Results 1 to 3 of 3
    May 2013
    Thanked: 9
    Default Fortuner 2.8GD6 Brake Booster Recall
    Received a call from the dealer advising my 2019 Fortuner has had a recall to replace the brake booster.
    McCarthy Bruma carried out the work under warranty. Just over R4k but happily under warranty.
    May 2007
    Durbanville Cape Town
    Thanked: 119
    Default Re: Fortuner 2.8GD6 Brake Booster Recall
    Checked my 2018 via dealer friend and it’s not on the list, apparently only the newer models
  3. The Following User Says Thank You to bees For This Useful Post:
    Jan 2019
    Otjiwarongo
    Thanked: 366
    Hiluxe and Fortuners manufactured from 08/2018 to 03/2019 are affected, but only a certain batch needs to be replaced. The Dealer will first inspect the Serialnumber to see if the recall needs to be done or not!
    Jörg Reddig
    1995 Discovery V8 ( Thor intake system , controlled by Spitronics Mercury 2)
    Land Rover 3.9 V8 " Defender 90 " Under Construction
    2021 Hilux Legend D/CAB ( Company Vehicle)
  5. The Following User Says Thank You to JWR For This Useful Post:
