Results 1 to 3 of 3
    Mar 2011
    Walker Bay
    Thanked: 1283
    Default Camping inverters
    Anyone know whether we should be earthing the small inverters we take while camping - and if so should we earth to the chassis? Mine is 500W.
    Jul 2010
    Pinetown
    Thanked: 2255
    Default Re: Camping inverters
    Paul, yes, afaik, however I never have and have never had a problem.
    There is a fuse between the 12V battery supply and the inverter though.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  3. The Following User Says Thank You to Peter1949 For This Useful Post:
    Thanked: 903
    There might be risk involved in earthing equipment working on 220V if the operating instructions do not say you must or where no earth is provided.
    A number of inverters do not have isolation between the battery DC side and the 220VAC side.
  5. The Following User Says Thank You to ekkekan For This Useful Post:
