Results 1 to 11 of 11
    Default Extra fuel filter
    Is there a way that one can install an extra filter (plastic ones) in line with the existing diesel filter to try to prevent dirty particles going to the diesel pump? (3.2 diesel)
    Barberton
    Thanked: 2676
    Chris, try searching "UDF filters". There was a million page thread, with plenty data, on the subject.
    Mikpunt, Durbanville
    Hi Chris.
    The plastic one you see in midas etc are generally for petrol vehicles which don't need as good filtration as diesels do, I don't think it would help as it would let most of the damaging stuff through.
    I am looking also adding an extra filter to my DiD, I have bought a Gen 3 with the non common rail motor.
    The OEM filter (replacement is a GUD Z554) does 7-9 micron filtration, I have found a filter holder CF16 and GUD Z314 filter that does 3-5 micron with water trap that I am going to install after the OEM unit. Will cost with all fittings and hoses just over R500.
    The udf filter, as I understand it, is more suited for the common rail motors as it filter to 2 micron, and making it quite pricey at over a grand for filter plus holder.
    Nicholas Gibson
    2005 Gen 3 Pajero 3.2 DiD Auto LWB
    Mods:
    ARB front bumper, OME, Lynx Bash Plate, Lynx Rock-sliders, Lynx rear steel bumper, Front Runner 40lt Long range tank, Madman EMS2 engine management module, dual battery system, 700FF spots
    Corsa 1.4 Club (swambo)
    "In my house I'm the boss, my wife is just the decision maker." - Woody Allen
    Thanked: 181
    UDF filter is first prize.
    But a good alternative is to install a Racor or Donaldson with water separator.
    I have installed a Donaldson filter with water separator. It is not just dirt that damages a diesel engine
    Thanked: 571
    Quote Originally Posted by Greenhorn View Post
    +1
    Mine - http://www.4x4community.co.za/forum/...ight=donaldson
    2011 Fortuner 3.0 D-4D 4x4
    2008 Lexus IS250 V6
    Jaco
    UDF filter kit = R5000 any idea of something cheaper?
    Thanked: 571
    Quote Originally Posted by JacoE View Post
    R1,500-R1,700 installed with fittings, pipes etc...
    2008 Lexus IS250 V6
    Jaco
    Quote Originally Posted by Chris Gunter View Post
    Hi Chris, I see you have the same motor as I do.
    The Toyota d4d common rail motor and mitsubishi DiD common rail motors need much higher filtration due to the tighter tolerances and higher pressures in the injectors so I would also agree with using a Donaldson, racor or even Udf 2 micron filters.
    I think it is overkill in our older generation diesels (although there is no such thing as too much filtration!) , that's why I am going for an extra in-line 3-5 micron filter as recommended by Tim at the GUD filters technical dept after having a long chat to him and saying I wanted some extra protection. He says the standard filter is already very good, in it self as being a 7-9 micron filter which is better than the newer toyota d4d 10 micron OEM filter...
    M2cw.
    Nicholas Gibson
    Mods:
    Thanked: 181
    Racor or Donaldson filter are cheaper and are more readily available
    Thanks, I will then follow up with Donaldson, just spend R24000-00 on diesel pump end injectors so want to minimize the risk of dirty diesel
    Dec 2013
    Ramsgate Kzn
    Thanked: 152
    Default Re: Extra fuel filter
    Sorry to bring up and old thread .
    How does the donaldson filer system compare to a standard water seperator as per pic.
  1. Colt 2.8tdi cold start issues?
    By Hanman1 in forum Mitsubishi
    Last Post: 2014/04/01, 10:16 PM
  2. Replies: 12
    Last Post: 2012/07/18, 06:15 PM
  3. Musing on modern day vehicle electronics and the duality of man
    By IanG in forum Vehicle & Technical Chat - General
    Last Post: 2012/04/13, 03:33 PM
  4. Discovery 1 Fuel Filter D1 V8
    By Die Hard in forum Land Rover
    Last Post: 2010/04/29, 04:39 PM
  5. K&N air filter
    By skala in forum Mitsubishi
    Last Post: 2009/11/05, 07:34 AM
