Page 3 of 3 FirstFirst 1 2 3
Results 41 to 55 of 55
Thread: LR heaven
  1. #41
    Thanked: 719
    Default Re: LR heaven
    All these jealous people
    Go and test drive one, you will want one.
    THEN, if your Puma is 2013 and up and has less than 100 000km on it call me please
    OOPS:
    Please refer to page 2 for some pics of Bruce's Trip
    Defender Kalahari
    Series 3 SWB
    Series 1 De Luxe Cab Pickup
    Series 1 Station Wagon 88''
  2. #42
    Plett/Paulshof
    Thanked: 1681
    Bit of dust ingress around bottom of rear door seals. Did some rough roads today around Morgan bay and the defender cruised everything. Small rattle on rear door, window door trim has a loose dart clip that pops out.
ID:	617948   Click image for larger version.
ID:	617949   Click image for larger version.
ID:	617950   Click image for larger version.
ID:	617951   Click image for larger version.
ID:	617952   Click image for larger version.
ID:	617953   Click image for larger version.
ID:	617954   Click image for larger version.
    Bruce Hunter
    "your signature should not be used to judge you or your opinions"
  3. The Following User Says Thank You to BruceHun For This Useful Post:
  4. #43
    Aug 2017
    Thanked: 357
    Starting to sound that it might be a real defender.
  5. #44
    Nairobi
    Thanked: 268
    Quote Originally Posted by Jakkals. View Post
    I have an annoying dust ingress issue with my 150 that I've failed to completely trace. So that's not a defender only issue, just saying.
  6. #45
    Thanked: 118
    Quote Originally Posted by byaru1 View Post
    Have a look at the decompression valve flaps(equalizer vents?) in the rear of the boot behind the trimmings. It might be twisted for some reason or not sealing properly. I have seen some not installed correctly by the factory.
    2006 Defender 110 Td5
  7. #46
    Plett/Paulshof
    Thanked: 1681
    Figured out the guys who did the smash and grab film damaged the dart clips. They had to redo the film twice so this part was removed 3 times.
    Bruce Hunter
  8. #47
    Nairobi
    Thanked: 268
    Quote Originally Posted by Suid-Wes View Post
    OK thanks for the pointers. I will take a look. Hadn't explored this. Behind which trimmings is this.
  9. #48
    Plett/Paulshof
    Thanked: 1681
    After 4000km's, no issues with the new one. LR replaced the dart clip and all good. Dust ingress being checked.
    Did a 6 hour deep clean yesterday! About 100kg of mud came off.
    Average fuel consumption sitting at 9.4l/100km. Coming back via East London, 10 hour trip with average speed of 115km/h.
    Wife commented how much better the Defender is than the LC200 for this type of trip. Drives better, brakes better, more comfortable, quieter, smoother.
    Bruce Hunter
  10. The Following 2 Users Say Thank You to BruceHun For This Useful Post:
  11. #49
    Thanked: 648
    A good purchase Bruce. In your opinion how does the Boot Area compare with the D4 - is it a similar depth.
    Many Thanks
    The more we talk about what is wrong, the less we see what is right in this world.
  12. #50
    Thanked: 118
    On the inside in the boot. You will have to remove the carpet panels to see it.
  13. The Following User Says Thank You to Suid-Wes For This Useful Post:
  14. #51
    Plett/Paulshof
    Thanked: 1681
    Quote Originally Posted by MikevR View Post
    Many Thanks
    The D4 boot quite a bit bigger. Not sure of actual litre difference. No big deal for me as only two of us. With trip to Transkei, I folded seats flat and had lots of space for dive gear, fridge, suitcases, grocery box, fishing tackle etc
    Bruce Hunter
  15. The Following User Says Thank You to BruceHun For This Useful Post:
  16. #52
    Reebok / Bloemfontein
    Thanked: 11
    Interesting design: the second row has been moved to the back about 10cm (I guess) which reduces the boot space. It means that the seats folds flat like the Disco without a complicated mechanism or reducing the seat height. I am starting to like it as it gives n luxury/roomy feel for second row passengers.
    if you install the metal luggage rack, you can stack the boot space easily when carrying 4/5 passengers while having a see through space above the spare wheel.
  17. The Following 2 Users Say Thank You to Etn For This Useful Post:
  18. #53
    Plett/Paulshof
    Thanked: 1681
    First issue cropped up on Saturday. DRL on headlight failed so new headlight it is. It is the outer ring of the headlight that should be on.
    Bruce Hunter
  19. #54
    Thanked: 118
    Does'nt it switch off when the indicator is used? Maybe a relation to that?
  20. #55
    Plett/Paulshof
    Thanked: 1681
    No, the whole headlight turns off when indicator on and you turn in that direction. . This is just the DRL standing still. They replaced it and now works correctly.
    Bruce Hunter
