Results 1 to 13 of 13
    Apr 2021
    Craighall Park
    Default Need advice on rebuilding FJ62 transfer box and propshafts
    Morning, new member Paul Ash here. I own an '88 FJ62 station wagon which is currently at Toyota for a service.
    I have just received quote for R28,000 to recon the transfer box and R6,500 to recon both propshafts. That's labour at around R800/hr for 35 hours for the box and 8 hours for the shafts.
    While I know to expect higher service prices from dealerships, this seems a little high. Is this reasonable or am I being jooked?
    Secondly, who in Joburg works on older Land Cruisers? Are there any experts who might offer better service than Toyota?
    Thanks in advance for your help.
    All the best,
    Paul
    Henties
    Thanked: 1444
    Default Re: Need advice on rebuilding FJ62 transfer box and propshafts
    I would try and look for a prop shaft workshop and a gearbox workshop. Toyota would quite likely outsource the work anyway.
    Get a quote from such specialist workshops and compare.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  3. The Following User Says Thank You to HugoNotte For This Useful Post:
    Kathu
    Thanked: 3851
    What is wrong with the T case.?
    Apr 2021
    Craighall Park
    I'm told it's "worn out". That phrase could cover a multitude of sins
    Apr 2021
    Craighall Park
    Thank-you, that's good advice.
    Do you know anyone particular in Joburg who would be worth contacting for this?
    Thanks very much.
    cheers
    Paul
    Bethlehem
    Thanked: 5366
    Quote Originally Posted by Paul Ash View Post
    Morning, new member Paul Ash here. I own an '88 FJ62 station wagon which is currently at Toyota for a service.............NICE cars.....!!
    I have just received quote for R28,000 to recon the transfer box and R6,500 to recon both propshafts. That's labour at around R800/hr for 35 hours for the box and 8 hours for the shafts.............6500 for props recon is a bit much.......
    While I know to expect higher service prices from dealerships, this seems a little high. Is this reasonable or am I being jooked?......see above
    Secondly, who in Joburg works on older Land Cruisers? Are there any experts who might offer better service than Toyota?.........I'd say Toyo Service Centre in West Rand. Ralph knows his Cruisers.
    All the best,
    Paul
    "Yes, I have a Bad Habit. I take Tea at Three".........Mick Jagger
    Nigel
    Thanked: 2509
    I have a t-case and propshafts for you.
    Contact me
    0824959252
    Uniglide
    +27 zero eight 2 four 95 9252
    Henties
    Thanked: 1444
    Thanks very much.
    cheers
    Paul
    Nope, I live at the west coast, Namibia.
    2012 FJ Cruiser
    Bethlehem
    Thanked: 5366
    Contact me
    0824959252
    Paul.......just call Henri for everything that needs to be sorted. Forgot about THE Go to Guy in here
    Thanked: 1220
    I would say that R6500 for both propshafts is reasonable. 5 x universal joints plus 2 x slip yokes/joints plus a centre bearing plus balancing.
    Apr 2021
    Craighall Park
    Thank-you, everyone, for the replies and advice.
    Henri, I will give you a call in the morning.
    Thank-you so much, I really appreciate it.
    All the best,
    Paul
    Kathu
    Thanked: 3851
    Cruisers does not have center bearings
  14. The Following User Says Thank You to grips For This Useful Post:
  15. #13
    Kathu
    Thanked: 3851
    The 62 have the split case gear driven t-case. Not much that can go wrong there.
    Only known problem is an oil leak at the front prop seal. Me think it will be like new with all bearings replaced.
    Only thing that kills them is lack of oil
