Results 1 to 9 of 9
    Hartbeespoortdam
    Thanked: 23
    Default Drop Fridge Slide (QA)
    Hello Everyone,
    I am looking for a drop fridge slide I can mount un top of my drawer system that could for a 90lt NL.
    What will you recommend?
    Rgs
    Land Cruiser 100 VX Diesel
    Land Cruiser 200 VX Diesel
    Land Cruiser FJ45
    KTM 990S
    Jan 2020
    Thanked: 132
    Default Re: Drop Fridge Slide (QA)
    There is a thread here on forum the one of the member created himself no quite who it was but was very explicit on how he made it
    Jul 2014
    Waterfall
    Thanked: 131
    I have used the Stofpad Drop Down fridge slide. Great product.
    Only negative I found was its weight and that it is difficult to fit in my 200 with that size fridge. I had to customise mine to allow enough space for the door to close
    2016 V8 D/Cab Cruiser
    Land Cruiser VDJ 71
    2020 LC 200 GXR
    2020 LC FJ
    Okahandja, Windhoek
    Thanked: 1112
    Quote Originally Posted by geoff norton View Post
    I have used the Stofpad Drop Down fridge slide. Great product. Only negative I found was its weight ....
    Jis its well made. I cut square pieces out of all sections too reduce the weight, and its still solid. Now I can carry it comfortable by myself.
    Johan Kriel
  5. The Following User Says Thank You to JLK For This Useful Post:
    Jul 2013
    Thanked: 411
    En die yskas op die slide, vol koedoe steaks .? 😁
    Thanked: 5250
    Geoff, I see you have the Big Country drawer. Are you happy? Any rattles?
    Also looking at same setup for my 105
    Gert Grobler
    VW Touareg V6 Tdi Escape; Land Cruiser 105
    Bush Lapa Boskriek 816
    Hartbeespoortdam
    Thanked: 23
    thank you, I want it for my 200… Will go take a look at them….
    Land Cruiser FJ45
    KTM 990S
    Jul 2014
    Waterfall
    Thanked: 131
    Nys, I am very happy with my drawer system. There are no rattles.
    When you look at drawer sysyems it's difficult to imagine the weight. On the 200 they are nearly 100kg. Wish that there was a lighter option as all the extras add up very quickly.
    Big Country made my 1 draw shorter and I have a hatch where my 2nd battery drops in. This works well to keep the battery totally out the way.
    Land Cruiser VDJ 71
    2020 LC 200 GXR
    2020 LC FJ
    Okahandja, Windhoek
    Thanked: 1112
    Quote Originally Posted by janseekat View Post
    En die yskas op die slide, vol koedoe steaks .? ��
    Dit was die moeilikheid daai slide is so swaar as die yskas vol koedoe steaks is moes ek ekstra vere kry onder die DC.
    Johan Kriel
