Results 1 to 5 of 5
    Dec 2014
    Thanked: 2966
    Default Rover V8 question
    How would a "major oil leak" be a cause of head damage to a 3.9 engine?
    This Example
    Description by seller:
    Being sold as a non-runner. Although the car can be started and driven, a major oil leak has resulted in cylinder head damage. Being the 3.9-litre Rover engine found in a large number of Land Rover products, parts for this repair are readily available.
    From here...
    https://www.classiccarafrica.com/auctions/tvr-chimaera/
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
    Thanked: 7
    Default Re: Rover V8 question
    I guess if the oil supply to the rocker shafts is affected, therefore starving them of oil, that would qualify as head damage?
    Justus Immelman
    2001 Range Rover P38
    Ruimsig
    Thanked: 24245
    Lack of oil will degrade the pump capability starving the head components such as the rockers of lubrication. But I think the following could have happened, engine overheated due to coolant loss resulting in a warp in the head gasket pushing oil out between the head and block which might have appeared to be a major ''oil leak''. (Happened to me twice)
    However, with a lack of oil due to a leak or a pump problem, it wont just be the heads I would be worried about
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
    cape Town - 0624206806
    Thanked: 522
    The 3.9ís are known for cooking & cracking, but thatís the block not the heads..... you looking for another project or do you have a empty space in your driveway
    Dec 2014
    Thanked: 2966
    Hell no! My P6 is next in line.
    A friend was browsing the site and he fancies the car. Asked me what it could be and it has me stumped.
    I told him if he wants to buy it to go for it and then buy a 4.6 to fit in as it makes more sense to me.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  6. The Following User Says Thank You to JohnnoK For This Useful Post:
