Results 1 to 18 of 18
Thread: Do I really????
    Aug 2018
    Paarl
    Thanked: 308
    Default Do I really????
    Do I really need to get the victron 15a smart charger or can I get a smaller amp victron charger.
    Which one will work to keep my 105ah deltec charged in my camper.
    Friemersheim, Southern Cape
    Thanked: 5432
    Default Re: Do I really????
    What is price difference?
    Robert van den Berg
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    Cape Winelands
    Thanked: 361
    You don't really need a Victron for that size unless you are in desperate need to burn some cash
    2011 CashCow 1.6 (Swambo)
    Aug 2018
    Paarl
    Thanked: 308
    Quote Originally Posted by Kamakazi View Post
    So what battery charger will be suitable then.
    Nov 2014
    Thanked: 3599
    75/10 - R1,580
    75/15 - R1,755
    100/15 - R2,143
    100/20 - R2,667
    100/30 - R3,900
    Can't find anything less than 10amp. To be honest, not sure that saving from 10 - 20 is worth the compromise, nor the 75 vs the 100 volt. Those are the blue solar
    Smart
    75/10 - R2,163
    100/15 - R2,738
    100/20 - R3,117
    R550 in it, I'd be buying at least the 100/15 - personally I have the 100/20
  6. The Following User Says Thank You to Gungets Tuft For This Useful Post:
    Jan 2018
    Jeffreys Bay
    Thanked: 13
    Just my thoughts... I've got the 100/20...but I only have 2 x 100w panels connected in series, which I use to charge my 24v lifepo4 battery... That means I've only seen a max of 8amps being used for charging. So if you've got bigger panels and push more amps, great. I'm in the process of getting the Orion-Tr 12-24 that gives 10amp charging. And I'm happy with that capacity of charging.
    I do get about 13 amp charge rate when I charge a 12v gel battery with the same 2 panels connected in series
    Here's some more info at post #10
    https://www.4x4community.co.za/forum...3-Victron-Mppt
    Aug 2018
    Paarl
    Thanked: 308
    I just want a good charger to permanently mount in my bush caravan which can handle water and dust.
    Just need to charge my 105ah battery.
    Nov 2014
    Thanked: 3599
    Quote Originally Posted by fatbike View Post
    Nothing is going to handle water - make sure it's completely waterproof in a halyester housing of some sort.
    You need to balance charge input (100w - 7a max) , charge efficiency (PWM vs MPPT), battery size (105 from 50% SOC is 50amps, 5 hours at 10a, 10 hours at 5a). If you're drawing 5a from 16.30 to 07.30 (10 hours) you're going to, simplistically, need 10 hours at 5a to charge the battery back up. So 100w is too small, and 5a too small.
    Maths time.
    What is the estimated draw
    What panel do you have for supply
    Where do you intend to camp (Average usable sunlight)
  10. The Following User Says Thank You to Gungets Tuft For This Useful Post:
    Aug 2018
    Paarl
    Thanked: 308
    Quote Originally Posted by Gungets Tuft View Post
    Maths time.
    I am talking about a 220v charger not solar.
    The victron is ip65 waterproof
    Nov 2014
    Thanked: 3599
    Then 10amp will be fine, since if you can charge batteries on mains then you can also run the fridge on mains. Your only issue is travel time, then fit a cable to charge the spare battery via the alternator
  13. #11
    Aug 2018
    Paarl
    Thanked: 308
    Thanks I run a permanantly connected 160w solar panel on my roof.
    I just want to upgrade my current benton bx1
  14. #12
    Thanked: 5432
    10A charger R2 271 Victron 10 Charger
    15A Charger R2 612 Victron 15A charger
    To me no contest, I'll go 15A
    Robert van den Berg
  15. The Following 3 Users Say Thank You to Prof For This Useful Post:
  16. #13
    Aug 2018
    Paarl
    Thanked: 308
    Jip my thoughts also.
    I must add I am adding tthe victron smart shunt to my set up also.
  17. #14
    Apr 2014
    Thanked: 6044
    I have 7 A intelligent but I needed an other. I took that 15A Victron. In a hurry it charges that 105 A battery (same as mine) quickly (Had this case already one time when we had to leave van to PE). I keep both of the charges out of rain: under semi closed bonnet, in front cone or now inside the van.
    Jouko
    2003 Grand Cherokee 4.7l
    2012 Smart
    Never drive a normal car 8)
  18. #15
    Apr 2011
    Thanked: 97
    I went full monty. I have the IP65 15amp charger and it's a pleasure. But then I also have lithium, whick sucks it all up.
    For in car I have the Orion 30 amp, and for them sunny days a SmartSolar 100 | 15 (untested).
    I also have a SmartShunt, and that is a magical device, specially for lithium.
    The fact that most of these components have built-in bluetooth also raises the bar.
    Leon Smith
    2020 Toyota Hilux XtraCab 2.8 4x4
    Fiat 500 0.9l turbo flattie
  19. The Following User Says Thank You to leons For This Useful Post:
  20. #16
    Apr 2011
    Thanked: 25
    FWIW. I have the NL 5A charger and its not enough in my circumstances.. At the two camps we stayed in in Kgalagadi, power goes off at night at 10, back on at 5... Running two engel fridges, the charger could not keep up.. So I am getting another one, at least 10A.. I will use the NL at home where cycle time isnt a factor.
  21. #17
    Quote Originally Posted by fatbike;[URL="[URL
    tel:4645903[/URL]"]4645903[/URL]]I just want a good charger to permanently mount in my bush caravan which can handle water and dust.
    Hi Fatbike,
    I have a compass off-roader caravan/trailer.
    I have 2 x 102ah batteries installed. I have a 230/12V 25A victron ip65 charger for when there is 230v power. I then have a 330w solar panel strapped on the roof with a victron MPPT IP67 100/30 solar charge controller.
    when we offgrid, I run 2 fridges 72l campmaster and the batteries are fully charged by about 14h00 the next day.
    The victron is simply one of the better chargers available that takes care of your batteries. If you want a smaller size just be sure you will have enough sun to recharge everything. For me the few extra hundred rand(about R350-R400) between the 15A or 30A wasn’t an issue.
    I have been caught with limited sun for a day and a half and have not struggled.
  22. #18
    Aug 2018
    Paarl
    Thanked: 308
    Quote Originally Posted by The Abe View Post
    Hi Fatbike,
    Jip also have the compass I want to permanently mount charger inside.
    I have 160w panel on roof mounted permanently and can add another panel if I want to.
