Results 1 to 9 of 9
Thread: Glow plugs?
    Thanked: 36
    Default Glow plugs?
    Glow plug advice please.
    I have 2 faulty glow plugs on my 2003 3.0D Toyota – 210 000 Km resulting in some rough idling on initial start-up.
    Cylinders 1 & 2 measures .8 Ohm and cylinders 3 & 4 measures about 3 Ohm.
    Using V=I*R formula, I know I must replace glow plugs for cylinders 3 & 4 but have the following questions:
    1. Do I replace all 4, or only the 2 “dead” ones?
    2. What caused the 2 glow plugs to die on 210 000 Km? I have an Isuzu with 638 000 Km that still starts first time every time.
    3. Is it really that difficult / risky to remove the glow plugs? Toyota quoted me 4 hour’s labour to do the job. Removing the intercooler to test the glow plugs was straight forward and easy, but I have heard that it might be tricky to remove them with a risk if it breaking in the cylinder head?
    Thanx
    Pieter
    Pretoria, Hartbeesfontein
    Thanked: 1046
    Default Re: Glow plugs?
    I would replace all 4 the 2 correct one's might die tomorrow. I had no problem in removing GP's on my Suuz so I presume for the Toy it should be ok, just use the correct tool
    Robert
    '09 VW Caddy Maxi TDi
    '06 Citroen C3 1.4HDi8)
    '97 Isuzu 280 S/C plaasbakkie
  3. The Following User Says Thank You to Tweeling For This Useful Post:
    Feb 2016
    Brackenfell, Cape Town
    Thanked: 27
    Hi
    Just be careful when you remove them, they might have some carbon on them which can make it difficult to remove. I had it once, used lots of penetrating oil and removed over a couple of days. Turn until the resistance is too high, spray oil, turn them back in a bit. Long process, but I was too worried about breaking them.
  5. The Following User Says Thank You to Swiegie1 For This Useful Post:
    Thanked: 36
    Thanx for the replies
    I guess replacing all four wouldn't be that much more work than replacing just two seeing that the intercooler etc needs to be removed anyway.
    I`ll give it a go and hope not to break one. Seems like slow and gentle with enough patience and penetrating oil will be the way to go.
    Oppierotse
    Thanked: 293
    Quote Originally Posted by Pieter C View Post
    [*]What caused the 2 glow plugs to die on 210 000 Km? I have an Isuzu with 638 000 Km that still starts first time every time.
    Isuzu engines have direct injection and doesnt need glow plugs to start.
    98 Hilux 2.8D D/C 4x4
    Langs die rivier, op n berg
    Thanked: 3869
    Al my isuzu bakkies sukkel maar om te start sonder glowplugs
  9. The Following User Says Thank You to Reenen For This Useful Post:
  10. #7
    Ellisras
    Thanked: 1071
    My TD42 Patrol start sukkel sukkel in somer met dooie glow plugs, maar in winter, niks - ek moes een keer 3 ketels kookwater op di inlaatkant van die engin gooi om hom aan die gang te kry. Met werkende glow plugs voel dit asof hy start nog vor die engin behoorlik 1 omwenteling maak.
    Ek vervang hulle nie gereeld nie. Ry nou met n ekstra stel byderhand en vervang net wanneer nodig.
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 857 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 123 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  11. #8
    Robertson/ Larissa, Greece
    Thanked: 4859
    Quote Originally Posted by wiel View Post
    Hang af van watter Isuzu jy praat. Die direct injection modelle start maklik, indirect start maar moeilik sonder glow plugs.
  12. #9
    Thanked: 36
    I am pretty sure my 1994 KB280 has glow plugs.
    Any way, got the 4 glow plugs from Toyota today........
  13. The Following User Says Thank You to Pieter C For This Useful Post:
