Results 1 to 12 of 12
    Jun 2016
    Roodekrans
    Thanked: 33
    Default GV 2.4 Worn valve stem seals?
    Hi guys,
    SWAMBO's GV has done only 135 000kilos and it now seems that the valve stem seals need replacing. It smokes on cold starts and it is getting worse. No smoke during normal driving. It also consumes oil now.
    This car has been maintained meticulously by Suzuki West Rand. Never missed a service.
    How is this possible? The innards of this engine should only start showing wear long after 250 000k's.
    Have any of you guys had this same problem? Is there anything else I should be aware of?
    Do you perhaps know of a good mechanic in the West Rand who could replace the seals for me? The vehicle out of warranty so I don't want to use the stealers.
    Thank you
    Myne: Wildtrak 4x4
    Hare: GV 2.4
    Thanked: 2882
    Default Re: GV 2.4 Worn valve stem seals?
    Change the oil with a good oil and see what happens.
    Cheap oils harden seals, carbon up rings and dont have good detergents.
  3. The Following User Says Thank You to MariusFourie For This Useful Post:
    durban
    Thanked: 1560
    Would it be difficult to change the seals.? never tried it before in a motor where the head is not off but surely its just a matter of taking the tappert cover off and plucking the seals of and re assembling everything again.
    Jun 2016
    Roodekrans
    Thanked: 33
    Thanks Marius. Full synthetic?
    After telling Suzuki's workshop manager that the car smokes on cold start, he suggested that I leave the car there overnight, so he can see what happens when he starts it the next day, when cold.
    He tells me the next day that the smoke "has a rich smell of petrol"! I didn't even bother to argue with him. This smoke smells pure oil. Ek is nie eers naby stupid nie. Maybe he doesn't want to work on the car, not enough money in it for them to open anything? More money in quick servicing? Probably chasing targets...
    I will not be going back there so I need a good indy in future anyway.
    Myne: Wildtrak 4x4
    Hare: GV 2.4
    Thanked: 2882
    Quote Originally Posted by Pierreb View Post
    Cold start means car will purposefully run rich until warm....
    Almost all cars will smell of petrol when cold.
    And petrol doesn't really smoke....
    Thanked: 1979
    +1
    Sent from my iPhone
    Jun 2012
    Thanked: 2708
    problem is once you remove the valve spring the valve will drop into the piston.... There are a few tricks however.
    one I have used with success is to remove camshaft(s) then shove a pantyhose through the spark plug hole into the cylinder (leaving a bit left) turn the crank as far to TDC as you can squashing the pantyhose against the valves, now you can safely remove the valve springs on that cylinder and change the seals. When done turn the crank back and remove pantyhose, repeat for all cylinders.
    Anton Muller
    2012 Q7 4.2 TDI
    Birkin SR20VET race car
    Cape Town Southern Suburbs
    Thanked: 1491
    Any recommendations on what is good oil or how to identify it?
    Jun 2012
    Thanked: 2708
    name brand oils only, anything from shell, mobil, fuchs, liqui moly etc. Check in your service book for the oil spec and make sure whatever you buy conforms to that.
    Anton Muller
    2012 Q7 4.2 TDI
  11. The Following User Says Thank You to mullerza For This Useful Post:
    Thanked: 1491
    And if your owners manual only specifies the viscosity?
    I normally use Shell Helix HX8 synthetic at the recommended viscosity. I always remembered Stephen Van Tonder said Shell is good because it's easy to get the exact oil you use on the road at a Shell garage.
    Only thing he didn't mention is they charge R90 for 250ml of synthetic oil at Shell garages!
    That equates to R1800 per 5L, the same oil that's normally R450 5L at Goldwagen, I suppose you have to pay for convenience though.
  13. #11
    Thanked: 265
    Go to Ravenol Oil in Observatory, and speak to Freddi - he will give you the best oil for your GV, he knows oil backwards.
    http://www.ravenol.co.za
    Suzi Blue , 2008 Nocturne Blue Suzuki Grand Vitara 3.2 V6
    Dobinson's 40mm suspension, Wizerd rock sliders, radiator, sump and diff plates
    Frontrunner RoofRack, NL 2nd Battery Box, Llumar sun protection
    16" Hyundai Tucson rims, 235/70R16 General Grabber AT3 tyres
  14. #12
    Jun 2012
    Thanked: 2708
    then you just buy the right viscosity, also next time buy an extra 500ml bottle from goldwagen and keep it in the boot. VWs are particular about their oil so I always keep a bottle in the boot just in case
    PS all good oils are designed to work with other oils, adding 500ml from a different brand will not cause any issues.
    Anton Muller
    2012 Q7 4.2 TDI
