Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
  1. #21
    Jan 2014
    Northern KZN
    Thanked: 336
    Default Re: The VW Bus that never made it to market
    Quote Originally Posted by Hooly View Post
    The technical specs for the Golf country that I could find are as follow.
    Ground clearance 180mm 210 on some versions
    KW 73 there were only 50 Gti's made with 85kw
    Torque 143nm
    Acceleration 0-100km/h 12.3s
    I can't find any info on the 1st gear ratio.
    The Golf was FWD with the rear activated through a clutch on slip
    Duster
    Ground clearance 210mm
    kw 80
    Torque 260nm
    1st gear ratio 4.45
    Acceleration 0-100km/h 12.5s
    The Duster is primarily FWD with the rear activated when slipping and there is a manual switchable lock between front and rear.
    Like the Golf the 4x4 Duster has under body protection as standard.
    You are correct. The 120mm clearance more than the standard golf syncro had me fooled. I misread that the standard syncro had a clearance of 210mm. The lower gear ratio is fact however. Actually not only the first gear that was lower, the entire range from 1 to 5 was lower than the standard syncro.
    Groetnis
    Koos
  2. #22
    Apr 2014
    Krugersdorp
    Thanked: 1603
    Quote Originally Posted by Beurvoort View Post
    Groetnis
    Koos
    Do you have the ratio's for the Golf it would be interesting to compare? What I can tell you is that I was pretty impressed with my Dusty while I had it, and the low first gear worked pretty well in offroad scenario's, although not a replacement for real low range like I have on my Cherokee Trailhawk.
    Groete
    Louis
    Louis Adendorff
    Jeep Cherokee Trailhawk (Ironman suit)
    Everest 2.2 XLS (Swambo’s mommy taxi)
  3. #23
    Aug 2016
    Thanked: 146
    There were a bunch of Namibians also doing a lot of work on a 4x4 version in the late 70's. They imported some components from VW Germany. They had a prototype running in the Namib dunes. Do not know much more about it. It was definitely running before the Synchros came to South Africa.
  4. #24
    Thanked: 2223
    Quote Originally Posted by Pieter de Waal View Post
    My understanding was that the Synchro was uniquely South African and totally developed locally (be that RSA or NAM). I have never seen a Synchro advertised in Europe. The same is true for the 2.5 and 2.6 Microbus these we South African variants developed for the towing fraternity as the 2.1 simply did no have enough poke. The 2.5 being the first as it was the standard 5 cylinder Audi engine and then the 2.6 was a torque improved version.
  5. #25
    Robertson/ Larissa, Greece
    Thanked: 5452
    You must be joking! Syncros are running all over Europe and the US! It was developed by Steyr in Austria actually. The 2.3/5/6 5 cylinder variants were SA developed yes.
    The Syncros running around in Swakopmund early on was built from original components before the Syncro was launched locally.
  6. The Following 2 Users Say Thank You to Francois Theron For This Useful Post:
  7. #26
    Thanked: 2223
    I stand corrected.
  8. #27
    Langs die rivier, op n berg
    Thanked: 4442
    Die eerste “syncro” wat ek gesien het, was n 80’s oetinger vanaf duisland wat hier deur getoer het.
    Wat was oetinger?
  9. #28
    Jan 2014
    Northern KZN
    Thanked: 336
    Wat was oetinger?
    Oetinger was basies `n maatskappy wat spesialiseer het om VW boxer enjins meer krag te laat lewer. As ek mooi onthou het hulle selfs op `n stadium a plat ses van drie liter gebou vir VW kombis, gebasseer op die 2.1 wasserboxer.
    Groetnis
    Koos
  10. #29
    Oct 2017
    Vereeniging
    Thanked: 243
    Oetinger was basies `n maatskappy wat spesialiseer het om VW boxer enjins meer krag te laat lewer. As ek mooi onthou het hulle selfs op `n stadium a plat ses van drie liter gebou vir VW kombis, gebasseer op die 2.1 wasserboxer.GroetnisKoos
    Korrek. Die 3.2 wasserboxer was letterlik 2.1 plus 33.33 present. Jy kon pistons omruil tussen die 2. Daai ses was 'n ongelooflike enjin gewees.
    Die B staan vir Beneke
  11. The Following User Says Thank You to EtienneB For This Useful Post:
  12. #30
    Henties
    Thanked: 2156
    Wat was oetinger?
    Oettinger is the oldest VW tuner, they started off shortly after WW2 in Germany Tuning Beetle engines.
    http://www.superstreetonline.com/how...ect-car/19039/
    2012 FJ Cruiser
    1983 FJ60 Landcruiser -sold-
  13. #31
    Oct 2017
    Vereeniging
    Thanked: 243
    Quote Originally Posted by EtienneB View Post
    EK IS IDIOOT. 2.1 plus 50% nie 33.33 . . . Jammer!
