Results 1 to 20 of 36
Thread: Cruise control
    Oct 2014
    PE
    Thanked: 35
    Default Cruise control
    My cruise control decided not to work this morning.
    Any ideas
    2012 Wrangler CRD auto
    Dennis
    Oct 2014
    PE
    Thanked: 35
    Default Re: Cruise control
    I've checked all relevent fuses.
    Its when you turn on the cruise control at over 40, no light comes on and no function.
    Dennis
    KEMPTON PARK
    Thanked: 464
    Try hard reset , disconnect battery , most of the time this sorts out the gremlin .
    05 TJ SAHARA
    08 3.8 JK ULTD RUBICON
    Oct 2014
    PE
    Thanked: 35
    Will try that now, will report back
    Dennis
    Oct 2014
    PE
    Thanked: 35
    Disconnected battery for 25 minutes and then reconnected. Still the same.
    I had the clock spring replaced about 28 000 km ago
    Dennis
    Oct 2014
    PE
    Thanked: 35
    Is there not a relay or module somewhere
    Dennis
    Thanked: 33
    Quote Originally Posted by DennisWWebb View Post
    Its possible that the stalk was not re-connected when the dash/steering was taken apart during the clock spring change.
    2011 Jeep Grand Cherokee Overland 5.7
    Previous Jeeps:
    2012 JKU Rubicon 3.6 V6 on 37's with Synergy 5" Lift Kit with Fox 2.0 Factory Racing Shocks with Synergy Adjustable Control Arms
    2010 JKU Rubicon 3.8 V6 on 35's with Synergy 4" Lift Kit with Fox 2.0 Factory Racing Shocks
    2008 JKU Sahara 2.8 CRD 6sp Man on 33's with Full Traction 3"
    Oct 2014
    PE
    Thanked: 35
    It's been working well for over 2 years then suddenly......
    I don't think it's the clock Spring because all the other buttons work
    Dennis
    Thanked: 33
    Yeah it has nothing to do with the clock spring, i was saying that maybe when they replaced the clock spring that they didnt reconnect the stalk or connector for the cruise control. But if it had been working after clockspring and now not thats unlikely too
    Previous Jeeps:
    Oct 2014
    PE
    Thanked: 35
    Latest update.
    It's at FinAuto at the moment.
    They have not been able to pinpoint the problem yet.
    Will keep you all posted.
    Dennis
    Oct 2014
    PE
    Thanked: 35
    They have traced it down to the switch on the steering wheel.
    Getting expensive over 4K for a second hand switch and fitment as well diagnostics.
    Dennis
    Oct 2014
    PE
    Thanked: 35
    Fitted the second hand switch module and it still doesn't work.
    I don't actually think that is the problem.
    Has anyone out there ever heard of the switch module having to be replaced.
    The agents can only supply a new one in 21 days (I am told) which makes me think they are going to import one.
    Anyway they have put it all together again so I can use the vehicle while we decide what to do.
    Dennis
    Oct 2014
    PE
    Thanked: 35
    Ok here's the latest
    Apparently it is the switch that is at fault as it sent an error code.
    To order a new one is about 5K so I put it on hold.
    They cleaned up the slip rings and put it back together as I needed the Jeep back.
    On the way home I thought I would press the cc button just for fun.
    The thing WORKS and is still working today.
    So it only cost me R1500 for diagnostic and 2 hours labour.
    So beat that.
    Thanks for all your help.
    Dennis
    somerset west
    Thanked: 550
    I dont know if this relates
    On my mercedes if the ABS lights come on indicating the ABS system is not active any more the cruise control doesnt work.
    sort out the abs bas etc and the cruise control resumes working again
    Apr 2009
    Randburg
    Thanked: 43
    So beat that.
    Happened on my Grand Cherokee. Stopped working but I didn't have checked because it was due for a service in a couple of months. Drove it like that and tried it every now and then. Suddenly started working again and has been working ever since. Couple of years now.
    Still don't know what caused it. Glad it repaired itself.
    Oct 2014
    PE
    Thanked: 35
    Dennis
    Apr 2012
    Thanked: 89
    Not sure if this is related to Jeep, but in some instances the cruise control will also disable when a brake light is blown.
    2004 PRADO VX 4.0 V6
    Apr 2009
    Randburg
    Thanked: 43
    Quote Originally Posted by B_Engel View Post
    No lights blown. Also had a brake light out before and it worked fine. Just some gremlin that sorted itself out. So many electronics that it could be anything that decided to reset itself.
  19. #19
    Oct 2014
    PE
    Thanked: 35
    CC worked for a while but today it is dead again. I banged the steering wheel and the light came on then died again.
    Replacement part quoted at R3240 plus vat and R435 plus vat to fit it.
    I find the same part on Amazon.com for $50.
    Even if it costs me double that to land it here its surely a better deal.
    Any advice please.
    Dennis
  20. #20
    Oct 2014
    PE
    Thanked: 35
    X
ID:	557158   Click image for larger version.
    Dennis
