Results 1 to 6 of 6
    B-gowrie Randburg
    Thanked: 395
    Default VW Polo Headlamps wont Dip/Dim
    I have a 4 yr old Polo whose head lights
    wont flick to Dim / Low Beam when required.
    I can get them on bright per normal
    ... but when I dip the switch only get
    v. dim park or night lights.
    I suspect the problem does not lie with the bulbs but rather the switching relay or possibly the round dashboard switch : Off/Park/MainBeams
    Where is the the relay panel located
    and how is it accessed ?
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
    Jul 2013
    Thanked: 412
    Default Re: VW Polo Headlamps wont Dip/Dim
    H7 globes? on dim both blown/ fused.
    B-gowrie Randburg
    Thanked: 395
    Quote Originally Posted by janseekat View Post
    The lamps are fine on bright but dont dim.
    Theyre not compound two function (high & low beam) bulbs as in older cars as far as I can see... or is there a seperate bulb for dim:low beam ?
    The Greatest Rover.
    A Home from Home
    Jul 2013
    Thanked: 412
    The amarok has 2 seperate beams. my sons polo and jetta and as I have observed all vw have 2 seperate beams.
    The fuse for the hi and low share.
    If you had the low beam replaced by night breakers or eq . remove the bulbs and test them.
    Maar jy moet nie gorilla hande he nie.
    Brackenfell
    Thanked: 20
    I remember my brother having the same issue on his Polo and having to replace the light stalk eventually? Know he drove around with his bright bulbs removed as they didn’t switch off at all.
    Aug 2017
    Thanked: 38
    Think its the headlight switch, if something goes wrong, control unit decides its safer to have lights on permanently rather than risk having no lights at night. Switch is easy to remove, maybe find someone willing to let you test with their switch
    2010 Suzuki Grand Vitara 3.2
  7. The Following User Says Thank You to MarshallGTi For This Useful Post:
