Results 1 to 12 of 12
    Jul 2010
    Gordons Bay as a base - travelling Africa
    Thanked: 241
    Wink Armadillo Shack Review
    March 2020 in Nossob, short before lockdown, we saw an Armadillo trailer and I was immediately hooked.
    During lockdown, I did research and later we visited the factory, prepared to order a brand new one.
    But it wouldn't be ready before the beginning of October and we had a Kgalagadi booking from the beginning of September.
    Luckily they gave us the address of a second-hand owner that wanted to sell it because he already had ordered a newer and bigger one.
    And so we bought our first-ever Offroad Caravan, the Armadillo Shack.
    It came with a 90 l NL fridge freezer, full awning, a steel table and a washbasin
    , a 110 W solar panel,
    two deep cycle batteries, spare wheel, a jerry can, two gas bottles, an 80 l water tank with electric pump,
    gas geyser and shower tent. The stove is a two plate CADC stove.
    It was 2 years old and looked as new.
    One thing I didn't like was the big awning, we tend to travel light, so we took it off and instead installed a light Leisure World awning.
    First picture isn't mine, but shows exactly how it came.
    Next pictures show the area where you can put up the table and sit and the part in front where the fridge stays.
    The original mattresses were too thin for us. We also never put up the table so we decided to use a foam mattress in one piece.
    The space underneath the table now takes our two chairs and the enviro-loo (10l fits exactly underneath).
    The bed is fantastic, it measures 1.90 x 1.50 m.
    The storage is absolutely generous, even on our last 9 weeks trip including CKGR we never got to use every compartment.
    We even had two 25 l plastic jerry cans in the middle-lower compartment for CKGR.
    The last pic shows a bit of the gas stove behind hubby, I like the way it is mounted and you can always work around the fold-down door.
    The pic with the blue light was taken at the Doornkraal campsite in Ithala (tnx to the forum members that suggested the place)
    The blue light is mounted underneath the steps, more of a fancy gadget, but it makes great pics at night.
    The caravan is set up in under 5 minutes. Just pop up the roof, take struts and front support leg down,
    plug 220 V in or pull out the solar panel to place it in the sun and it's all done.
    I didn't like the big awning (still in our garage) and also not the name Shack so I carefully removed it from the trailer.
    We removed the original spring blades as they were flat at one stage and added 10 blade springs.
    I learned that one should always use the front support thing when storing the caravan to avoid such a scenario,
    but we also had Echo 4 trailers before that had 10 blade springs installed.
    New Armadillo caravans come with 10 blade springs, I heard.
    I absolutely love the easy setup, no need to pop out any windows, just one push up and two rods that's it.
    There are ample 12 V and 220 V plugs, and plenty of 12 V lights built-in.
    The gas bottles connect directly to the gas stove and geyser. Plug and play.
    We can take the solar panel off to place it in the sun, it is permanently connected and charges also while we drive.
    The extension has about 7 m and was more than long enough to give us a good charge in Richtersfeld and CKGR.
    We met many people that had a look at it in the last 8 months. One couple we met at Kgalagadi even told us,
    that they were on their way to order an offroad caravan from another brand when they came about the Armadillo
    and in the end, they saved R 65.000 and it ticked more boxes than the one from the competitor.
    Some more details in the next post.
ID:	612379   Click image for larger version.
ID:	612380   Click image for larger version.
ID:	612381   Click image for larger version.
ID:	612382   Click image for larger version.
ID:	612383   Click image for larger version.
ID:	612384   Click image for larger version.
ID:	612385   Click image for larger version.
ID:	612387   Click image for larger version.
ID:	612388   Click image for larger version.
ID:	612389   Click image for larger version.
ID:	612390   Click image for larger version.
  2. The Following 7 Users Say Thank You to Southerndreams For This Useful Post:
    Jul 2010
    Thanked: 241
    Default Re: Armadillo Shack Review
    1. Side window
    2. 3. Gas geyser compartment with one of the two deep cycle batteries
    4. 5. Steel table stores between body and nose cone - Front part support stabiliser (don't know how to call it).
    previous owner had installed the holder for the support stabiliser and we installed the holder for the jockey wheel as we take it even off driving in town.
    7. - 9. We installed an extra Thule caravan lock for enhanced security.
    10. 11. Middle compartment
    12. - 14. Gas stove compartment
    15. This small compartment usually stores the shower curtain, the shower frame just clips into the two black clips above:
    We normally don't use the shower and we use this compartment to store the electric leads and plugs.
    Shower curtain is stored underneath the bed.
    16. - 18. Gas bottles, jerry can holder, 220 V and solar plugs and spare wheel
    Its very windy today but if you want I can add some details from inside tomorrow.
ID:	612394   Click image for larger version.
ID:	612395   Click image for larger version.
ID:	612396   Click image for larger version.
ID:	612397   Click image for larger version.
ID:	612398   Click image for larger version.
ID:	612399   Click image for larger version.
ID:	612400   Click image for larger version.
ID:	612402   Click image for larger version.
ID:	612403   Click image for larger version.
ID:	612404   Click image for larger version.
ID:	612405   Click image for larger version.
ID:	612406   Click image for larger version.
ID:	612407   Click image for larger version.
ID:	612408   Click image for larger version.
ID:	612410   Click image for larger version.
  4. The Following 3 Users Say Thank You to Southerndreams For This Useful Post:
  5. #3
    Aug 2017
    Bellville
    Thanked: 166
    Very nice set up!
  6. The Following User Says Thank You to SP1971 For This Useful Post:
  7. #4
    Pietermaritzburg
    Thanked: 86
    Thx , we are getting our xtr 302 on the 19th of April, can't wait to go camping with it
  8. #5
    Jul 2010
    Thanked: 241
    Quote Originally Posted by SP1971 View Post
    Very nice set up!
    Thank you. We love our Armadillo And big Pajero fans anyway, no matter what camping trailer or Caravan we have
  9. #6
    Jul 2010
    Thanked: 241
    Quote Originally Posted by Thole View Post
    Great. Would love to see how their new opening mechanism works
  10. #7
    Pietermaritzburg
    Thanked: 86
    Wil post some pics .at our first camp
  11. #8
    Pietermaritzburg
    Thanked: 86
    Collected our Armidillo xtr302 on monday, we are very impressed with the van. It towes very well, and setup is very simple.
    Build quality is very good.Click image for larger version.
ID:	615530Click image for larger version.
ID:	615531Click image for larger version.
ID:	615532Click image for larger version.
  12. #9
    Jul 2010
    Thanked: 241
    May I ask what you paid?
  13. #10
    Pietermaritzburg
    Thanked: 86
    We paid 376,000.00 that included vat and 18000.00 worth of extras
    It comes standard with 100w solar , gas geyser + bottels, and plenty of lights, every nook has a light. Full tent and shower and dressing tentClick image for larger version.
  14. #11
    Jul 2010
    Thanked: 241
    GARAGE CLEAN OUT:
    Selling our almost brand new Caravan Awning (3.50 m x 3.00 m) including 3 never used sides
    (Valued at R 12.000) for incredible R 4900
    The 3 sides are BRAND NEW. Nothing wrong with it, but we love to travel light, so we took it off and installed a 2 m roll out awning.
    Since we bought the trailer, the awning was stored in a dry garage. We need to clear out now and it needs to go soonest!
    Grab the awning before Saturday, 29. May, and I'll add the double basin and stand (holder?) as well at no extra cost.
    See the last picture, please note, the basin comes without the table.
    WA to 064 655 3990
    It has 3 arms. 2 fold out to the right and the left. A third is hooked on the trailer in the middle.
    It's quick to set up. Just not our cup of tea.
    We missed taking pics when we set it up once, but I think the random pictures will give a good impression
ID:	616363   Click image for larger version.
ID:	616364   Click image for larger version.
ID:	616365   Click image for larger version.
ID:	616366   Click image for larger version.
ID:	616367   Click image for larger version.
Name:	Aemadillo Basin.jpg
  15. #12
    Jul 2010
    Thanked: 241
    How much did the awning cost?
