Results 1 to 10 of 10
    Feb 2020
    Randburg
    Default Draw system for 2015 Fortuner
    Good day all.
    im looking for DIY plans / design for a draw system for my Fortuner. If anyone has built their own and is keen to share ideas / drawing / plans I would be very grateful.
    thanks
    Thanked: 1864
    Default Re: Draw system for 2015 Fortuner
    Old Shape or new shape.
    Feb 2012
    Thanked: 7
    Quote Originally Posted by TangoMike View Post
    Good day all.
    thanks
    Ek het ongelukkig nie meer die planne en tekeninge nie maar dit is wat ek gebou het vir ons 2011 Fortuner. Die twee rakke was nogal onstabiel op rowwe pad maar ek het die twee rakke aan die bokant aan mekaar vas gebout. Dit het uitstekend gewerk!
    Het dit intussen uit gehaal en verkoop. Sleep nou Bush Lapa
ID:	585319   Click image for larger version.
ID:	585320   Click image for larger version.
ID:	585321   Click image for larger version.
    Toyota Fortuner 2011 3.0 D4D 4x4 Auto
    Bush Lapa Boskriek (BL81)
  4. The Following User Says Thank You to JB10 For This Useful Post:
    Feb 2020
    Randburg
    Old shape
    Thanked: 1864
    So all I have left is an accurate drawing of the boot board I made. This leaves about a 10mm gap all around and reaches all the way to the rear of the seats.
    I can sent you the .cad and .dxf file and someone could waterjet cut this for you as the start.
    Feb 2020
    Randburg
    that would be great. Anything to start.
    [email protected]
    Thanked: 1864
    You have mail.
    Mar 2018
    Ellisras
    Thanked: 40
    I am also looking for these drawings if someone have them?
    Mar 2018
    Ellisras
    Thanked: 40
    Post Re: Draw system for 2015 Fortuner
    Quote Originally Posted by WantOnsKan View Post
    Thanks Andrew, much appreciated!
    Aug 2011
    JHB
    Thanked: 209
    Quote Originally Posted by JB10 View Post
    That looks really nice.
    I think that with a small amount of tweaking to the design, you could sort out the stability issues quite easily.
