Results 1 to 20 of 82
    Jul 2020
    Thanked: 17
    Default The old 2.2 with hole in piston
    So die fordtjie het ons langs die pad gedrop oppad huis toe van vakansie af. Wit rook, rammel onder die bonnet. Kan iemand n goeie motor werktuig kundige aan beveel in die Pta noord area. Ons is in sinoville. Moord en roof, soek n arm en been om haar reg te maak, nuwe masjien blykbaar. Enige verwysings sal wardeer word. Name:  20210504_105043_HDR.jpg
  2. The Following User Says Thank You to Fomo For This Useful Post:
    Thanked: 1427
    Default Re: The old 2.2 with hole in piston
    Sterkte ou maat.
  4. The Following 2 Users Say Thank You to Spiceman For This Useful Post:
  5. #3
    Jul 2014
    Thanked: 2026
    Nicolaas Pretorius 0722426742 - hy is op 'n plot naby onderstepoort
    Eish ja dis eina, maar hoekom hoor ek SO baie van die gate in pistons op die nuwe fordjies?
    Iets is beslis af want dit net te veel plekke waar ek van mense hoor met die issue.
    Willem
    (workshop whore)
  6. The Following User Says Thank You to WAJ For This Useful Post:
  7. #4
    Aug 2020
    Oasis
    Thanked: 4297
    Het jy die Ford "gechip"?
    Willem Greyling
  8. #5
    Aug 2019
    Thanked: 327
    Quote Originally Posted by MANDREAS View Post
    Dit is meer as net n chip dit is n hele gat
  9. The Following 10 Users Say Thank You to Tiaan Pot For This Useful Post:
  10. #6
    Aug 2020
    Oasis
    Thanked: 4297
    Willem Greyling
  11. #7
    Jul 2020
    Thanked: 17
    Dit klink my is n probleem. Maak nie saak of jy 10km of 200 000 km op het nie. Myne het injector failure, en op hoe spoed en ekstra diesel tot pop sy.
  12. #8
    Jul 2020
    Thanked: 17
    Nope. Sy is was nog soos ge adverteer
  13. The Following User Says Thank You to Fomo For This Useful Post:
  14. #9
    Jul 2014
    Thanked: 2026
    Also contact Vision Motors 012 335 0070, located in Steve Biko road - they specialize in rebuilding Ford engines or exchange (perhaps not the cheapest, but surely they will be cheaper than the stealers).
    Willem
    (workshop whore)
  15. The Following User Says Thank You to WAJ For This Useful Post:
  16. #10
    Boksburg
    Thanked: 198
    Is hy uit waarborg uit?
    Selfde het met my gebeur op 210000km Injector failure gat deur piston maar ek het extended waarborg uit gehaal.
    Drikus Paulsen
    Trok: Ford Ranger 2.2 Xl-Plus aka RHINO sleep Echo Chobe.
  17. #11
    Jul 2020
    Thanked: 17
    Dankie. Ek sal hulle kontak.
  18. #12
    Jul 2020
    Thanked: 17
    Quote Originally Posted by Dp123 View Post
    Dp. Hy is 200km uit sy waarborg.
  19. #13
    Jan 2009
    Oral
    Thanked: 769
    Selfde met ons gebeur Desember.
    Almal met wie ons gepraat het het gese moenie aan die masjien probeer werk nie, sit 'n nuwe een in.
    Dit het in Namibia gebeur, en ek wil net so 'n klap inkry na Walvisbaai Ford toe, bly ver van hulle af weg, baie ver.
    So nou het ons 'n nuwe masjien in die bakkie. (ons het die bakkie huistoe gebring op 'n roll-back en die werk hier laat doen).
    Ons s'n het net 145 000 op die klok gehad, en hy is ook standaard.
    C
  20. #14
    Jul 2020
    Thanked: 17
    Quote Originally Posted by C Africa View Post
    C
    Glad nie lekker nie. Ons was darm nie sover nie, net buite Normandien. Nogsteeds n 10k trip met gesin van 4 terug PTA toe. Enigste ford wat by stop as ek probleme het daai kant van die grens is Novel Ford.
    Dit lyk vir my na die beste opsie tog maar n nuwe masjien in sit.
  21. #15
    Jul 2014
    Thanked: 2026
    Vraag is, hoe verhoed mens die soort ding? Ek hoor darm maar van baie gevalle. Hoe weet mens die injectors is nie lekker nie as die bakkie nog reg loop en lekker trek?
    My Broer het onlangs 'n "lowrider" 2,2 single cab werksdonkie low output ranger gekoop met iets soos 160,000 kilos al op.
    Al waarmee ek gesukkel het met my drie lieter T5 is die brieke en vibrasies en headgasket en wheel bearings en clutch.... baie betroubaar
    Willem
    (workshop whore)
  22. The Following User Says Thank You to WAJ For This Useful Post:
  23. #16
    Jul 2020
    Thanked: 17
    Daai is n goeie vraag. Hoe verhoed mens dit.
    Die slim mense daar buite reken die injectors moet elke 60 000km ge toets word. Ek het dit laat toets op die 120k diens. En 200km later........
    Die snaakse deel van als vir my, daar het nie een liggie op die dash aan gekom nie. En ek het hom vir n laaste keer gestart voor Ford se deure en nog steeds geen waarskuwing nie.
    Die masjien wat hulle in geprop het by ford, kon nie een keer die selfde fault code gee nie. Elke keer iets anders fout.
    Is my 3de een. Dalk tog maar die laaste een.
  24. #17
    Langs die rivier, op n berg
    Thanked: 3931
    200km uit waarborg, of 200 000km uit waarborg?
  25. #18
    Jul 2020
    Thanked: 17
    Net 200.
  26. #19
    Stilbaai
    Thanked: 107
    Dieselfde het met my gebeur met my (gewese) Nissan Pathfinder op 105k km. Enjin is herbou deur die sg beste enjinherbouers in George en is daarna vyf keer terug op 'n trok met groot probleme. Na ses maande en minder as 10k km was ses maande waarborg verby toe hy finaal breek en hulle hulle hande in onskuld was. Ek moes hom feitlik verniet weggee.
    Vind uit wat kos 'n nuwe enjin by Ford, hulle word in PE gemaak en was laas wat ek gesien het, goedkoper as om die enjin te herbou.
    Nes die 2.5 Nissan enjin is die 2.2 Ford enjin 'n baie goeie enjin en ek weet van baie wat hoŽ km's gee sonder probleme. In my geval was een van die moonlikhede wat gegee is dat hulle besoedelde diesel in Transkei in die Pathfinder gegooi het. (Dit het tussen Umtata en Butterworth gebeur nadat ek in Port St Johns volgemaak het).
    Ek het dus twyfel in my gemoed of die hedendaagse verfynde diesels regtig suksesvol herbou kan word.
    Danie Gerryts
    2013 Nissan Patrol 4.8 GRX A/T
    2016 Ford Ranger 3.2TDCi 4x4 A/T Supercab
    Gypsey 5
    Jurgens Xplorer
  27. #20
    Planet of the Apes
    Thanked: 325
    Quote Originally Posted by DanieG View Post
    Kan een tenk diesel "catastrophic failure" veroorsaak?
