Results 1 to 20 of 37
    Oct 2017
    Rustenburg
    Thanked: 7693
    Default Rotisserie motor - I need a good one
    Can anyone point me to one that does not have plastic gears..
    Or if it has, good plastic gears, that wont strip after the first use..?
    ASB!
    Andrew van Staden
    =Anti Lockdown Activist=
    2021 FJ Cruiser
    Oct 2017
    Rustenburg
    Thanked: 7693
    Default Re: Rotisserie motor - I need a good one
    Are there even different makes?
    Or are they all from the same place?
    Andrew van Staden
    2021 FJ Cruiser
    Ruimsig
    Thanked: 25617
    Mine is a Weber and its >10yo but I suspect it might be locally made. I think Weber might use LKs here locally for some of their stuff.
    What make have you been using?
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    Rangeview Krugersdorp
    Thanked: 1657
    Perhaps try a more modest size roast ?
    Ford Figo 2016
  5. The Following 2 Users Say Thank You to duncang For This Useful Post:
    Oct 2008
    Grabouw
    Thanked: 452
    I have 2 LK's ones that I bought at the local co-op donkey years ago.
    I often use it for either 2 chickens (double prongs) or a large leg of lamb.
    They just keep going and are not even heavy on batteries. (Just keep spare batteries because you do not want to run out of power halfway through a roast.)
    The main thing to do so that the motor is not under strain, is to "balance" the load on the rod.
    Barnie Hickman
    Jeep XJ 95 "Witblitz" Jeep XJ 99 "Goldi" Swambo's
    Oct 2017
    Rustenburg
    Thanked: 7693
    I have no idea, has no branding, but it looks like that LK's one
    I see there is a stainless steel one on Take a while...
    Anyone with feedback?
    Andrew van Staden
    2021 FJ Cruiser
    Oct 2017
    Rustenburg
    Thanked: 7693
    I did 2 less than 2kg roasts, and the gears started slipping.
    I doubt anyone could balance the roasts perfectly.. (How do you?)
    Any way, I think it was more to do with the heat, that affected the gears maybe..
    Andrew van Staden
    2021 FJ Cruiser
    Ruimsig
    Thanked: 25617
    It looks the same as the others, the internal gubbins are probably the same as the others, just the outer case has changed.
    How many have you gone through and over what period?
    Hummer H3 V8
    W.A.P Objectivist
    Oct 2017
    Rustenburg
    Thanked: 7693
    Quote Originally Posted by BarnieH View Post
    I try.. but a bone in roast is very difficult to get perfectly balanced..
    Andrew van Staden
    2021 FJ Cruiser
    Oct 2017
    Rustenburg
    Thanked: 7693
    One after 2 roasts of +/- 2.5hours each
    Andrew van Staden
    2021 FJ Cruiser
    Ruimsig
    Thanked: 25617
    Methinks you are looking for one of these
    Hummer H3 V8
    W.A.P Objectivist
  13. The Following User Says Thank You to Estee For This Useful Post:
  14. #12
    Oct 2008
    Grabouw
    Thanked: 452
    Not trying to lecture, but the other thing that I learnt is that the rod must be aligned and level.
    This also for where it inserts into the motor.
    Barnie Hickman
  15. The Following User Says Thank You to BarnieH For This Useful Post:
  16. #13
    Oct 2017
    Rustenburg
    Thanked: 7693
    It is for one of these:
    Andrew van Staden
    2021 FJ Cruiser
  17. #14
    Aug 2020
    Oasis
    Thanked: 5010
    Baby potatoes affixed with toothpicks to the roast to balance it out.
    Anyway, that's what I have always done.
    Willem Greyling
  18. The Following User Says Thank You to MANDREAS For This Useful Post:
  19. #15
    Oct 2008
    Grabouw
    Thanked: 452
    Nice jobby there Andrew.
    Is it still new?
    If I were you, I would still check alignment. Mistakes could have been made during manufacturing.
    I have the plain poor man's rotisserie and speak only from that experience.
ID:	617207   Click image for larger version.
    Barnie Hickman
  20. #16
    Oct 2017
    Rustenburg
    Thanked: 7693
    Is it still new?
    Its about a month maybe 2 old.
    Anycase the "rod" is supported by two bearings on the opposite to motor side, and the alignment looks fine
    Andrew van Staden
    2021 FJ Cruiser
  21. #17
    May 2018
    Pearly Beach near Gansbaai
    Thanked: 158
    ASB!
    If this is after the first use then return it to the manufacturer and make it their problem!
    Go online and send them a complaint and wait for their response!
  22. #18
    Oct 2017
    Rustenburg
    Thanked: 7693
    Quote Originally Posted by Dirkba View Post
    What type would you recommend?
    Andrew van Staden
    2021 FJ Cruiser
  23. #19
    Apr 2019
    Thanked: 2254
    There are a few battery powered units on Amazon.com that are metal gears. Haven’t owned one so no experience… metal sounds better than plastic near heat though…. They ship them to SA reasonably.
  24. The Following 2 Users Say Thank You to heyyahhey For This Useful Post:
  25. #20
    Thanked: 49
    We have bought a couple over the years and so far all working well.
    Try
    https://bircraft.co.za
    1996 : 80 Series Landcruiser 4500 GX SW
  26. The Following User Says Thank You to LenArtman For This Useful Post:
