Results 1 to 8 of 8
    Potchefstroom
    Thanked: 298
    Default Thar dash indicators
    On my 2010 Thar dash are indicator lights for 4H and 4L, but is not working.
    Is there any way that they can be made to operate?
    Do they need to be wired or switches installed?
    It would be nice if the indicators light up when 4H and 4L is engaged!
  2. The Following User Says Thank You to Lappies Labuschagne For This Useful Post:
    Constantia Kloof
    Thanked: 1885
    Default Re: Thar dash indicators
    If it has a short stick they don't work, had the same on my Bolero and it is a function of the transfer case being entirely mechanical i.e. it doesn't have sensors. The lights are used when you have a vehicle with an electric selector that operates solenoids to do the selection where micro switches are activated to complete the circuit for the lights.
    Brandt Theunissen
    2007 Mercedes Benz ML500 5.5
    1968 VW Beetle 2276
  4. The Following User Says Thank You to Koebelwagen For This Useful Post:
  5. #3
    Potchefstroom
    Thanked: 298
    Quote Originally Posted by Koebelwagen View Post
    Surely microswitches can be installed on the selectors?
    I assume that the wires are in the harness?
    Constantia Kloof
    Thanked: 1885
    Quote Originally Posted by Lappies Labuschagne View Post
    I am sure you can try. I didn't really bother to investigate further once I realised the lack of installed sensors/ switchgear.
    Maybe the guys over on the TeamBHP forum can assist.
    Brandt Theunissen
    1968 VW Beetle 2276
    Benoni, Gauteng
    Thanked: 102
    Hi Koebelwagen,
    Your reply re the sensors in the TFR case does make logical sense, however my 2018 THAR has the indicators in the instrument cluster, and they do function, with the mechanical transfer case lever. I always thought the 4WD system of the first generation THAR and the second generation THAR was the same.
    Interesting ....
    Eric L
    ME_______ - 2018 Mahindra THAR - Hard Top / VHF+UHF Comms / Dual Battery system / Winch / Freezer
    SWAMBO__ - 2014 Mahindra BOLERO - Feels like an SJ / loads like a truck / tows like a tank!
    RETIRED___ - Zooks Galore ...'08 Jimny / '99 Gen 1 GV / 1.6 Vitara JLX-x2 / SJ413 SWB-x3 / SJ413 LWB-x1 / SJ410-x2.
    Potchefstroom
    Thanked: 298
    Maybe I must ask Mahindra!
    AFAIK the later models only have cosmetic updates:- dashboard and other plastics.
    If indicators work on later models, it should be able for earlier models as well! Same gear- and transfer box.
    Constantia Kloof
    Thanked: 1885
    Quote Originally Posted by Ericl View Post
    Hi Koebelwagen,
    Interesting ....
    OK, maybe it changed, I had a 2015 model Bolero. It had the lights, like Lappies' Thar but didn't work. The Thar and Bolero have the same transfer case.
    Brandt Theunissen
    1968 VW Beetle 2276
    Potchefstroom
    Thanked: 298
    Maybe I must check all the fuses!!
  11. The Following User Says Thank You to Lappies Labuschagne For This Useful Post:
