Results 1 to 20 of 84
    Apr 2011
    Thanked: 85
    Default Portable Lithium Box
    I am on the brink of a Battery Box Build - Everlasting Excitement! (Or just BBB-EE). I started off by reading everything I could lay my hands on for about a year, then went into shopping mode.
    I purchased a 108ah Blue Nova lifepo4, a Victron Orion 12 12 30 dc-to-dc, a Victron SmartSolar MPPT 100/15 pv-to-dc, a Victron IP65 15amp ac-to-dc, a Victron Phoenix 500va inverter, a Victron BMV 712, a Badger 6-way blade fuse splitter, cable, cable cutter, lugs, Victron battery switch, midi fuses, a hex crimper, and perhaps even some other stuff.
    I have three boxes full of goodies, screaming to be assembled, and I am procrastinating (I am a procrastinator).
    I proposed, to myself, and then accepted my proposal, that the battery box will contain the battery (this was an easy decision), all load ouput devices (including the Phoenix), the BMV, output Anderson and various dc sockets, the Badger splitter, and Anderson connectors for the three load input devices.
    These latter three items will reside outside the box, each in their appropriate environment, the Orion in the bakkie, the IP65 wherever a dc source is, the MPPT wherever the box is within 15m of sun.
    The box will be used to service our (SWAMBO and I only) bakkie camping requirements, as well as our loadshed tv, dstv and pc requirements (fervently hoping that a 400w inverter is up to this).
    For info, we are both (just) on the far side of 60, and are gently entering the camping game. I traded my 10 year old Disco 4 V8 for a new Legend 50 2.8 Extra Cab during the discount madness last year when the new Hilux was on the horizon. I have a Metallian canopy, and the box will go in there. We run a 40l Engel fridge, and have no fancy requirements.
    That's the background, and I have a ton of questions before I start the build, which will be documented, and perhaps turned into a major movie starring Brad Pitt and Jennifer Anniston.
    Leon Smith
    2020 Toyota Hilux XtraCab 2.8 4x4
    Fiat 500 0.9l turbo flattie
  2. The Following 5 Users Say Thank You to leons For This Useful Post:
    Apr 2011
    Thanked: 85
    Default Re: Portable Lithium Box
    Here are the Victron components:
    Leon Smith
  4. The Following User Says Thank You to leons For This Useful Post:
  5. #3
    Apr 2011
    Thanked: 85
    The Anderson plugs and housing, busbars and isolators, and blade-fuse splitter:
    Leon Smith
  6. The Following User Says Thank You to leons For This Useful Post:
  7. #4
    Apr 2011
    Thanked: 85
    Cable, accessories and and tools:
    Leon Smith
  8. The Following User Says Thank You to leons For This Useful Post:
  9. #5
    Apr 2011
    Thanked: 85
    And beating heart:
    Leon Smith
  10. The Following 2 Users Say Thank You to leons For This Useful Post:
  11. #6
    Apr 2011
    Thanked: 85
    My first question: must the output from the inverter go through a circuit breaker before terminating at a socket? Why, and what? Thanks!
    Leon Smith
  12. #7
    Apr 2011
    Thanked: 85
    My second question: what must I do with the earth connection (bottom right)? All negative wires return to their respective originating component.
    Leon Smith
  13. #8
    Jun 2015
    Pretoria East
    Thanked: 1172
    Subscribed. Looking forward to your build.
    I have a similar project in mind, with the below in mind (I already have this in the Hilux semi-fixed).
    200AH LiFePo4
    Victron Orion Tr Smart 12/30
    Victron 75/15 MPPT solar controller
    BMV 712
    Victron Phoenix Inverter 12/500
    My idea is to include the battery, all wiring and fuse box inside, with the Orion and MPPT on the outside. The Orion especially needs ventilation and I don't want the heat to be transmitted to the battery. I will treat the Victron Phoenix 500VA separately not to make the box too heavy.
    The idea of the Box is to easily transfer this between Hilux and FJ. The long-term plan is to add solar blankets, but these are still quite expensive and I have many panels at home.
    Dirk Theron - Life's a journey, enjoy the ride!
    18 Land Cruiser FJ - build to play
    19 Hilux 2.8 GD-6 Auto 4x4 - my best overland build ever
    2013 LC 200 4.6 Petrol V8 - Ex. The best car I have owned, apart from its thirst
    2014 LC 79 V8 - Ex
    2001 LC 105 4.5 EFI - Ex
    2013 FJ Cruiser - Ex
    1996 LC 80 UK spec VX 4.5 EFI auto - Ex
    2001 Jeep TJ 4L - Ex
    2006 Jeep Cherokee - Ex
    1989 LC Bundera 1KZ-TE 3L auto - Ex
    1996 Nissan Sani DC 4x4 - Ex
  14. The Following User Says Thank You to DCTheron For This Useful Post:
  15. #9
    Bellville
    Hi Leons,
    Regarding your second question, you can have a look on Victron's website (https://www.victronenergy.com/invert...tem-schematics) where they provide possible installation schematics, showing all the cable runs.
    '15 Opel Platkar
    '12 Triton 3.2 DID D/cab 4x4 - sadly sold and dearly missed
  16. The Following 2 Users Say Thank You to SmileyMe For This Useful Post:
  17. #10
    Thanked: 1207
    Quote Originally Posted by leons View Post
    Page 1 of manual says:
    The AC output is isolated from the DC input and the chassis. Local regulations may require a true neutral. In this case one of the AC output wires must be connected to the chassis, and the chassis must be connected to a reliable ground. Please note that a true neutral is needed to ensure correct operation of an earth leakage circuit breaker.
    See Pages 12-13 of the manual.
    https://www.victronenergy.com/upload...R-DE-ES-IT.pdf
    Political Correctness
  18. The Following User Says Thank You to the_terrible_triplett For This Useful Post:
  19. #11
    Apr 2011
    Thanked: 85
    Thanks for this Dirk. You've made me consider a small design tweak to make the the upper box (with inverter) a detachable part of the lower one.
    Would you connect the two with an Anderson connector?
    Leon Smith
  20. #12
    Apr 2011
    Thanked: 85
    Thanks The_Terrible_Triplett. Does this mean that the portability of such a box is limited by a physical copper cable connection from AC output to a physical part of the chassis of the bakkie?
    Leon Smith
  21. #13
    Hillcrest
    Thanked: 7919
    This is DANGEROUS territory. VERY.
    If the battery box is going to be used in a vehicle or a trailer/camper, in other words mobile. DO NOT CONNECT any of the two 230V AC outputs to anything. No earth, no bat neg, no campsite Neutral/Earth, niks, nada. The should stay floating relative to the real world and the whole normal concept of L-N-E with Earth Leakage goes flying out the door.
    The inverter output should only be connected to the appliance/appliances that it is going to be driving. And even then these should preferably be double insulated 2 Pin appliances.
    At home, don't connect to the DB board. If you do, get an electrician to do it for you and issue a COC. At home treat it like a camping system. ie plug your appliances directly into the inverter. (via an extension card if necessary.
    Disclaimer - This is what I would do, proceed at your own peril.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  22. The Following 10 Users Say Thank You to Fluffy For This Useful Post:
  23. #14
    Jun 2015
    Pretoria East
    Thanked: 1172
    If one do the sums then yes an Anderson will work, i.e 500VA / 12V = ~42A and the Anderson plug is rated 50A.
    2014 LC 79 V8 - Ex
  24. The Following User Says Thank You to DCTheron For This Useful Post:
  25. #15
    Jun 2015
    Pretoria East
    Thanked: 1172
    This is exactly what I do.
    Added: I only use the inverter whilst stationary to charge various batteries (radio, cellphones, etc) for instance. Thick and short cables from aux battery to inverter, from there a short AC lead.
    2014 LC 79 V8 - Ex
  26. The Following 3 Users Say Thank You to DCTheron For This Useful Post:
  27. #16
    Hillcrest
    Thanked: 7919
    Problems like the above send cold shivers up my spine, and are why I am rather against Mains Inverters in portable systems. With these systems, the whole concept of L - E - N flies out the door. Both connections are neither Live nor Neutral. OR alternatively both are live, depends how you look at it.
    The 230V AC's relationship to Earth or Ground depends on the Inverters architecture. Depending of the manufacturer, the mains can be truly floating, established by galvanic isolation components inside, or one of the mains leads may be "tied" to battery Pos or Neg. Chassis or ground is anybodies guess.
    The main problem comes in when there is a fault somewhere, usually in the wiring or an appliance. You really dont want to be in a vehicle where the vehicle is connected to one of the mains connections and the body of a kettle connected to the other. This is the sort of thing that can happen when a metal kettles element goes faulty, hence my advise previously on only double insulated appliances (ie plastic kettle)
    ZS5KAD
    3 Land Rover V8's
  28. The Following 2 Users Say Thank You to Fluffy For This Useful Post:
  29. #17
    Thanked: 1207
    What Fluffy said.
    Fixed installation, my bad, was meant to be at home as a off-grid setup, permanently set up, being a Phoenix.
    Vehicles, Victron have schematic for vehicle installs.
    https://www.victronenergy.com/upload...D-INVERTER.pdf
    https://community.victronenergy.com/...c-drawing.html
    https://www.victronenergy.com/blog/2...n-van-install/
    Ideally you want to speak to a Victron installer, 4x4 electrical installer, that knows all the ins and outs of Victron and vehicle installs.
  30. The Following 2 Users Say Thank You to the_terrible_triplett For This Useful Post:
  31. #18
    Apr 2011
    Thanked: 85
    Thank you very much Fluffy! This is exactly what I'll do. And you're quite right, I do wish to treat loadshedding as another camping exercise. The box will not be anywhere near mains, but parked next to the TV as if in a tent. I really don't understand AC L-N-E and leakage, and would very much like to read up more about it. Do you have any suggestions for a dummy's guide?
    Leon Smith
  32. #19
    May 2007
    Lonehill
    Thanked: 30
    My design with similar components. All on the box excluding Orion DCDC.
    All chargers +ve to the battery +ve via fuse
    All loads from Out on battery protect ( including Phoenix remote supply which will disconnect inverter via remote - Phoenix must be connected directly to battery not Battery protect).
    All -ve to Smartshunt Out.
    VE Connect Smart Dongle to Phoenix for VE connect
    Fun project - I used marine ply.
ID:	614565   Click image for larger version.
ID:	614566   Click image for larger version.
ID:	614567   Click image for larger version.
ID:	614568   Click image for larger version.
  33. The Following 7 Users Say Thank You to Rain Hard For This Useful Post:
  34. #20
    Apr 2011
    Thanked: 85
    Thanks Rain Hard. That's a nice looking box, well put together.
    What does VE direct do? Is it the box next to the shunt?
    Also, I see you're using one of the remote switch connections on the Phoenix. How does that work?
    Leon Smith
