Good day I had a strange clunking sound when pulling away from a stop. So I started looking around and found that when the engine was pulling over to onside and made a clunking sound. So I jacked up the engine with a wooden block under the enige and took out the old one and replaced it the mount was about 1cm higher than old one everything was fine for a few days. Then when I start the engine I hear a strange vibration like sound. So I checked the nut and it came a bit loose so tightened it again but noticed it was leaning over again like the old one was I noticed that it was leaning over like the old one did jacked up the engine and fond noting wrong with it. After a short drive it starts to lower again. Has anyone have had a problem like this ? Or any advice that I can try ?
