Results 1 to 16 of 16
Thread: Rust
    May 2018
    Brackenfell
    Default Rust
    Hi everyone.
    I just noticed a bit of rust just above my windshield (2015 DC Ranger).
    Is this normal? Is it a cause for concern? How urgently should I get it resolved?
    Willem
    Thanked: 550
    Default Re: Rust
    Quote Originally Posted by wibob View Post
    As quickly as possible.
    2007 Nissan Pathfinder LE 2.5dCI 4x4
    2013 Nissan Xtrail 2.0dCi XE 2x4
    Jul 2013
    Thanked: 394
    Default Re: Rust
    There is seam there and will spread rapidly if left unattended.
    I treated my old ranger with some sandpaper,rustbuster and touch up with earbud and paint.
    the only real cure is to have the windscreen removed and professionaly repaired.
    Next time insurance replace your winscreen,speak to your panelbeater.
    Debbin
    Thanked: 120
    Default Re: Rust
    Get it sorted ASAP
    prevention is better than cure
    once it intensifies and spreads to the other plate under that, the oxidation that naturally causes the rust to Ďexpandí pushes against the class and will cause it to crack.
    my 07 was plagued by rust around the screen and I had it removed more than once but when itís going especially on the plates on the inside, itís hard to stop.
    May 2018
    Brackenfell
    Default Re: Rust
    I must say, I am pretty surprised that this is starting on what I consider a fairly 'new' vehicle. I've only had it for a year and a half. My old Bantam had less rust issues after 10 years of use. I'm guessing my anti-corrosion warranty, after-market mechanical breakdown and short-term insurance will all be useless for this problem?
    Thanked: 550
    Default Re: Rust
    That does look like stone chips and it started to rust.
    Get it treated.
    Mar 2015
    Thanked: 629
    Default Re: Rust
    See if you can find the anti corrosion warranty documents. I think it is 5 years. There is a couple of Toyota Hilux's and Fortuners on the group with the same problem and a lot newer. Maybe have a look at that thread for some advice.
    https://www.4x4community.co.za/forum...d.php?t=305277
    May 2018
    Brackenfell
    Default Re: Rust
    Quote Originally Posted by Tom13 View Post
    Yeah, 5 years.
    May 2018
    Brackenfell
    Default Re: Rust
    So is this the kind of thing you can spot-fix, or will it be a whole mission to get the windscreen off and work on the whole area?
    Also, is there a way from preventing it from happening again? Some kind of roof-wrap stone-chip protection or something?
    Jul 2013
    Thanked: 394
    Default Re: Rust
    The windscreen is glued , has to be destroyed.
    Replacement wscreens are not expensive for ford mazda . old shape wr.
    Debbin
    Thanked: 120
    Default Re: Rust
    If the surface rust has not spread under anything yet and you can reach it, you can try a rust converter to slow it down.
    Remove as much of the rust as you can, then apply some of the rust converter. Once itís dry properly, apply some touch up paint to seal it a bit better.
    Keep an eye on it to make sure it doesnít spread
    Aug 2020
    Oasis
    Thanked: 3529
    Default Re: Rust
    Quote Originally Posted by RvanZ View Post
    I agree.
    No need to get into a panic just yet. Follow this ^ advice and keep an eye on it.
    The pic is not very clear but it only looks like surface rust - I can see no paint bubbling or chipping away at the spot.
    Willem Greyling
  13. The Following User Says Thank You to MANDREAS For This Useful Post:
    Robertson/ Larissa, Greece
    Thanked: 4635
    Default Re: Rust
    Quote Originally Posted by janseekat View Post
    Why does the windscreen have to be destroyed?
  15. #14
    Aug 2020
    Thanked: 27
    Default Re: Rust
    Yup I had the problem on my 5 year old Fortuner as well as on other places. Got it fully repaired at panel shop and now have a strip of VPS fitted across the windscreen lip to prevent further stone chips and new rust spots forming.
  16. #15
    Sep 2011
    cape town
    Thanked: 108
    Default Re: Rust
    I have posted somewhere a few months ago. I also have the same issues. Ford rejected my warranty claim. The say its a result of stone chips. I went to DALS and got a qoute for 15k to repair. I didnt. Will need to do something soon.
  17. #16
    Nov 2011
    Thanked: 1309
    Default Re: Rust
    Quote Originally Posted by riyadh View Post
    Exactly like someone else told me -small rust spots appeared at rim of windscreen glass- dealers blamed stone chips -not a single other 'stonechip' anywhere else to be found on front -sounds like Frod have a problem they are hiding.
    - Charles Bukowski
