Results 1 to 18 of 18
    Thanked: 1842
    Default YES1-160 GA/4P Automatic Transfer Switch
    Trying to assist my BIL. The "professionals" that installed the system really were beyond poor.
    The system works but for one thing. The generator starter motor cranks the generator to a start but then the starter motor does not disengage and switch off.
    Anyone with a wiring diagram, my translated one is a little confusing.
    Klipriver
    Thanked: 387
    Default Re: YES1-160 GA/4P Automatic Transfer Switch
    Are you sure it's a wiring issue? Not perhaps the starter itself?
    Alan
    _________________
    Range Rover P38
    Series 3 109 SW (Tortoise)
    Thanked: 1842
    The manual start works.
  4. The Following User Says Thank You to Andrew Leigh For This Useful Post:
    King Williams Town
    Thanked: 1913
    You need to incorporate a timer into the contact coil or run a live to press button and live to stop. To start generator, press button till it kicks in, to stop, press stop button.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 1842
    Ok been sussing this thing out.
    1. When power is applied to the Automatic Crossover Switch, and the Genny is off (no power failure). Is the contactor of the Automatic Crossover Switch NO or NC? NO makes sense for me.
    2. How does the power hold for long enough for the starter to kick in, are there a bunch of capacitors that deliver power for a brief period of time?
    3. What is the startup sequence generally? Power Drops, Contactor remains NO, Genny starts, Timer waits a couple of seconds, contactor pulls in and power is resumed?
    One would have thought that on an Automatic Crossover Switch their would be internal relays to control the start and the killing of the starter motor. In this sequence the starter need to get a signal to start, once started it then needs a signal to stop cranking, then when power is resumes then the Genny need to get a signal to the cut switch.
    I think that the generator should be connected across 301 and 306 from the below. This connection goes to a special plug on the Genny, there are three wires and three pins.
    Name:  Automatic Switch Wiring.JPG
    The Generator is a JDP6000-LDENS Air cooled Diesel Generator.
    Mar 2014
    Joburg
    Thanked: 75
    As per the drawing of the switch I don't see a mains monitor or remote start signal output. Is there another controller or sorts next to the ATS switch?
    Thanked: 1842
    Quote Originally Posted by Geiler Keiler View Post
    No unfortunately not, what you see is what was installed. What do I need to get and how is that wired into the Genny?
    Mar 2014
    Joburg
    Thanked: 75
    Two options
    1 ATS Controller at ATS switch and engine controller at generator.
    2. AMF controller that controls the ATS switch and the generator.
    How far is the ATS switch from the generator?
    Thanked: 1842
    Two options
    The ATS Switch is around 2.5m cable run to the Genny.
    Nov 2017
    Thanked: 265
    Have a look at the 12v outputs of the generator for a positive when it starts.
    If there is a suitable 12v available - you get a positive as soon as it starts, you can fit a change over relay. The positive must be enabled so the starter does not run on, or cuts the starter off too soon.
    You could also try a positive to an additional oil pressure switch but the timing must be accurate to avoid the above.
    Everything should be made as simple as possible, but no simpler.
    Thanked: 971
    Another point if the positive to the relay coil goes to 12V and engine is still crancking the relay might be replaced with a timer that can be set to a few seconds. Trail and error to find the actual setting. With this then the killing of the genny must be worked in when grid is on.
    Thanked: 1842
    Thanks for bearing with me on this.
    Okay I get the solenoid setup, I think.
    Relay is connected with the NC contacts in series with the Starter, which is permanently connected to the ATS, the relay is unenergized. When ATC activates starter kicks in, when voltage lifts sufficiently the relay is activated taking the starter motor out if circuit. Great I can get this sorted. A couple of questions though.
    The output from the ATS, when I find it will be is 12V +?
    We will not need a timer?
    So we can easily switch off the starter motor now thanks.
    How do we get the Genny to stop. Is it simply a matter of another relay wired in the reverse to ground out the ignition coil?
    I did notice this a.m., from a picture sent to me that there is an ATS output port on the Genny with a 6 pin connector and a 3 pin port that appears to have been added later. The three pin port is the one that was used to go to the ATS. So it would appear is if somebody has already found the relative connections already.
    Thanked: 1842
    I would prefer to avoid trial an error. It is a 70km drive to test or replace part every time. So the relay is probably R 30 and the timer probably R 300.
    What about a capacitor across the relay coil to give a couple of seconds more?
  15. #14
    Nov 2017
    Thanked: 265
    Simplest is what hunter said. Might save problems where the gen set is cold or hot regarding different starting times.
    To switch off, you could use a 4 pin relay connected to the diesel pump solenoid if fitted. How do you switch it off on manual start.
    Don't forget insulated lugs, wire, insulation tape, cable ties, crimper etc......
    Have a look at the gen set battery charger side for another possible 12v supply or check the output from the alternator if fitted.
  16. #15
    Mar 2014
    Joburg
    Thanked: 75
    [QUOTE=Andrew Leigh;4623344]The ATS Switch is around 2.5m cable run to the Genny.[/QUOTE
    If its that close I would go for a AMF setup.
    With a AMF controller you have protections like:
    Mains over / under voltage
    Mains high / low frequency
    Mains phase sensing / rotation
    Gen over / under volt
    Gen over / under frequency
    Gen over load protection
    Gen oil pressure
    Battery charger / DC alternator voltage
    You will be able to read:
    Mains Voltage
    Mains Frequency
    Gen Voltage
    Gen Frequency
    Gen current
    Gen DC Voltage
    Run Hours
    Then there are load of programmable timers:
    Main abnormal delay
    Mains normal delay
    Start delay
    Gen safety delay
    Gen stop delay
    And some AMF controllers have built in battery changers.
  17. #16
    Thanked: 971
    The trail and error was when installed to test with cold and hot engine.
    Capacitor won't work when you energise the coil. The relay will still pick up as soon as energised. If it was time delay to drop off it would work.
  18. #17
    Thanked: 1842
    The capacitor was meant to to keep the relay in for that little bit longer to avoid the timer. If the voltage picks up too quickly the generator may not be fully started and may cut out again?
  19. #18
    Thanked: 971
    When the genny starts the relay picks up and stays picked up. Thus one needs to delay the picking up until the genny runs. This delay must be long enough for cold and hot starts. Not easy to get a cold enough day to trail and error cold starts as it is still quite warm but winter is coming.
