Results 1 to 20 of 26
    Oct 2007
    Default Removing foreign paint from duco.
    Hi all. Stupid sounding but serious question.
    Discovered today that I somewhere drove through (what looks like) white enamel paint.
    It is mostly in the left front wheelwell (thin streaks and dots) but also on the inside of the wheelarch of my Amarok (color-coded metalic paint).
    I am looking for advice on safely removing this paint from the duco as well as the wheel arch.
    I would appreciate any feedback.
    Thank you.
    2001 Toyota Hilux 3.0L KZ-TE 4x4 Raider d/c >
    with some extra bits...
    Greyton westerncape
    Thanked: 65
    Default Re: Removing foreign paint from duco.
    Looks like white road marking paint,however I see no alternative to repainting due to the splatter coverage.
    Aug 2017
    Thanked: 41
    Clay bar
    2010 Suzuki Grand Vitara 3.2
  4. The Following User Says Thank You to MarshallGTi For This Useful Post:
    FWM
    Oct 2012
    otjiwarongo
    Thanked: 256
    Quote Originally Posted by PolarBear View Post
    Thank you.
    In the past i removed tar from my bakkie with turps and no issue just a little and not tonhard rubbing. Do it on inner first. My bakkie is white so dont know ifnit will effect the metallic
    2017 VW Amarok 3.0 TDi V6 4Motion D/Cab
    2020 VW T Cross Highline R Line
    2019 Bushlapa Miskruier 1616
    Jun 2016
    Randfontein
    Thanked: 5013
    Car polish or clay bar will remove it. I would not worry about the inside of the wheel arch. Just drive a dirt road and cover it with some mud.
    Willie Knoetze
    2019 Nissan NP300 2.5tdi d/c 4x4
    Aug 2020
    Oasis
    Thanked: 5213
    Polar Bear, I am sorry to say that Amarok of yours is done with. Like in finish an' klaar.
    As it is now basically valueless, I'll gladly take it off your hands.
    Willem Greyling
    Melkbosstrand
    Thanked: 268
    Seikel can colour match their Kalahari bumper...
    2015 VW Amarok 4motion Auto
    2011 Conqueror Companion
  9. The Following 2 Users Say Thank You to BobMabena For This Useful Post:
    Garsfontein
    Thanked: 2318
    If it is factory colour coded metallic paint, the paint code will be imprinted somewhere on your VIN plate. Any automotive paint spot will be able to mix it up for you - not just Seikel.
    However, try the other recommendations here first - they will probably work.
    Personally, I would not bother, but I am a phillistine and my truck is 'amper mondig'. I do not care for the odd scratches or blemishes.
    Ian de Villiers
    Nissan Patrol GRX 4.5
  11. The Following User Says Thank You to iandvl For This Useful Post:
  12. #9
    Johannesburg/Prague
    Thanked: 121
    As mentioned turps is fine the new paint will come off easy and do no damage , I have even used thinners where it was bad and also no damage , perhaps if one has am old classic Ferrari or similar then perhaps no . all modern cars have a clear coat over the paint and it quite robust and the new paint (unless you left it on for months ) has not cured properly
    The hardest paint to get off is water based PVA when that dries its almost impossible to remove as solvents dont work so well and as they tend to be in thick lumps rubbing with any compound usually removes it together with the original paint , so if you get paint on your car first try washing it off as soon as possible , if that does not work then its probably oil based and much easier to remove
    The wheel arch inside I would not bother extra insulation
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  13. #10
    Apr 2012
    Louis Trichardt, Limpopo
    Thanked: 420
    1pc Vehicle Paint Glue Degumming Remover Eraser Wheel Pneumatic Discs Automobile Rubber Grinder Drill Adapter
    '13 Toyota Hilux 4x4 XCab
  14. #11
    Johannesburg/Prague
    Thanked: 121
    Quote Originally Posted by Metalmachine View Post
    I would not use this to remove anything on my vehicle , much better by hand
    Swambo Volvo S40 T5
  15. #12
    Jan 2015
    Thanked: 596
    Most of the modern water-based ducos on cars are immune to a wipe with thinners. That would most likely remove what looks like road marking paint without affecting the clearcoat.
    I recently had the side and bonnet of my Bantam resprayed. A few weeks later I also discovered that I had driven through something that resembled paint. I took it back to the spray-painter, expecting another huge quote to respray. No, he said, "Just wipe it off with normal thinners." He then sent one of his handlangers with a container of thinners and a rag, who promptly just wiped the side of the bakkie down and gave it a quick polish. No charge!
    Try on a small area under the bumper or somewhere that is not visible and see what transpires.
    Guy B. Vergoes Houwens
    2014 LC76 4.5 V8
  16. The Following User Says Thank You to ghouwens For This Useful Post:
  17. #13
    Tshwanetoria
    Thanked: 1213
    I have something like resin splattered on my bakkie. Must have happened on the way to or from the KTP. I think it must have been dripping from a lorry or something? Only saw it when washing the vehicle for the first time on my return.
    So far polish, clay bar, terps, thinners and acetone not working!
  18. #14
    Tshwanetoria
    Thanked: 1213
    I have something like resin splattered on my bakkie. Must have happened on the way to or from the KTP. I think it must have been dripping from a lorry or something? Only saw it when washing the vehicle for the first time on my return.So far polish, clay bar, terps, thinners and acetone not working!
  19. #15
    Johannesburg/Prague
    Thanked: 121
    Must be a water based product when they dry its virtually not possible to remove , when you get expert advice please post I also found on a 2012 car some PVA (very small amount ) was difficult to remove , as mentioned modern cars have ecco friendly water based paint
    Swambo Volvo S40 T5
  20. The Following User Says Thank You to 12richardk For This Useful Post:
  21. #16
    Nov 2011
    Thanked: 1514
    Maybe careful application of heat/steam?
    -or a fine chisel, and a spot of nail varnish!
    Good luck!
    - Charles Bukowski
  22. #17
    Tshwanetoria
    Thanked: 1213
    Quote Originally Posted by Patrick L View Post
    Good luck!
    I also thought of that "fine chisel" option, with lots of patience
  23. #18
    Sep 2012
    Thanked: 15
    Try Acetone, if thinners wont work, and its a epoxy, then nothing will except chipping?
  24. #19
    Garsfontein
    Thanked: 2318
    Quote Originally Posted by Reccepops View Post
    Be careful with acetone. That will probably eat the real paint off too...
    Ian de Villiers
  25. The Following User Says Thank You to iandvl For This Useful Post:
  26. #20
    Thanked: 562
    Quote Originally Posted by 12richardk View Post
    Was used on Wheeler Dealers when Ant needed to remove glue residue. Works well for the bulk of the item to be removed and then you finalise by hand. Just have to be patient .... In the past Ant also used sharp blade or plastic blade scraper (similar to this....) https://www.amazon.com/Ehdis-Visibil.../dp/B01HLWB0BM
