Results 1 to 7 of 7
    Gordon`s Bay
    Thanked: 13
    Default Window washer tank and detergent
    Does someone know the capacity of the window washer reservoir on a 2014 Fortuner and what detergent can be added to clean oily windscreens without damaging the rubbers and pump--A friend of mine used normal dish washing liquid and it stuffed up his rubbers around the glass and the pump impeller .
    I do have a bottle of BUG OFF that is for windscreens but I want to make sure it does not eat at my seals.
    Toyota Fortuner D-4D 4x4 AT---My "speed control en navigasie "sisteem is al oor die 50 jaar oud!Ham Call ZS1SSM
    Nov 2014
    Thanked: 2564
    Default Re: Window washer tank and detergent
    Quote Originally Posted by Mark Sanderson View Post
    Been using Sunlight liquid forever, even before the Tuna. On the Tuna for 9 years and no issues with windscreen rubber or pump impeller.
  3. The Following User Says Thank You to Gungets Tuft For This Useful Post:
    Friemersheim, Southern Cape
    Thanked: 4686
    Quote Originally Posted by Gungets Tuft View Post
    I store my knapsack sprayers with a water and sunlight dilution to prevent rubber seal hardening
    '98 Daihatsu Rocky 'The Kitty'
    '02 Daihatsu Rocky 'The Bully'
    "What can be asserted without evidence can also be dismissed without evidence."
    May 2016
    Thanked: 4014
    I use Wash-n-Wax.
    Sunlight Liquid leaves streaks on the paint and chrome
    2006 VW Touareg V10 (Sold)
    Feb 2016
    Paarl
    Thanked: 775
    Been using Sunlight liquid since forever. But I like to use car polish on my windscreen. It makes water run off windscreen. At speed on highway, I don't need to switch on wipers. Sunlight will remove the wax. So decided to change to liquid 'wash n wax'
    2009 Corsa Utility 1.7Dti (Business bakkie)
    2011 Honda CRV 2.4
    2007 Hyundai Atos (Tossie)
    Sep 2011
    cape town
    Thanked: 122
    The trick is to mix the sunlight and others with water before adding to the window washer reservoir.
  8. The Following User Says Thank You to riyadh For This Useful Post:
    Dec 2017
    Thanked: 16
    Toyota sells a bottle of washer fluid for R20 I think it is. Iím very happy with that.
    2015 Prado VX 3.0 D4D
    2012 FJ Cruiser 4.0 V6 (SOLD)
