Results 1 to 13 of 13
    Thanked: 520
    Default Blocked drain cleaning
    Looking for a affordable drain cleaner to clear the neigbours roots from our drainpipe. The usual suspect are crazy expensive. Centurion area.
    2006 VW Touareg 4.2 V8 Auto
    2000 Disco 2 GS 4.6 V8 Auto
    2013 Wildebeest Kalfie Boswa
    2002 Audi S6 4.2 V8 quattro
    2013 Freelander SD4 (SWAMBO)
    ORRA Z07
    Melkbosstrand Cape Town
    Thanked: 121
    Default Re: Blocked drain cleaning
    Why are you worried about cost , his roots are damaging your pipes , he should pay.
    Jul 2010
    Pinetown
    Thanked: 2615
    Most likely need to be removed mechanically rather than chemically me thinks ?
    Then unfortunately the cause need to be addressed. Tree or shrub, whatever.
    I had this problem with my neighbour who was moving toward some legal solution, so I was forced (by across the wall chat) to cut down a very mature tree Ficus Nataliensis.
    However its root system is very aggressive and was starting also to damage my brick paving, swimming pool, steps, etc.
    So, unfortunately there is sometimes no other solution.
    Yes, speak to him and make him realize that.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  4. The Following User Says Thank You to Peter1949 For This Useful Post:
    King Williams Town
    Thanked: 2008
    Get a set of sewer Rods with that twirly corkscrew fitting and twist those roots out. I'm led to believe nothing will eat those roots up.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
  6. The Following 2 Users Say Thank You to hunter26 For This Useful Post:
    The tree needs to go to avoid a recurring problem.
    Roots would need to be cleared out of the pipe mechanically.
    Go through insurance if you can to save cost on the basis of a blocked drain. If paving etc needs to be lifted and relayed then the costs can run up quite quickly.
    Dec 2007
    Nkomasi
    Thanked: 395
    get n bucket of coppersulphate
    May 2016
    Thanked: 4282
    For roots to block a sewer, there has to be a leak in the pipe.
    Removing the roots will be a temporary fix only.
    2006 VW Touareg V10 (Sold)
  10. The Following User Says Thank You to 4ePajero For This Useful Post:
  11. #8
    Thanked: 520
    Quote Originally Posted by bertus View Post
    Will this kill the roots?
    ORRA Z07
  12. #9
    Thanked: 520
    Quote Originally Posted by 4ePajero View Post
    Is so... maar dit is in die buurman se erf.
    ORRA Z07
  13. #10
    Thanked: 302
    Meganies is al manier om die drein nou oop te kry. Dan boom afkap, riool oopgrawe en die beskadigde stuk pyp vervang.
    Ek kan vir jou kom kyk wat die opsies is? 073 0924 714
    Si vis pacem, para bellum
  14. #11
    Thanked: 1514
    Friend of a friend with a roots problem in drains was told, by a drains inspection co. guy, to gooi a 5l poolacid down the drain, wait a few minutes, follow with a 100l bucket or two of water to fill up manhole to flush under some pressure. i believe it worked to kill the roots, but is probably not allowed, so don't do that.
    "The problem with the world is that the intelligent people are full of doubts, while the stupid ones are full of confidence."
    - Charles Bukowski
  15. #12
    Thanked: 520
    Quote Originally Posted by thabogrobler View Post
    Dankie.. sal jou mre luitjie gee 👍
    ORRA Z07
  16. #13
    Apr 2017
    Durban North.. my name Dudley Reid
    Thanked: 4771
    If you don't know what you doing
    DON'T, or else you going to be digging the rods out
  17. The Following User Says Thank You to Dudleytheplumber For This Useful Post:
