my Gen 4 is very sensitive to how the car is parked. I only check it when dead cold and on a level surface else it looks low. But maybe if its used some oil it would be good to check the turbo spindle for play (oily smoke tends to be more greyish and not dark).
    If you cant make it to PE I can ask friends in the Kirkwood/Addo area if there is a mech they recommend.
    Hope you come right.
  12. #11
    Feb 2019
    Thanked: 331
    Sound like the turbo. Check the oil. If the turbo seals blow it will eat the oil very quickly.
  13. #12
    Feb 2019
    Thanked: 331
    Quote Originally Posted by 12richardk View Post
    Our Gen 4's don't have a DPF. They only have a CAT.
  14. #13
    Jul 2010
    Thanked: 241
    Our mechanic at home said it's either dirty diesel or the injectors.
    We slowly "cruise" towards PE, prepared to stop immediately if engine gets louder and call Outsurance.
    No workshop in Colchester according GM, we opted for the Mitsubishi dealership in PE.
    I'll keep you updated ��
  15. #14
    Feb 2019
    Thanked: 331
    Our mechanic at home said it's either dirty diesel (we filled up at Shell in Albertina) or the injectors.
    Albetinia is a long way for dirty diesel to only start causing an issue in Addo. But perhaps its just taken a while for the filter to clog. Keep a sample incase it is dirty diesel then contact the service station. Injectors will typically cause black smoke. That's overfueling. Grey/bluish smoke implies oil. You mention the oil looks low so its more likely there.
    Colchester is a no go for sure.
    Personally I'd rather try Bossie than the dealer there, I think you will have more luck.
    Will scan to see if you guys made it to PE.
  16. #15
    Friemersheim, Southern Cape
    Thanked: 4831
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    "What can be asserted without evidence can also be dismissed without evidence."
  17. #16
    Jul 2010
    Thanked: 241
    Quote Originally Posted by ChasingSunsets View Post
    I've rechecked slips and we remembered we filled up on a small filling station in Uitenhage. I also thought it can't be so far !!!.
    I only saw the post mentioning Bossier later, we are now on our way to Magic Auto.
    Brains are a bit slow after 6 phantastic and relaxing nights at Nyathi Highly recommended
    TNX we'll update later
  18. The Following User Says Thank You to Southerndreams For This Useful Post:
  19. #17
    Jul 2010
    Thanked: 241
    I fill up at Shell Albertinia many times a month and no issues to date
    It wasn't Shell Albertina, it was at a small filling station in Uitenhage. I've edited the post I don't want to harm them
  20. #18
    Jul 2010
    Thanked: 241
    We had driven from Addo Main Camp to PE without any more smoke incident.
    Magic Auto couldn't assist us due to a family related cause.
    At Mitsubishi dealership we got lucky to slip in between, they read out injectors etc. and couldn't find anything wrong.
    99% the cause was dirty diesel from Uitenhage.
    The mechanic also explained, that if it would've been the injectors, the vehicle would've been going into limp mode.
    Thanks all that assisted ♥️
  21. #19
    May 2016
    Thanked: 4221
    I am very reluctant to post this, but add 500ml 2-stroke oil to the tank.
    No, I am not inviting a discussion.
    Use it or lose it.
    2006 VW Touareg V10 (Sold)
  22. The Following 3 Users Say Thank You to 4ePajero For This Useful Post:
  23. #20
    Thanked: 4831
    Likewise
    Robert van den Berg
