Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 121 to 140 of 143
  1. #121
    Wartburg
    Thanked: 2439
    Default Re: Is a portable braai a necessity when overlanding.
    Quote Originally Posted by ed rouillard View Post
    I realised that i have a near new foldup brai known as a Pyromid. Got 2 from a guy who was going to make it locally and gave one to a mate, who used it for years in the bush.
    Took it out and it is a really nice piece of kit - braai, oven, and used briquettes i think. Comments?
    We looked at importing some of these as a group buy - this is probably my ultimate lightweight braai/oven. They also came with throw away bags to collect the fat/ash. No cleaning was required at all
    Mike Lauterbach
  2. #122
    Dec 2016
    Bryanston
    Thanked: 183
    Pyromid:
    I have test used it once way back and it was great. Very well made IMO.
    Packs almost flat about 20 mm and has grill and oven option. Resists wind as well.
    Not light at about 4.5 kg but versatile.
    Am using different kit in my overlanding and also an approach to have a fire, cook, heat water all in sequence and without much impact on environment.
  3. #123
    JHB
    Thanked: 211
    This came up on the LCCSA website today
    https://draaibraai.co.za/
    Looks quite nifty
  4. The Following User Says Thank You to Woolf For This Useful Post:
  5. #124
    Jan 2020
    Kidd's Beach
    Thanked: 82
    Quote Originally Posted by Woolf View Post
    Looks quite nifty
    lovely idea. I wonder how long the wing nut holding the spindle shaft will last in the coals . a great idea and easy and compact. I would like to know weight and height the grill can screw up to from the coals. a fantastic concept .
  6. #125
    Sep 2012
    Canberra
    Thanked: 32
    I never camped in RSA where I needed a portable braai - There were either spots available or you could make fire on the ground.
    But in Oz I know have one of these
    https://youtu.be/GUq4I_1BI2Q
    as its often a requirement to have fire contained and of the ground - I love it.
  7. The Following 3 Users Say Thank You to pfgrobler For This Useful Post:
  8. #126
    Thanked: 455
    Quote Originally Posted by Khakibush View Post
    Swambo's uncles made the exact braai but a built in version with 4 segments, opposite segments were mesh or plate steel.
    They were about 160cm in diameter. 25mm Square thread adjusted height very fast. This was about 40 Years ago.
    Very nice idea.
    Fortuner D4D
    Hilux 2.7 4x4 Raider.
    Sp Tourer
  9. #127
    Thanked: 46
    Quote Originally Posted by JCMN View Post
    We bought a Madkon braai, couple times in KNP we have arrive at the camp and there's no braai's available and a lot of the braai's in the Drakensberg are burnt through and you cant use them.
    To all the Madkon owners, how do you clean the ash out without getting your finger caught on all the moving parts?
    with difficulty.... I turn mine upside down, grab the legs and shake it up and down - makes a racket and is messy..
    Putta
    Landcruiser 105
    BL Miskruier B850
  10. #128
    I have too experience the issue of not having adequate braai facilities at some camping spots or they have a small brick built or wieldop braai, whereby you can't make fire and braai, if coals are out before you completed braaiing or making potjie, then it's an issue. I now use my portable braai for braaiing or potjie, skottel etc. and even as a firebowl and use the camp fire for feeding coals.
    I now supply these braais. It fits neatly in a plastic dairy crate with small grid.
    It is designed as a small braai for couples camping. May not be the answer for big family camping.
    They not the lightest but prob will outlast you. Weight 8kgs.
    Constructed of 3mm steel with 8mm base with heavy duty coal grid. You can attach rods to the legs to heighten the braai if necessary. Can make coals, can use sticks/kindling (potjie), can add coals while braaiing.
    Easy to clean, just tip ash and rinse out.
    Cost R750. [email protected] 0824659069.
Name:	On The Go Camping Braai 1.jpg
ID:	612991   Click image for larger version.
Name:	On The Go Camping Braai 2.jpg
ID:	612992   Click image for larger version.
Name:	On The Go Camping Braai 3.jpg
ID:	612993   Click image for larger version.
Name:	On The Go Camping Braai 4.jpg
ID:	612994   Click image for larger version.
Name:	On The Go Camping Braai 5.jpg
ID:	612995   Click image for larger version.
Name:	On The Go Camping Braai 6.jpg
ID:	612996   Click image for larger version.
Name:	On The Go Camping Braai 7.jpg
ID:	612997   Click image for larger version.
Name:	On The Go Camping Braai 8.jpg
Name:	On The Go Camping Braai 9.jpg
  11. The Following User Says Thank You to Weptac For This Useful Post:
  12. #129
    Hentiesbaai
    Thanked: 15
    Google "madkon braais" and have a look at their portable stainless steel braais. Alternatively a braai same as/similar to that posted by IcePick88. Mine has a stainless drum and grid. Problem with these are that if the grid is raised above the drum, the wind tends to blow the heat away from underneath the grid.
    Toyota - 2 LED Interior Light
  13. #130
    Jun 2015
    Thanked: 35
    If there are just two of you as we are when overlanding have a look at the latest version of the Swannie Braai. It's marketed by a guy at Grotto Bay on the Cape west coast and now available through Takealot. Google it. It's made of stainless steel including its grid which can hold meat, wors etc for two adults. Before cooking the meat we also put a sizeable hot water kettle on ours to heat water when the wood is still burning down for coffee or washing dishes.
    The best feature of this braai is that after use it folds flat and with its grid fits into the flat canvas bag that comes with it which will stow under your seat in most vehicles. Another advantage is that it needs far less wood to cook a meal than most other braais as it contains the heat so well; in fact the manufacturer claims you can cook wors on it with just rolled up newspaper. It will certainly do a couple of nice big chops or steak plus wors, heat up a can of baked beans and maybe even some toasted saamies or bananas afterwards all with around five or six pieces of good braai wood or some charcoal. Either stand it in/on a campsite portable or brick braai place or just a few rocks or bricks on the ground. Works well when it's windy due to its box like design. For two people it's the best portable braai we've ever had.
    No, I'm not a sales agent for Swannie Braai.....
    Jambo7
    London to Sydney 1968 East Africa 2001 Southern & East Africa 2004 & 2006
    Australia 2007 Cape Agulhas to North Cape, Norway 2009/10
    Ushuaia, Argentina to Deadhorse, Alaska 2012/13, Southern Africa 2015 & 2017
    DON'T JUST DREAM IT - DO IT!
  14. #131
    Jan 2017
    Thanked: 161
    About 7 or 8 years ago I was “rewarded” with a mini Weber called a Smokey Joe when spending more than R2000 fitting new tyres to Swambo’s Honda. It sat unused in the garage until Lockdown Level 5 last year, when I was looking for something small & convenient to use every day. (I was angling to order a small Japanese Hibachi - Swambo said use that bloody thing that’s sitting in the garage the past 7 years!
    So out it came...and now I use it at least 4 or 5 times a week cooking supper for the two of us!
    Small, compact, easy to dismantle if you’re traveling (3 wingnuts hold the legs on) with all the advantages of a Weber kettlebraai!
    And best of all, when finished cooking I simply close all the vents and kill the coals, re-using them again at least two more nights, perhaps with the addition of 2 or 3 additional briquettes!
    This will definitely become a part of my overlanding kit in future to use when a conventional braai fire is not possible or convenient.
    If you want to go into the bush, take a Ford. If you want to get back, take a Landcruiser!
    Series 80 'Cruiser GX Diesel 1996
    Cooper ST Maxx 265/75/16 tyres;
    ARB bullbar; 9000kg T-Max winch; Outback roofrack; Double fuel tank; Outback Extreme spare wheel carrier x 2; Air Spring boosters; Racor diesel filter; NL dual battery set-up; 2 x 100w solar panels; Big Country gullwings, Front Runner drawer system; Stofpad 4x4 drop-down fridge slide; NL 78-litre double door fridge/freezer; NL 60-litre freezer; Eeziawn rooftop tent; Eeziawn awning.
    SWAMBO: Honda CRV 2.2 Diesel
    Previously: '98 Defender 110 HT TDi, Landy SIII S/W, Hilux D/C 4x4,
    Isuzu 2,3 4x4, Isuzu 2,0 4x4, Isuzu 1600 4x4, Chev Nomad, Cheetah beach buggy!
  15. #132
    Thanked: 1636
    I just find it hard to believe this thread is already 7 pages long?
    A very hot topic it seems.
  16. The Following User Says Thank You to Peter Connan For This Useful Post:
  17. #133
    Jan 2010
    Thanked: 5784
    Well, it must be old age and I never thought I would say this, but we have decided this weekend that a small portable charcoal braai definitely have some merit in certain scenarios and for only 2 people.
    On the shortlist is a Cobb.
    For those who have a Cobb: does the meat taste like proper 'braaivleis' with the smoky flavour seeing it does not really have the traditional grid, but more of a plate? How effective are the stones as apposed to charcoal and the foil sleeves that goes into the moat?
    Christa
  18. #134
    Thanked: 6796
    Think of the cobb as a small Weber (kettle braai)
    Everything is the same it just uses less charcoal and is smaller.
    As with the Weber or Kettle braai it is not really suited to "braai-ing but is better for roasts. How ever, it does have an attachment that you can use for grilling, and one for frying, and one for braai-ing..
    https://cobbonline.co.za/product/cob...ith-fire-grid/
    Edit:
    Those foil sleeves work very well in keeping the Cobb clean
    Andrew van Staden
  19. The Following User Says Thank You to Hedgehog For This Useful Post:
  20. #135
    Apr 2012
    Bela Bela
    Thanked: 344
    Agree that the Cobb is best for roasting. I have a small portable braai that I take. Just big enough for 2 people.
    Pete Williamson
    ADVENTURE BEFORE DEMENTIA
  21. #136
    Jan 2010
    Thanked: 5784
    Thanks gentlemen, yes I suspected the Cobb is more for roasting than real 'braai-ing'. Still looks like a nifty piece of equipment though, just not sure how quickly the fascination of one would pass.
    The Anywhere Products GI 50 braai mentioned earlier looks like a better contender then. Just a bit surprised by it's 10 kg weight.
    Christa
  22. #137
    Mar 2009
    Thanked: 135
    I have the same braai, after the last one got pinched. Cheap (R200 then), works well.
    Quote Originally Posted by IcePick88 View Post
    I bought one of these from builders warehouse. Still goes into it's box when travelling after use. Works well. Cheap. Disposable.
    Attachment 611105
    Stuart
    2006 Toyota Land Cruiser 100 4.7L V8
  23. #138
    Thanked: 46
    Edit:
    those foil sleeves are a lifesaver !!! we also use spray and cook on all surfaces to faciltate cleaning - makes awesom "all in one" meals flatties with veg
    Putta
    Landcruiser 105
    BL Miskruier B850
  24. #139
    Thanked: 442
    Dis jammer ek het nie geweet jy stel belang in die Cobb toe ons by die kamp ontmoet het nie - die Cobb was by ons.
    Ek vind hom regtig handig.
    As jy naby Raslouw is, is jy welkom om te kom kyk. Hy is handig met baie goed; nie met alles nie. Tjoppies, wors, hoender en ander groente smaak vorentoe.
    Vir steak wat baie warm hitte soek, is daar 'n ekstra plaat en kole mandjie wat help daarmee.
    Make it happen!
    2018 Mobi Lodge
  25. The Following User Says Thank You to Toccata (Roelof) For This Useful Post:
  26. #140
    Jan 2010
    Thanked: 5784
    Quote Originally Posted by Toccata (Roelof) View Post
    Dankie vir die inligting, Roelof. Die idee van 'n Cobb het juis di naweek met die kamp by my man opgekom.
    Ons was toevallig gister by Outdoor Warehouse en hulle het een daar gehad wat ons na gekyk het. Lyk handig verseker, effens groter was wat ek my voorgestel het.
    Christa
