Page 1 of 4 1 2 3 4 LastLast
Results 1 to 20 of 67
    Oct 2017
    Rustenburg
    Thanked: 6859
    Default Leg Of Lamb On An Open Braai
    I have yet to "open" braai a leg of lamb IOW not in a Weber, or Offset BBQ, but on a braai, with coals under it
    I have heard a lot about this and really want to try it.
    Any pointers
    Deboned is a must, as I have heard..
    What fire? What kind of coals, how long, what dab (roast baste) should I use?
    Andrew van Staden
    Honeydew
    Thanked: 76
    Default Re: Leg Of Lamb On An Open Braai
    Make sure that once it is deboned that it is more or less the same thickness throughout - start with a relatively cool fire, because it is thick you cannot braai it on hot coals and fast - low heat long time is the way to do it...I really enjoy doing every now and then and it tastes fantastic - don't over braai it!
    Ford Ranger
    Double cab
    2.2
    Stock standard (for now)
  3. The Following User Says Thank You to Christob For This Useful Post:
    Jun 2017
    Robertson
    Thanked: 110
    Doen dit soos 'n lamsrib, staan-staan.
  5. The Following 2 Users Say Thank You to handyman For This Useful Post:
    Robertson/ Larissa, Greece
    Thanked: 4668
    I have done it a number of times and found it ususally takes longer than expected. A good marinade helps with some good quality olive oil added. Drip some of the marinade from time to time while braaing.
    And yes as mentioned, go slow. If you are going to debone it yourself, get the right knife. It can be a tricky exercise!
    The finished product can be quite enjoyable.
  7. The Following 4 Users Say Thank You to Francois Theron For This Useful Post:
  8. #5
    Oct 2017
    Rustenburg
    Thanked: 6859
    Quote Originally Posted by handyman View Post
    Dis 'n interesante idee... Met anderwoorde, ontbeen en plat in 'n toeknyp rooster, in 'n staan houer langs 'n vuur..
    Mmmmm... Dit klink nou soos KUIER!
    Andrew van Staden
  9. #6
    Nov 2011
    Thanked: 1325
    Did this just the other day- fantastic!
    Debone leg and slit thicker thigh to fold open -ensure approximately even thickness.
    Make up generous marinade of olive oil, pepper, origanum, thyme, garlic, lemon zest ( not juice -that's for later)
    -stud lamb with slivers of lemon rind, sprigs of rosemary, ( chillies sliced if you like )
    -pour marinade , and leave to marinate with occassional turning, for up to 24hr.
    Very hot fire -meat on -mix lemon juice into marinade
    (NB-handle meat with tongs, not prongs! - keeping meat flat and 'contained' rather than stretched out on grid, aids in keeping moisture)
    -sear -and nearly char -meat on both sides, while basting with marinade
    -once seared, put away to rest on wooden board with foil/pan cover for 5 min
    -return to medium heat in sealed pan/foil
    -cook further 10-20 min, depending on thickness, and how rare you like it.
    Generous squeeze of lemon, pepper , Greek salad, aniseed braai rolls
    - absolutely delicious!
    Crispy and succulent!
    - Charles Bukowski
  10. The Following 11 Users Say Thank You to Patrick L For This Useful Post:
  11. #7
    Oct 2017
    Rustenburg
    Thanked: 6859
    Quote Originally Posted by Patrick L View Post
    Make up generous marinade of olive oil, pepper, origanum, thyme, lemon zest ( not juice -that's for later)
    I had to wipe my desk..
    Andrew van Staden
  12. The Following User Says Thank You to Hedgehog For This Useful Post:
  13. #8
    May 2016
    Thanked: 3857
    Sous Vide beforehand?
    2006 VW Touareg V10 (Sold)
  14. #9
    Oct 2017
    Rustenburg
    Thanked: 6859
    I get the reason, but I find the texture of the sous vide cooked meat unpleasant...
    Andrew van Staden
  15. #10
    Bethlehem
    Thanked: 5370
    Just curious - why deboned??
    "Yes, I have a Bad Habit. I take Tea at Three".........Mick Jagger
  16. #11
    Aug 2020
    Oasis
    Thanked: 3759
    Ek het al baie ontbeende skaapboud soos 'n staanrib gebraai.
    Brikette werk die beste in my opinie, maklik om die hitte te reguleer.
    My vrou gebruik 'n Greek Salad slaai sous as basting sous - baie lekker.
    Willem Greyling
  17. The Following 5 Users Say Thank You to MANDREAS For This Useful Post:
  18. #12
    Oct 2017
    Rustenburg
    Thanked: 6859
    To get it even thickness, and the bone requires longer cooking I think
    Andrew van Staden
  19. The Following 2 Users Say Thank You to Hedgehog For This Useful Post:
  20. #13
    Aug 2020
    Oasis
    Thanked: 3759
    Raak meer egalig gaar.
    Willem Greyling
  21. #14
    Thanked: 4668
    Can you braai 'n heel boud?
  22. #15
    Aug 2020
    Oasis
    Thanked: 3759
    As mens dit braai soos op 'n spit, sal dit werk. Ek dink die fancy mense noem dit 'n rotisserie of iets.
    Willem Greyling
  23. #16
    Nov 2011
    Thanked: 1325
    I've not tried this, but I'm sure a Weberati star braaier could do it? -but probably only very slowly, and with thermometer aid?
    - Charles Bukowski
  24. #17
    Oct 2017
    Rustenburg
    Thanked: 6859
    Quote Originally Posted by MANDREAS View Post
    Jou vrou sal weet
    Andrew van Staden
  25. #18
    Oct 2017
    Rustenburg
    Thanked: 6859
    A whole leg works well in a Weber, but the thread is about an anti Weber method
    Andrew van Staden
  26. The Following User Says Thank You to Hedgehog For This Useful Post:
  27. #19
    Bethlehem
    Thanked: 5370
    Nog nie probeer nie, maar ek sou se as jy die thin bits met foil toedraai kan dit werk......??
    Hoekom ek vra - daai been gee darem ook lekker flavour aan die vleis
    Ons braai nou en dan ontbeende boud met toeknyp rooster, BAIE nice met goeie olyfolie en feta blokkies en jogurt - jy druk die feta sommer so met die hand met die jogurt en smeer hom.
  28. The Following User Says Thank You to Petri Oosthuizen For This Useful Post:
  29. #20
    Nov 2011
    Thanked: 1325
    Are you allowed tin foil, though? -on your tyre-rim fire of pallet wood?
    That's like a Parkie's Weber, inn'it?
    Also great for protective hats when out in the bush with all the Starlinks etc. tapping in...!
    - Charles Bukowski
  30. The Following User Says Thank You to Patrick L For This Useful Post:
