Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 61 to 80 of 84
  1. #61
    JHB
    Thanked: 226
    Default Re: Portable Lithium Box
    Very neat and elegant. Well done!
  2. The Following User Says Thank You to Woolf For This Useful Post:
  3. #62
    Jun 2015
    Pretoria East
    Thanked: 1172
    Regarding those air compressors….
    With my Victron setup it is easy to check and I was quite shocked to see my ARB compressor draws 34A.
    Dirk Theron - Life's a journey, enjoy the ride!
    ‘18 Land Cruiser FJ - build to play
    ‘19 Hilux 2.8 GD-6 Auto 4x4 - my best overland build ever
    2013 LC 200 4.6 Petrol V8 - Ex. The best car I have owned, apart from its thirst
    2014 LC 79 V8 - Ex
    2001 LC 105 4.5 EFI - Ex
    2013 FJ Cruiser - Ex
    1996 LC 80 UK spec VX 4.5 EFI auto - Ex
    2001 Jeep TJ 4L - Ex
    2006 Jeep Cherokee - Ex
    1989 LC Bundera 1KZ-TE 3L auto - Ex
    1996 Nissan Sani DC 4x4 - Ex
  4. #63
    Apr 2011
    Thanked: 85
    Thanks Woolf! I learnt a lot and had great fun. Of course, the motivation to build a box like this needs investigation.
    Is it "better" to purchase a National Luna box with everything? Or "black box" units like Hcdp, Wrnd or National Luna? It's probably cheaper, smaller, neater. I don't know. But this is very satisfying!
    Leon Smith
    2020 Toyota Hilux XtraCab 2.8 4x4
    Fiat 500 0.9l turbo flattie
  5. #64
    Apr 2011
    Thanked: 85
    Wow, that's a large draw! It makes sense to rather run it off an idling crank battery (alternator).
    Which ARB model is that?
    Leon Smith
  6. #65
    JHB
    Thanked: 226
    That’s why it comes fitted with a 40A fuse
  7. #66
    Apr 2011
    Thanked: 85
    Yes, there's no doubt about its safety. Just a heads-up when considering large draw items.
    Leon Smith
  8. #67
    Oct 2018
    Magaliesig
    Thanked: 701
    Quote Originally Posted by DCTheron View Post
    Mine draws about the same (from the manual), which is why I have it on a separate 50A circuit... And I run it off my aux battery
    Rob Kirk
    Amarok V6.
    Sym 200 scooter 2 x 1, CVT transmission, 4V OHC, 11.4 kW, 15NM
    0-60km/h in about 10s (downhill), Top speed - 100km/h (on a steeper downhill)
    Ground clearance : 125mm on 16-inch rims
    Tare : 134kg, GVM : 250kg (approx), GCM : 250kg (approx), Towing capacity : 0kg
    Best of all : 4L/100km, town driving and pinning it...
  9. #68
    Oct 2018
    Magaliesig
    Thanked: 701
    Leon, as promised, a pic of my setup, going the "DB board" route as opposed to a box. Yes, it is less portable, but seeing as I may only be camping 3-4 times per year, it is "reasonably portable" if I wanted to unbolt it and use it for loadshedding. The solar panels might be awkward (but not impossible) to set up in my garden; or I can purchase a 220V LiFePO4 charger.
    Next to the switchbox is the blue BH connector for the solar panels. Underneath the switchbox (red plastic square) are my strip fuses, just as extra protection to the DC circuit breakers which are housed in the switch box. Copper lugs (plumber's copper pipe) can be seen to the right of the fuse box (positive) and to the left above the black sockets (negative) to which I attach my compressor. Sockets are 1 x dual USB and two cigarette lighter sockets. My LED lights run off one of the cigarette lighter sockets. The fridge runs off a BH connector mounted on the back of the DB board, just above the left copper lug. Those are the two lonely bolts poking through.
    Circuit breakers inside the switchbox, left - right are: Load, PV input, Battery and Compressor. Battery can be seen held down by turnbuckles at the bottom, and the compressor sits conveniently positioned on the wooden "bridge". I have a small (300W) inverter that I will need to use to charge my radio (has no car charger, only 220V) , which I will mount most probably top left of the board.
    Seeing as everything is mounted up against the bulkhead, it takes up more space than a box, but is not too much in the way. I'm not a great craftsman, so everything is functional rather than "neat". Also, cabling is reasonably accessible (on the back) to troubleshoot.
    FWIW...
    Rob Kirk
    Amarok V6.
  10. #69
    Apr 2011
    Thanked: 85
    Thanks for the pics Rob. That setup looks perfectly functional, and obviously serves your needs. I like the vertical stack. I think it takes up less space than a box, and everything is visible. I particularly like your very practical compressor lugs . Well done!
    Leon Smith
  11. The Following User Says Thank You to leons For This Useful Post:
  12. #70
    Oct 2018
    Magaliesig
    Thanked: 701
    Thanks, Leon. Wherever possible I hate cutting cables; the lugs make it easy to use the supplied crocodile clips on the compressor.
    Rob Kirk
    Amarok V6.
  13. #71
    Apr 2011
    Thanked: 85
    The battery box is fully built, and now sports a cigar plug, a hella plug and a dual USB. These appear to be de rigueur for the modern, well-dressed battery box.
    As a loadshed-buster, the box is a screaming success:
    Here are the consumption figures for our TV station:
    1. Inverter only: 9W
    2. And TV: 70 W, 5.3 amp
    3. And Chromecast: 73W, 5.5 amp
    4. And Explora: 90W, 6.9 amp
    5. And amplifier: 105W, 8 amp
    6. And DVD: 116W, 8.8 amp
    That means I can still plug in my Dell XPS 13 (60 W while charging and working), and even the Engel (40W) in an emergency, without coming close to hurting the 400W Phoenix.
    Leon Smith
  14. The Following 6 Users Say Thank You to leons For This Useful Post:
  15. #72
    Thanked: 185
    Very, very nice and neat Leon. Looks like the work of a true craftsman.
    I'm curious as to what adapter you are using for the schuko socket on your inverter? They're quite hard to find.
    I have one of these which is working well so far:
    https://www.stepbuildingsupplies.co....gle%20Shopping
    Stuart
    2006 Toyota Land Cruiser 100 4.7L V8
  16. #73
    Apr 2011
    Thanked: 85
    Quote Originally Posted by slodj View Post
    Hi Stuart, and thanks for the kind words. It was a nice project to learn a bit more about the mysteries of electricity!
    I made up a little cheapy lead in the interim, with a male Schuko from ACDC.
    I must say, the standard of electrical fittings is quite low generally. I have yet to find a shop that provides a wide range of quality fittings in Cape Town, and it's very frustrating. I'm going to build a portable box for the inverter, and will post here what I come up with.
    Leon Smith
  17. The Following User Says Thank You to leons For This Useful Post:
  18. #74
    JHB
    Thanked: 226
    Electric lawnmowers use Shuko's. Most bigger hardware shops have replacement plugs
  19. The Following 3 Users Say Thank You to Woolf For This Useful Post:
  20. #75
    Thanked: 990
    I used one of these SA sockets. It splits in 2 halves. One on either side of the front plate. They are sold by AC/DC. No need then for any adaptor.
  21. The Following 2 Users Say Thank You to ekkekan For This Useful Post:
  22. #76
    Hillcrest
    Thanked: 7919
    Quote Originally Posted by Woolf View Post
    I haven’t seen them in a hardware store for a looong time. They usually come as moulded plugs with the lead.
    I suspect they may even be illegal to sell.
    Available from RS Components and Communica.
    ZS5KAD
    3 Land Rover V8's
    NA - TwinTurbo - SuperCharged
    A V6 and an inline 4
  23. The Following User Says Thank You to Fluffy For This Useful Post:
  24. #77
    Apr 2011
    Thanked: 85
    Thanks Fluffy. I found a good Schuko lead at Linkqage in Cape Town.
    They also had a supply of RJ12 plugs, thank goodness.
    I shortened my 500km long BMV-712 data cable down to 1m. Here's the Victron pattern, in case it's non-standard:
    Leon Smith
  25. The Following 2 Users Say Thank You to leons For This Useful Post:
  26. #78
    May 2007
    Lonehill
    Thanked: 30
    https://www.rabtron.co.za/140-ac-iec-power-connectors
  27. The Following User Says Thank You to Rain Hard For This Useful Post:
  28. #79
    Thanked: 963
    Quote Originally Posted by leons View Post
    Thanks for this, been meaning to shorten mine as well.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
  29. The Following User Says Thank You to Die SwartKat For This Useful Post:
  30. #80
    Apr 2011
    Thanked: 85
    Makes such a difference to an already cluttered space!
    Leon Smith
