Results 1 to 20 of 40
    Thanked: 554
    Default Sikaflex alternative for sealing caravan
    Hi guys,
    I need to reseal a small bit of my caravan. I did some sealing yonks ago and it needs some touch ups. But for the life of me I cannot remember what I bought. I'm sure it was sikaflex, but my local builders only has Sikaflex 11FC and I'm not sure if I can use it.
    Are there any other alternatives?
    This is just a patch job for now for going camping at the end of April. I would like to take the caravan in for a pro job after that to have the whole van resealed properly.
    I know I should not use normal silicone.
    2007 Nissan Pathfinder LE 2.5dCI 4x4
    2013 Nissan Xtrail 2.0dCi XE 2x4
    Brackenfell
    Thanked: 464
    Default Re: Sikaflex alternative for sealing caravan
    sikaflex alternative, is soudal polyurethane sealant. Bought some yesterday at our local small hardware for R92.00. Used alot before and works well
  3. The Following 3 Users Say Thank You to Dwayne P For This Useful Post:
    Thanked: 554
    Thanks. Saw that at Builders.
    Thanked: 554
    Would this be it?
    https://www.builders.co.za/Fasteners...00000000614583
    I suspect they only have it in black.
    Thanked: 1626
    I know that the marines sikaflex can only be had around Dbn. I tried calling locally as they HO is up here, but they could only sell me a full box of many more tubes than i needed.
    Speak to them and ask them who has stock of the product you need, or if it is a temp job, just bodge it with some bathroom silicone and get the guys to do it when they strip and reseal.
    For boats, people seem to swear by Sikaflex, so it seems better than the competing products based on user experience?
  7. The Following User Says Thank You to stephenplumb For This Useful Post:
    Thanked: 554
    Quote Originally Posted by stephenplumb View Post
    Heard that normal silicone eats away at the alu. I guess 4 days won't hurt. I could always just remove it when I get home.
    I was quoted R5500 to reseal the whole van. Not bad.
    Apr 2018
    JHB
    Thanked: 169
    Quote Originally Posted by IcePick88 View Post
    Would this be it?
    +1 on the soudalflex.
    It's available in white, black & grey. The colour can only be found just above the barcode or if you read german on top on the tube next to opening, and builders packs them all together so you have to rummage a bit.
    I always use grey on my alu canopy when a bolt goes through or wires etc and no leaks. The black I used all over the cab of the Defender cause well it's a Defender and no more leaks.
    2018 Suzuki Jimny - Expedition vehicle
    2002 Land Rover Defender - Daily Drive
  10. The Following 2 Users Say Thank You to Sheldon93 For This Useful Post:
  11. #8
    Brackenfell
    Thanked: 464
    Would this be it?
    that is the same one. We have it available in White, grey/silver and black.
  12. The Following User Says Thank You to Dwayne P For This Useful Post:
  13. #9
    Thanked: 554
    Quote Originally Posted by Sheldon93 View Post
    Great thanks. I was standing at builders trying to figure out where the hell the color is written. I'll go have another look!
  14. #10
    Apr 2018
    JHB
    Thanked: 169
    Took me 37mins staring at every inch of the stupid thing until I saw it the first time
  15. The Following User Says Thank You to Sheldon93 For This Useful Post:
  16. #11
    Brackenfell
    Thanked: 464
    same here. use black for rubberising in load bin that has been damaged. Silver in seams on my stainless off road trailer.
  17. #12
    Nov 2011
    Thanked: 1316
    SikaFlex FC11 is perfect.
    (The other may be as good at slightly cheaper -I have not used it. Pay R150 for FC11 in non-Builder's shop here -Buco are at R150 also at the moment -I think)
    Colour in white,grey,black, brown -colour printed on barcode label-AND olour-coded by nozzle colour!
    - Charles Bukowski
  18. The Following User Says Thank You to Patrick L For This Useful Post:
  19. #13
    Nigel
    Thanked: 2510
    Wurth has an equivalent that doesn't need to be finished. You dispense as you need it.
    Uniglide
    +27 zero eight 2 four 95 9252
  20. The Following User Says Thank You to Henris For This Useful Post:
  21. #14
    Thanked: 1242
    Silkaflex could be difficult to remove if it's only a temporary job.....it's that good!
    FJC - Just Cruising
  22. #15
    Debbin
    Thanked: 120
    Den Braven polyflex
  23. The Following User Says Thank You to RvanZ For This Useful Post:
  24. #16
    Brackenfell
    Thanked: 464
    Quote Originally Posted by RvanZ View Post
    Den Braven polyflex
    is this still available. I have used it in past, not stocked in our local store anymore
  25. #17
    Thanked: 2667
    Soudaflex - same as sika just more economical. NEVER use silicone, acetic acid chows alu or any metal for that matter even stainless
    Henk
    Follow us on Facebook
  26. The Following User Says Thank You to hbannink For This Useful Post:
  27. #18
    Kimberley
    Thanked: 22
    Can this Soudaflex be used on yacht deck fittings?
  28. #19
    Gaborone
    Thanked: 1301
    Sikafex FC11 is nowadays used a lot in marine applications, be it on decks or to combine some compound connections.
    It is meant for permanent use and rather difficult to remove once it is fully cured. The density and strength is close to the compound of a tyre rubber.
    So it is worth the while to do the Sikaflex job thoroughly the first time round.
    I have used it on a 100 year old diesel boat (1911 built) with steel hull and it has survived the hull itself when redoing the deck and roof structure.
    No more screws or nails, no rust and keep it flexing, so no cracks ever.
    Walter Rene Gygax
    Kalahari Safari
    ORRA Call:​ WB58 | ICASA ZRF430
    Nissan Patrol GU TB45
    E39 - 540i for the open roads
  29. The Following 2 Users Say Thank You to Kalahari Safari For This Useful Post:
  30. #20
    Oct 2017
    Kriel
    Thanked: 95
    If i wanna seal off something on the car a usually go to pg glas and buy the silicon they use to install the windscreens of cars... Never any problems thus far...
