Results 1 to 13 of 13
    Mar 2014
    Randburg
    Default 46mm diameter hole in 3.5mm steel plate
    I would like to find a cost effective method to make a 46mm hole in a steel plate.
    I am installing an engine in my bicycle and need to install the rear sprocket around the hub and close to the wheel spokes. The hub and sprocket do not need to be joined or fixed together.
    The sprocket came with a hole of diameter 40 mm while the hub is 45mm. The thickness of the sprocket is around 3.5 mm.
    I tried grinding the hole with a Dremel but all that did was grind my grinding disc
    I was looking at other methods like a hand reamer or drill reamer but none go as large as 50mm.
    I am also trying to contact some machine shops around me to see if they could help.
    My problem is, how do I enlarge the hole with hand tools or a drill?
    I have added some pictures for clarity.
ID:	614959   Click image for larger version.
    Thanked: 3867
    Default Re: 46mm diameter hole in 3.5mm steel plate
    Only way to do it with any accuracy is on a lathe. Arrive with beers at a friend who has a lathe or get a local engineering shop to do it for you
    Anton Muller
    "That which can be asserted without evidence, can be dismissed without evidence." Christopher Hitchens.
    2020 X3 M40i
    Birkin SR20VET race car
  3. The Following 4 Users Say Thank You to mullerza For This Useful Post:
    Thanked: 3508
    Quote Originally Posted by kidharb View Post
    That's what I'd do if it were mine.
    Or find a mate with a milling machine or a lathe that can turn that diameter.
    John Kilfoil
    'People who believe the vaccination will alter their DNA should probably consider it an opportunity"
    Rover P6
    Range Rover P38 HSE -- Sold
    Moto Guzzi LeMans
    Aprilia Tuono V2
  5. The Following User Says Thank You to JohnnoK For This Useful Post:
  6. #4
    Mar 2012
    Randburg
    Thanked: 1670
    I guess If my only option was to do it myself, mount the sprocket on a piece of wood (preferably hardwood) with those holes located on a PCD. Get the centre of the hole. Use a holesaw with a centre guide drill. Won't be 100% but as close to dammit as you'll get.
    A drill press, preferably to be used.
    GaryG
    Honda Civic Type R
    - Daily Drive
    Isuzu KB 250 Xrider - Swambo
    4.0 XJ Jeep Cherokee - Sold
  7. The Following 2 Users Say Thank You to ViperR For This Useful Post:
  8. #5
    Mar 2021
    Hartebeespoort Dam
    Thanked: 58
    As the others above mentioned, either a lathe or lasercut.. good luck
  9. #6
    Sep 2016
    Lephalale
    If you can get a Hole saw that size, screw to a piece of wood, mark the center and drill with the hole saw.
  10. The Following User Says Thank You to husky28 For This Useful Post:
  11. #7
    Thanked: 2114
    Quote Originally Posted by ViperR View Post
    Isn't the sprocket too hard for a hss hole saw?
  12. #8
    durban
    Thanked: 1862
    It depends what your hole saw is made of. A bimetal hole saw may struggle,a carbide one maybe not. I dont know if only the spokes are hardened. If the whole thing is hardened it could be a problem.
  13. #9
    JHB
    Thanked: 138
    You could try a jig saw with a steel blade.
    Or, you are welcome to bring it to me and we can machine it on my lathe. Im in Greenstone Hill, JHB
    2012 Bi Turbo 4Motion, on Bilsteins with a 50mm suspension lift and 20mm body lift. 76mm pipe and software.
  14. The Following 2 Users Say Thank You to JohnBoy For This Useful Post:
  15. #10
    Mar 2014
    Randburg
    Thanks for the replies. I guess the only way is a lathe, as I think this is beyond my limited tools and arm strength
  16. #11
    Thanked: 2459
    Lasercut
    Sent from my iPhone
  17. #12
    Thanked: 4514
    You won't get it accurate with a hole saw
    In a wooden block with the existing hole.
    Lathe is the only option.
    Why 46mm on 45 that is rattle fit. You need around 0.05mm for a secure fit
  18. #13
    durban
    Thanked: 1862
    It is unclear if the hole is just a clearance hole because then I would think it wont matter. He mentioned its not going to be attached to the hub, so maybe it just needs to fit over the hub. Obviously I may be way off here.
    If it isn't hardened then a hole saw would do it . I suspect the teeth would be induction hardened.
    If it is not overly hard I would set it up on a faceplate or 4 jaw and bore it. This could be done in many ways, annular cutter, hole saw lathe, milling machine with a boring head or slot drill using a rotary table or laser cut or wire cut using an EDM . Take your affordable pic
