Results 61 to 80 of 86
  1. #61
    Thanked: 20097
    Default Re: Disco 1 300tdi oil usage
    Quote Originally Posted by Henkus View Post
    Loves to hate.
    46K is steeds 'n bargain want daar is min voertuie wat by 'n D1/D2 kom.
    My D1 se ratkas het 39K gekos en ek het maar 38K vir haar betaal. Al seker 20miljoen se plesier uit haar uit gekry.
    You just supported my price estimate.
  2. #62
    Jul 2018
    Potchefstroom
    Thanked: 109
    Loves to hate.
    R20mil se plesier!! Nou praat jy waar!!
  3. The Following User Says Thank You to Kudus For This Useful Post:
  4. #63
    Jul 2018
    Potchefstroom
    Thanked: 109
    Love the D1, both V8 and TDi. But one must eventually draw a line.
    It is that eventually that I have to figure out. I haven’t seen the line yet…
  5. #64
    Thanked: 20097
    Quote Originally Posted by Kudus View Post
    Well cool then. Just something to think about at 05h00
  6. #65
    Jul 2018
    Potchefstroom
    Thanked: 109
    I’d like to rather think of the Kalahari trips I did and what I am still going to do
    But yes, I am also laying awake because of the problems the car has at the moment
  7. #66
    Jul 2018
    Potchefstroom
    Thanked: 109
    Britpart bearings are the only bearings they could find for the small end bearings. Would you trust Britpart bearings?
  8. #67
    Thanked: 20097
    I'm not allowed to comment.
  9. #68
    Langebaanweg
    Thanked: 2228
    As the small end of the conrod is tapered, fitting them could be more difficult, as you have to get the conrod square to the small end bearing when pressing them in.
    I know that Mike from Britannica Restoration rather fit new conrods.
  10. #69
    New Germany
    Thanked: 1320
    maybe give Turner engineering in UK a shout see what make there ones are as on there sight says aftermarket OEM
    2005 Defender TD5
  11. #70
    Jul 2018
    Potchefstroom
    Thanked: 109
    Thanks for your advice. Will work on it tomorrow morning
  12. #71
    Mar 2014
    Brakpan
    Thanked: 592
    All i can add is Britpart is not good. Cant speak my mind also
    Four wheels move the body,
    Landys move the soul.
    0735236742
    Current: Discovery 2 td5.
    Next landy, D3 V8 HSE Previous one.D1 v8i D1 300 TDi donkey, D1 V8 Fuel THIEF!!! freelander 1, biggest pos known to man,
  13. The Following 2 Users Say Thank You to Sam vd Merwe For This Useful Post:
  14. #72
    Mokopane
    Thanked: 309
    I think jfh put his finger on the problem here.
    Whether they are Britpart or not, the problem is fitting them effectively. Somewhere on my Fugard thread I went through this story as well... ended up buying a set of Bearmach conrods from LP4A - I think it ended up costing around R5k. This after spending about R3k on engineering the old ones and not being happy with the result.
    Turner Engineering does sell original LR conrods, reconditioned with new small ends. I would trust them. But you will pay...
    The engine is being done by a reputable indy - ask them for some honest advice, in my opinion. What do they usually do? I would imagine that they would be happier fitting new conrods as well. This whole thing will impact the original quote they gave you - maybe they are trying to take a cheaper route to avoid doing this.
  15. #73
    Jul 2018
    Potchefstroom
    Thanked: 109
    Thanks antvz. Will give them a call asap in the morning then. Already emailed turner engineering. See what they respond
  16. #74
    Jul 2018
    Potchefstroom
    Thanked: 109
    What do you guys think of Bearmach’s bearings?
  17. #75
    Jul 2018
    Potchefstroom
    Thanked: 109
    What is value for the clearances it should run?
  18. #76
    Langebaanweg
    Thanked: 2228
    I'll have to ho on the site to see, but it's more about what brand they sell.
    This will be found in the manual.
    Is this for the small end bearing?
  19. #77
    Jul 2018
    Potchefstroom
    Thanked: 109
    Small end bearings yes. Guy said its running 500 do he is happy
  20. #78
    Langebaanweg
    Thanked: 2228
    This all I could find in the overhaul manual.
  21. #79
    Langebaanweg
    Thanked: 2228
    Did he say 5 thousands?
  22. #80
    Jul 2018
    Potchefstroom
    Thanked: 109
    Thanks for all your trouble. He said in Afrikaans “500stes”
