Results 1 to 17 of 17
    Feb 2015
    Thanked: 11
    Default 300Tdi Oil Pressure light flickering
    Went on a long trip and when stopping at the offramp at idle the oil pressure light flickers. By increasing the idle speed marginally the light goes out. Once off the highway and driving around town slowly the light no longer flickers at idle.
    What could the problem be?
    Jan 2020
    Thanked: 130
    Default Re: 300Tdi Oil Pressure light flickering
    How many kms on the clock and also how long since last oil change. Is the temp staying normal. Best bet would be to do an oil and filter change. See if that sorts it out.
    Feb 2015
    Thanked: 11
    218 000km and did an oil and filter change less than 500km back. Did change oil brand but same viscosity. Worth changing back to original oil brand?
    Jan 2020
    Thanked: 130
    Yes might be good idea. I have Mazda 2 5tdi with 240k on clock and Prado Kzte with 220k on clock. Change oil and filters at 10k intervals and use Castrol GTD oil. Never an issue so far.
    Thanked: 209
    i have had the oil pressure sensor fail on mine before
    same systems as you mention
    easy to replace to see if that's the problem
    but don't ignore this issue
    Thanked: 3543
    Check whether the oil light takes longer than usual to go out when starting up - especially from cold.
    This might be something small like the sensor or maybe the oil itself, but it could also be your oil pump on its way out - which could cost you an engine. Although a 300tdi with that on the clock should not normally have oil pump issues
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
    Feb 2015
    Thanked: 11
    I acknowledge there are many variables which influence this but what sort of mileage can one expect from the 300 Tdi motor assuming it is properly maintained.
    Apr 2019
    Thanked: 2041
    Quote Originally Posted by thujack View Post
    Mine is purring nicely - 390,000km
    Thanked: 3543
    My Disco Tdi is sitting on 355 000
    My Defender Tdi is sitting on 578 000
    Both engines unopened, Disco just got a new lift pump, Defender has had new injectors fitted and the diesel pump overhauled.
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
  10. The Following User Says Thank You to EttiennedK For This Useful Post:
    Feb 2015
    Thanked: 11
    At what mileage did you do the injectors and pump?
    Oct 2018
    Pinelands
    Thanked: 31
    My oil light switch did the same the other day and was a cheap fix instead of what it could have been.
    Thanked: 3543
    About 500 000 - was still fine up to then but filled up at a filling station that had had their tanks contaminated by water. Cleaned and flushed and it ran perfectly. Did the work pro-actively as it is used daily for work purposes.
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
    Jan 2007
    Thanked: 50
    The flickering of oil light happened a couple of times in my tdi's life, exactly as you said....when getting off highway and idling. Always been the oil sender switch which caused it. Bought an original sender last time and haven't had the issue for some years.
  15. #14
    Melkbosstrand
    Thanked: 450
    I've had this twice before
    First time was sensor busy failing. I think it's about R130 or so
    Second time was turbo about to go. It got gradually worse then she started using oil. New turbo core was under 2k
    Rob
    Disco 2 ES TD5. Custom map, V8 TC
    Disco 1 ES 300TDi
    Series IIA 88" pickup
    Subaru impreza WRX
    Porsche Boxster S
    Shamrock Cobra 350
    Buell XB12R
  16. The Following User Says Thank You to Hagu13 For This Useful Post:
  17. #15
    May 2018
    Brisbane
    Thanked: 31
    I always get accused of thinking the worse so, take that into consideration but I'd be getting my oil pressure checked. Of course you need to do it while hot and at both revving and at idle.
    It may well be all of the things mentioned in the above posts but, it could also be one bearing that has worn out.
    I just reconditioned my engine. A 300tdi.
    A few months before I did the rebuild, I blew the head gasket going up a hill and of course it overheated. I repaired the head and gasket but I eventually got a big end knock about 2 thousand K's later.
    Upon dismantling and inspection, it was obvious that the big end bearing on Number 4 was worn through pretty badly and I think it was because of the overheating episode. The other 3 weren't too bad.
    There's a theory around, that once the oil pressure drops on these engines through age or whatever, the bearing in Number 4 is starved for oil. I don't know enough to KNOW that this is fact but in theory, it does make sense.
    Good luck!!
  18. The Following User Says Thank You to Peppercorn For This Useful Post:
  19. #16
    B-gowrie Randburg
    Thanked: 387
    ... on a TD5 the oil P sensor sits on the flange mounting of the oil filter ... (below the turbo) and not far from the hot stuff like exhaust manifold , pipe etc ... would need check wire is not de-insulated & shorting against anything hot...
    ... not sure of location/setting of sensor for Tdi ... ?
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    1975 Series3 88 PUP :
    Simply ... Classic ...
    2017 Metalian Mini ...
    A Home from Home
  20. #17
    Thanked: 209
    tdi on the opposite side to turbo
    to me a silly idea to put electric cable near a turbo
  21. The Following 2 Users Say Thank You to RossJ For This Useful Post:
