Results 1 to 20 of 34
Thread: D4 Reliability
    Default D4 Reliability
    Hi all,
    Just a general question, nothing on the vehicle has been repaired/replaced mechanically and has FSH with agents. Low mileage (<90000km) vehicle and generally in very good condition.
    Is there anything I should be aware of? Check?
    Appreciate the assistance
    2017 FORD RANGER WILDTRAK 4X4 AUTO
    2015 LAND ROVER D4 HSE
    2013 Suzuki Jimny - "Suzie Q" - SOLD
    Gqeberha
    Thanked: 5056
    Default Re: D4 Reliability
    Year?
    Petrol/Diesel?
    Year - 2015
    Diesel (SDV6)
    Thanked: 789
    At that distance mine (2010) required lower wishbone bushes.
    Replaced again at 180k km's.
    Only repairs was a diesel filter housing and coolant reservoir due to faulty sensors.
    Suspect a sticky front caliper due to uneven pad wear on RH front at the moment, currently just shy of 200k km's.
  5. The Following User Says Thank You to faniedup For This Useful Post:
    So in general, they not as unreliable as made to believe?
    Thanked: 1242
    Quote Originally Posted by freewheeler View Post
    You have the can opener in your hand I see
    FJC - Just Cruising
  8. The Following 3 Users Say Thank You to dirtshark For This Useful Post:
    Jan 2009
    Potchefstroom
    Thanked: 403
    Quote Originally Posted by dirtshark View Post
    And once those worms are out...
    Joburg
    Thanked: 499
    Correct!
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Range Rover 4.4 V8 sold
    Audi A3T sold
  11. The Following 4 Users Say Thank You to Beesblaas For This Useful Post:
  12. #9
    Sandton
    Thanked: 94
    Correct!
    Cam belt should be done after 7 years plus plastic water manifold. Some indies recommend replacing both water pump and oil pump at the same time - up to you and your indie.
    Mine is a 2013 model and apart from above needed lower control arms at 90 000. Nothing else has gone wrong.
    2013 Discovery 4 SDV6S
    2008 Discovery 3 TDV6S (SWAMBO)
    Imagine Comfortvan
  13. The Following User Says Thank You to Cecilh For This Useful Post:
  14. #10
    Thanked: 9
    I have come to realise that the MOST opinions relating to the unreliability of these vehicles are from hearsay, i.e. people who have never owned one.
    2011 RRS HSE Lux
    2002 Disco 2 Td5 GS A/T
  15. The Following 4 Users Say Thank You to Skippr For This Useful Post:
  16. #11
    Joburg
    Thanked: 499
    Quote Originally Posted by Skippr View Post
    100% In 20 years of owning a Series3, Defender, RR and Discovery I have never had a breakdown. All my Landyís were/is high mileage and I have only had to replace wear and tear items.
    If all these vehicles were so unreliable I must be the luckiest man alive.
    Discovery 3 V8 HSE
    Defender 90 2.8i
    Audi SQ5 Tdi
    Audi A3T sold
  17. The Following 3 Users Say Thank You to Beesblaas For This Useful Post:
  18. #12
    Thanked: 3825
    A WK, XJ and a Ducati...
  19. #13
    Apr 2019
    Thanked: 1974
    The plastic water manifold is a big deal. It should be replaced at 100k and every 100k.
    Ours have not been problem free. We have had three "serious" issues in three years of owning two.
    2017 SDV6 on about 85K:
    - Incorrectly installed diesel fuel filter (by LR Waterford) came "loose" about 2,000 km after service was done, leading to a major fuel leak. As car as under service plan, just had them come and get it and fix it. Handled promptly and professionally. Happened locally. Would have been rather irritating in Bots or something but i do carry a spare filter.
    2012 SDV6 on about 255,000k:
    - Plastic water manifold exploded, causing complete cooling loss but fortunately no engine damage - resulted in towing
    - Electric parking brake failed to disengage, back up cable release failed to disengage, had to leave car overnight (on sani pass no less), EPB released next morning. Had plastic!!!!! gears replaced with bronze after market, no further issues.
    Maintenance:
    - Transfer case rebuilt
    - Air suspension compressor replaced
    - Transmission serviced by ZF - due to shudder and wear
    - Replaced water pump proactively
    - Car now in for possible turbo rebuild or exhaust manifold gasket leak
    The 2012 gets heavy use offroad, trails, etc..., and also has pulled a caravan for about 20k over the past couple years.
    All in all, the "left on the side of the road" across the two vehicles has not been bad, has not been perfect. The maintenance, I think considering age and complexity of the vehicle, has been reasonable.
    The 2017 was bought "nearly new" so about 70k driven by me. The 2012 was bought with 180k on, so 70k on that one as well driven by me - 140k on the two vehicles combined in just under 3 years.
    Both have been well maintained - the 2017 by LR, and the 2012 since I've owned it by Overlandworks, and had a full LR service history when I bought it.
    A very capable, and very comfortable, car. Beats a Yota every day of the week. The only vehicle I'd entertain as an alternative is a Patrol, just because I think they are really cool.
  20. The Following 3 Users Say Thank You to heyyahhey For This Useful Post:
  21. #14
    Jan 2007
    Thanked: 381
    Mine is a 2017 and it is on 90k km. We've replaced the compressor for the air suspension.
    Was going to sell it a while back, but decided to hang on to it, as there is just nothing out there that ticks all our boxes like the D4 does.
  22. #15
    Ruimsig
    Thanked: 22792
    You can work it out yourself
    The Mean Time Between Failures (MTBF) = Total Kms/Total Failures
    Failure Rate = 1/MTBF
    Mean Time To Repair (MTTR) = Total Hours of Maintenance/Total Number of Repairs
    Mean Time To Fail = 1/Failure Rate
    Availability = MTBF/MTBF+MTTR
    Estee = S T = Sean Towlson
    Hummer H3 V8
    W.A.P Objectivist
  23. #16
    Apr 2019
    Thanked: 1974
    Out of curiosity- how has that H3 treated you? I always liked the H2 - donít think it would work on some of the trails around here though
  24. #17
    Ruimsig
    Thanked: 22792
    In two years of ownership it has only been serviced according to manufacturers specification. It remains solid, no rattles or squeaks considering it is a 2009 model. It has comparable technical specs to the Jeep Rubicon, sans the SFA which is a pity and handles touring and trails quite well thank you
    It is cramped though compared to the LRs, not from a drivers perspective though and handles long distance cruising like a well manufactured saloon car. However, the sound system becomes painful when the base achieves harmonic resonance with the exhaust
    However, fuel costs have probably exceeded the total breakdown and repair costs of all of my LRs since 1997
    Hummer H3 V8
    W.A.P Objectivist
  25. The Following 3 Users Say Thank You to Estee For This Useful Post:
  26. #18
    Ruimsig
    Thanked: 22792
    The irony though.
    A Janqui driving and waxing lyrical over a Limey vehicle and a Limey driving and waxing lyrical over a Janqui vehicle
    Hummer H3 V8
    W.A.P Objectivist
  27. The Following 3 Users Say Thank You to Estee For This Useful Post:
  28. #19
    Apr 2019
    Thanked: 1974
    The irony though.
    I like the GMs a lot - Tahoe and Suburban and the 1500 and 2500 Pickups. But yep those V8s like to drink. Worth it.
  29. The Following User Says Thank You to heyyahhey For This Useful Post:
  30. #20
    Ruimsig
    Thanked: 22792
    PS: remember the mean time is in kilometers.
    Hummer H3 V8
    W.A.P Objectivist
