Results 1 to 5 of 5
    Jul 2019
    Snor City
    Default Engine stuttering in reverse
    2012 Cherokee 3.7 Ltd AT
    Hi,
    I have a weird problem on my Jeep. The engine stutters violently in reverse as if it is misfiring on some cylinders and the power steering "shakes" the steering wheel when turning. Putting it back into drive all appears to be fairly normal again.
    If anyone experienced a similar problem & solution please let me know? Other forums suggest it's the coils but how can this only happen in reverse? The coils are quite expensive to replace just to see whether that is my problem.
    Thanked: 4768
    Default Re: Engine stuttering in reverse
    Contact Bulli, he should be able to answer you.
    0625434275
    A WK and 8J.
    Jul 2019
    Snor City
    I have an update if anyone is interested. It's the ignition coils. All of them had to be replaced. And 6 months later they are acting up again so I guess that coils are now considered maintenance parts that need regular replacement
    Thanked: 20024
    Coils will fail due to crap cords and crap plugs, among others. The question still stands: did you talk to Bulli or Eben?
    Two of the best Jeep guys in Snor City.
    Jakes Louw
    Apr 2021
    Thanked: 34
    Sounds more like Transmission to me, could be a Solenoid in the trans that is stuck open (some forward drive solenoid) and fights the reverse when its engaged. I'm currently in this boat with a conversion motor.
