Results 1 to 13 of 13
    Default Jeep grand Cherokee 3crd 2012 suspension problems
    Hi I am looking for a jeep specialist that can help me with my suspension issues.
    I am from durban but willing to bring it to JHb if neccessary.
    Any help would be appreciated.
    Arno 0833592530
    Sep 2012
    S2950'26.46", E3057'25.92"
    Thanked: 17
    Default Re: Jeep grand Cherokee 3crd 2012 suspension problems
    I used KZN Air Shocks in Ballito for my last batch.
    Great service and decently priced.
    https://www.kznairshocks.co.za chat to Nadia.
    [life is what happens when you're notp aying attention]
    2003 Jeep GC Laredo 2.7CRD
    2011 Jeep GC Overland 5.7 HEMI
    Mar 2009
    Fishhoek
    Thanked: 177
    What is the problem arno? Please keep us informed.
    2010 Eagle Head 5.7 hemi
    Quote Originally Posted by SytheZN View Post
    Thank you Sythe ZN
    I had it there and then the gentelman mentioned that its an electrical issue that needs to be solved first.
    So the issue was a warning light came on, immediate suspension service required.
    Then the battery started draining overnight.
    I replaced the battery and now the front suspension dropped down and refuse to pick up.
    i took it to a guy that works with Jeeps in amanzimtoti on the 10th of Jan and he has ever since replaced the comfy box,and installed a new compressor,its been with him 3 months and the suspension still sags and the battery is still draining.
    I have been without this Jeep since the 20 December 2020.Im slightly frustrated but i know there is someone somewhere that can fix this issue.
    I have lost faith in this Jeep but it drives so nicely(when it does) that im almost willing to give it another chance.
    Sep 2012
    Thanked: 17
    Yeah, mine was sagging as well. Thankfully no electrical issues though.
    I had worn through the front right airspring bellows, so replaced both front. Also did all the bushes in the front while it was apart and a full set of brake pads. They lasted pretty well in my opinion - almost 200k km which is not bad considering I'm hard on my suspension.
    After, while waiting for stock of lower control arms, I noticed it was dropping over the course of a few days. Took it back when the control arms came in and they found a leaking seal on one of the pressure lines which they sorted out no questions. Been fine since.
    I wish you luck, electrical gremlins are a pita.
    it gives me some hope knowing that you have sorted out your problems. I will send a report here if we do manage to solve this issue.
    Thanked: 4941
    Quote Originally Posted by arno65 View Post
    Arno, chat to Bulli.
    He looks after many WK2's and knows them very well.
    His number is 0625434275.
    A WK and 8J.
    Quote Originally Posted by Rainier Vermaak View Post
    Thank you Renier ,they seem to have found the problem,a corroded fuse box that causes the comfy box to short stopping the power to the compressor.Ill call Bulli if these guys cant solve it by next week.
    Thanked: 84
    Corrosion on the coast is a pita!
    Oct 2021
    MOOIKLOOF, PRETORIA, 0059
    Hi I have a 2014 SRT and need a service. I am based in Pretoria. Is there somebody that you can recommend? The mileage is 90k.
    At the moment the battery is drained for some unknown reason and the alternator was just replaced a few weeks ago and strangely enough the drivers window is just not closing. I need a good reliable person to work on the car and fix it. Please can you recommend someone?
    Thanked: 831
    Quote Originally Posted by MK12 View Post
    You can't go wrong with Bulli, and you are PTA based, which makes things even simpler. Give him a call, he is in Silverton.
  12. The Following User Says Thank You to Commander For This Useful Post:
  13. #12
    JHB
    Thanked: 88
    Call Bulli, you won't find a better person to look after your Jeep
    Baa Baa Black Jeep
    2004 WJ Jeep 4.7 HO Overland
  14. The Following User Says Thank You to Ren For This Useful Post:
  15. #13
    Thanked: 4941
    Nor trying to sound like a stuck record but Bulli would be the best person to talk to.
    062 543 4275
    A WK and 8J.
