Results 1 to 20 of 36
    Aug 2015
    Thanked: 187
    Default Two Random Useless or Useful Fun Questions
    1) What if the outside temperature is 4 degree centigrade and my camping fridge is set at 8 degree centigrade, will it run? If it does, why? To pour heat inside?
    2) Car alternator charges the main battery as well as secondary battery or batteries, which means bigger/stronger alternator is capable of charging bigger batteries. Why not use this approach to charge electric vehicle battery while driving? Say use petrol or diesel to start the car, then switch to electric, make the alternator still run, therefore charge battery while driving. Battery never dies...
    S-West/Stellenbosch
    Thanked: 81
    Red face Re: Two Random Useless or Useful Fun Questions
    I heard, day time drinking is posh if your rich and common if you are poor.
  3. The Following 7 Users Say Thank You to Serious? For This Useful Post:
    Feb 2013
    Thanked: 1277
    Default Re: Two Random Useless or Useful Fun Questions
    1. Just leave your fridge open.
    Your fridge is insulated from the outside, if its internal temp is at 8 it will switch off, if it rises above 8 it will switch on. Ultimately the compressor still regulates the inside temp, it is not regulated by the outside temp. Basically if you leave your fridge plugged out in this example it won't easily reach 4 degrees equal to the ambient temp due to the insulation unless of course you open it up.
    2. This is basically how hybrid vehicles work, like a Toyota Prius.
    "The problems we have today is because the guys who work for a living are outnumbered by those who vote for a living." - Magnus Heystek
    Jul 2014
    Thanked: 2006
    Hmmm if only we could figure out perpetual motion without losses
    Willem
    (workshop whore)
  6. The Following 5 Users Say Thank You to WAJ For This Useful Post:
    Thanked: 783
    Quote Originally Posted by Teryos View Post
    1. Take everything out of the fridge and put it outside.
    2. You won't have an full "electric" car anymore. But a hybrid.
    My ryding: 'n Ding met 4 rubber sirkels en n enjin wat nou en dan aangedryf word met al 4 sirkels
  8. The Following User Says Thank You to IcePick88 For This Useful Post:
  9. #6
    Polokwane
    Thanked: 822
    1. Your fridge will only start running once the inside temp raises above 8 regardless of what the outside temp is. If the outside temp stays on 4 and the inside temp is below 8 your battery will last along time
    2. Ok
    Conqueror Courage 2016
  10. #7
    Aug 2015
    Thanked: 187
    1. But how can it rise above 8 when ambient temperature is 4?
    2. facepalm
  11. #8
    Oct 2017
    Rustenburg
    Thanked: 7143
    Quote Originally Posted by IcePick88 View Post
    Point 1 is logical, it will maintain the temperature below 8 degrees, if the temperature inside goes above 8.. If not it wont switch on
    Point 2, you cannot generate more energy from energy used to move the car, iow to create the same amount of energy from an alternator connected to the electric motor, will require the alternator to generate the same amount of energy that the electric motor is making to turn the alternator, and the frictional losses and the energy to move the car..... and then even more to charge the battery...
    But most of all....You can only create energy, from energy... So somewhere you would need energy from the outside to overcome all the losses, and charge the battery
    Andrew van Staden
    I drive a fire engine red Cruiser and tow an army inspired van.
  12. #9
    Oct 2017
    Rustenburg
    Thanked: 7143
    2. facepalm
    By standing in the sun
    Andrew van Staden
  13. The Following User Says Thank You to Hedgehog For This Useful Post:
  14. #10
    Feb 2013
    Thanked: 1277
    2. facepalm
    If you put warm braaivleis in the fridge the temp will rise.
  15. #11
    Oct 2012
    Thanked: 329
    If you travel just faster than the speed of light, then switch on a torch, will you see the light?
    That Mighty Amarok
    Swart Tires wat ek self gekoop het
    Pull over wat my ouma gebrei het
    Vensters waar deur ek kan sien
    Engine voor
    Exhaust agter
  16. #12
    Oct 2017
    Rustenburg
    Thanked: 7143
    Quote Originally Posted by Snyks View Post
    Private message The Flash, he's here on the forum
    Andrew van Staden
  17. The Following User Says Thank You to Hedgehog For This Useful Post:
  18. #13
    Oct 2008
    Grabouw
    Thanked: 405
    1. Plug it into a Pajero. If that fails.
    2. Plug it into an Amarok.
    Barnie Hickman
    Jeep XJ 95 "Witblitz" Jeep XJ 99 "Goldi" Swambo's
  19. #14
    Oct 2017
    Rustenburg
    Thanked: 7143
    Quote Originally Posted by BarnieH View Post
    What is the question?
    Andrew van Staden
  20. #15
    Oct 2017
    Rustenburg
    Thanked: 7143
    Here are two from me;
    1. Eggs shells don't float and neither the broken egg, so why do whole eggs float?
    2. If water molecules condense to form ice, why is ice lighter than water?
    Andrew van Staden
  21. #16
    krugersdorp
    Thanked: 397
    yes
    theoretically it is possible to exceed speed of light.
    your example is same as :
    if i travel at say 100kph and trow a stone in same direction.
    will stone travel faster than 100kph?
  22. #17
    Thanked: 783
    Yes.
  23. #18
    Jan 2014
    Thanked: 227
    1. There is an air bubble in the egg.
    2. Ice is 9% less dense than water
    2018 Ford Everest XLT 3.2 4x4 Auto
    2013 Chevrolet Trailblazer 2.8 LTZ 4x4 MT (SOLD)
    Photography : https://500px.com/c0rn3llman5
    Youtube : https://www.youtube.com/channel/UCX4..._as=subscriber
    My girlfriend asked me to whisper 4 special words into her ear... so I said : "Ons gaan NOU braai!"
  24. The Following 2 Users Say Thank You to CornellMans For This Useful Post:
  25. #19
    Thanked: 783
    Quote Originally Posted by jadranko View Post
    yes
    Nothing with mass can go at the speed of light.
  26. The Following User Says Thank You to IcePick88 For This Useful Post:
    GKE
  27. #20
    Oct 2017
    Rustenburg
    Thanked: 7143
    Quote Originally Posted by CornellMans View Post
    Point 2 - I agree, but, why is it less dense if it is the "solid" state of water?
    Molten steel, is less dense than solid steel.. Why different with water?
    Andrew van Staden
