There are very conflicting information out there on the web, and basically because most of the info on the web, is coming from the USA and they have a very different model line up to us.
So here goes:
We have only one model in our line up. What is our model's specs with regard to knoppies?
It has knoppies
Who has done a suspension lift on it and why?
Never had the need for a lift as my tyres were always standard
I would consider upgrading the shocks after 50k imo the stock shocks are weak and don't last.....go for a Bilstein or the like.
What suspension lift works best in your opinion? (If you keep the tyre
SIZE stock)
depends on intended use imo
What is the radio like and what does it feature? (Hands free, blue tooth, voice activation etc?)
The head unit sound quality is pretty good, the only sound improvement needed is an amp, speakers and sound deadening, I really didn't need a bigger color screen, CarPlay etc...so purely a sound upgrade was all i needed, it cost a bit but sounds superb!!
Can it tow a trailer like the Comfort? (Have you towed with it and what?)
No problem but its no diesel, ive towed my boat plenty (1.5T)
Leave it in D and go, only use the cruise control if its very flat.
What kind of tow hitch does Toyota fit? (Removable or fixed)
all have been Toyota fitted removable.
Does the rear suspension cope with a trailer of that size?
No problem, even towed a mates boat with a 140kg ball weight and it coped.
That said having a shortish wheelbase it porpoises a bit, airbags could help.
I see there are more than 130 FJ owners on this forum so please share your experiences.
Thanks!!
