Results 1 to 7 of 7
    Sep 2014
    Kuilsrivier
    Thanked: 128
    Default Breather on diffs
    So often i do long gravel roads with 4x4 high and occasionally needs to go throught a water crossing.
    I know the diff oil gets warm and should it go through cold water it might suck in water.
    Anybody have knowledge of one way breather connections on a Gen 4 Jimny?
    Johan
    Live Life!
    King Williams Town
    Thanked: 1763
    Default Re: Breather on diffs
    I must say, my old 2003 Isuzu has its diff pipe breather connected into my fuel tank filler pipe.
    2x spotlight,2x fog lights
    215/80/R15c tyres
    1 x great humourous driver
    GPS,Bluetooth
    snorkel soon
    Craig
    Thanked: 1626
    Quote Originally Posted by Coetzee Kuilsrivier View Post
    I don't think you want a one way valve as the pressure drop on suction can be extreme and will just suck water in through the seals. Much better to just extend the diff breathers to somewhere higher like a snorkel.
    Better still to just avoid the water if it is not essential to wade through it.
    Thanked: 1636
    One-way valve is definitely not the answer.
    Either an extended breather with it's end higher up than the water level (which by the sound of it you may already have), or a little bellows is the answer.
    Make sure you have similar solutions for both diffs as well as the transfer case and gearbox (if it's a manual gearbox).
    Jul 2010
    Pinetown
    Thanked: 2255
    The old Suuz has extended breathers on diff and gearbox - just extended pipe lengths - never had a problem with this.
    Simple & effective.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
    King Williams Town
    Thanked: 1763
    Quote Originally Posted by Peter1949 View Post
    Simple & effective.
    Peter I traced my rear diff breather (4x2) and see it goes into my fuel tank filler pipe. My concern is, what happens on a full tank, won't it suck fuel back into diff when diff is hot then cools.
    215/80/R15c tyres
    GPS,Bluetooth
    snorkel soon
    Craig
    Jul 2010
    Pinetown
    Thanked: 2255
    Not sure but depends where in the pipe it connects I guess.
    If very high and entering from the top of the pipe maybe ok?
    Mine are just extensions upwards not connected into any other pipe.
    Obviously not in the worst dust prone places.
    Never given trouble, never had water in diff or gearbox, so must be OK.
    Plenty of water crossings over time but never much deeper than above hubs excepting maybe very briefly or from a bow-wave.
    I have always avoided water crossings when practical because in the places we have done them it is usually not exactly safe to walk the crossing.
    So I tend to rely on seeing recent tracks going in and OUT on the other side or otherwise not being the first vehicle in a group crossing.
    Avoided any disasters ....
    Peter Hutchison
  8. The Following User Says Thank You to Peter1949 For This Useful Post:
