Results 1 to 7 of 7
Thread: Diesel guys
    Dec 2013
    Ramsgate Kzn
    Thanked: 138
    Default Diesel guys
    Guys no too familiar with diesels..I understand that the diesel filter is on the right but to the left..what is that ?Is it a water separator ?If so how does it compare to a donaldson water seperator ?
    Thanked: 1713
    Default Re: Diesel guys
    Water separator and priming pump.
    Not sure how it compares to others.
    Priming pump is used to get fuel through the pump if you have run it dry or had to strip it for some reason.
    Dec 2013
    Ramsgate Kzn
    Thanked: 138
    Thanks ..will have to check how it can be incorporated
    Thanked: 1713
    You can get a universal filter and housing from Midas or any of those which incorporates all three functions. Filter, water seperator (with electrical feedback to a warning lamp on your dash) and priming pump. If space is the problem, that might be the answer.
    Dec 2013
    Ramsgate Kzn
    Thanked: 138
    Thanks.. How many microns should I be filtering for a isuzu kb 280?
    Thanked: 1713
    No idea, but find out what the standard filter's GUD part number is, and phone GUD.
    Nigel
    Thanked: 2561
    Quote Originally Posted by Mellin View Post
    Idealy, below 2 microns. None of them. Except for UDF, Cat, Donaldson, etc. The dedicated guys.
    Uniglide
    +27 zero eight 2 four 95 9252
