Results 21 to 29 of 29
Thread: D250S Dual Help
    Jan 2010
    Gauteng
    Thanked: 97
    Default Re: D250S Dual Help
    Quote Originally Posted by coetzer94 View Post
    Please correct me if I am wrong.
    You connected the vehicle main battery as well as the solar.
    You did not connect your second battery (assuming from your volt reading in pic 2)
    Your DC-DC unit will not give a voltage output unless there is a second battery connected to the system, only then will the power light illuminate and will the unit charge the second battery.
    I also bought my ctek 2cnd hand off facebook and still going strong. The biggest issue on them is the max solar volt rating blowing fuses, just check that your solar panel is within the CTek spec
    I will try this again this weekend and see what results I get. Thanks for the tip.
    Jan 2010
    Gauteng
    Thanked: 97
    Quote Originally Posted by albertdc View Post
    WayneMan, did you give Sarel a call as suggested?
    I'm going to try again this weekend As suggested in previous comments. If it still fails I'll look into giving him a call. Thanks for those details.
    Thanked: 965
    Quote Originally Posted by AndyT View Post
    Which light are you referring to as the "power light" ?
    I have not fooled around with mine for a few years now, but as far as I can recall you need a battery at both ends for it to work and they must be at working limit of the unit..
    This is correct.
    Nico Swart
    Triton 2.5DiD D/C with SS
    ZS6NJS
    Thanked: 965
    And this.
    Problem solved. Almost guaranteed.
    Nico Swart
    ZS6NJS
  5. #25
    Nov 2016
    Thanked: 96
    Any Update?
  6. #26
    Thanked: 965
    And now?
    Any updates now?
    Nico Swart
    ZS6NJS
  7. #27
    Jan 2010
    Gauteng
    Thanked: 97
    I tried again this morning and same condition, the power light does not come on.
    The solar light and / or the alternator light but else
    I ran it for s few minutes, and still no change.
    I've decided to look at an alternate solution like one of the victron DC to DC charges. They are half the price of the new Ctek chargers.
  8. #28
    Thanked: 965
    Quote Originally Posted by WayneMan View Post
    Just to confirm, you had the main source battery, as well as an auxiliary connected and added the solar panel and then tested?
    Nico Swart
    ZS6NJS
  9. #29
    Jan 2010
    Gauteng
    Thanked: 97
    I only had the source battery and aux battery connected with the engine running. No solar panel this time. No power light comes on and no charge to the aux battery. It is definitely faulty.
    As you connect power, a red light flashes, and that to me, shows an error condition.
    Its going in the dump and I'm moving on. I have purchased a different brand and feel confident I won't be left stranded by this rubbish.
    C Tek is a good brand, but unfortunately this one has let me down.
