Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 50
    Thanked: 1294
    Default Lithium 12Ah on a gate motor
    We have just tested a 24V 12Ah imported lithium on a very heavy gate. It worked for 3 days and at least 250 open and close cycles without recharging.
    Very impressed......
  2. The Following 4 Users Say Thank You to ekkekan For This Useful Post:
    Thanked: 2186
    Default Re: Lithium 12Ah on a gate motor
    What gate operator (motor) did you use?
    Thanked: 1294
    Test was done on a heavy duty 24V Gemini sliding gate.
    Thanked: 2186
    Ah, D10. I thought so. Thanks.
    Edit.
    Sorry, I'm dreaming. Its not a Centurion. But I guess similar to D10.
    Thanked: 1294
    Edit.
    I don't know much about the other makes but a few of them use the very same DC motor from the same factory.
    Sep 2012
    Thanked: 88
    Interesting
    what make? indication on pricing?
    Its not about how fast you are but about how quick you get there...
    Thanked: 1294
    Quote Originally Posted by Die$eL View Post
    Interesting
    Info on this imported from China battery is scarce. All labels were removed or it came in black propper battery box with bolted terminals.
    I would build one using the loose cells from lithiumbatteriessa a number of guys have built for their solar systems. They have a super cheap 6A for about R65 each. Using 8x3.2V for 12V will be 12Ah.
    I heard that Bluenova have the 7Ah look alike for about R1000 - info from a client.
  9. The Following 3 Users Say Thank You to ekkekan For This Useful Post:
    Thanked: 849
    I made my own little 12v one from lithiumbatteries.co.za for my swing gate about 8 months ago. Works perfectly. Need to make a 24v one for my garage door.
  11. The Following User Says Thank You to Kortgat For This Useful Post:
  12. #9
    Thanked: 1698
    What needs to change on the gate or alarm control circuits that would normally charge the lead acid battery?
    It's not just plug and play, or is it?
    "The problem with internet quotes is that they are very often unverified."
    -Abraham Lincoln
  13. #10
    Thanked: 849
    Quote Originally Posted by MarcR View Post
    Yes, just the standard charger works fine on mine. No need to get fancy.
  14. The Following User Says Thank You to Kortgat For This Useful Post:
  15. #11
    Thanked: 1294
    We have not done any testing yet. I would guess one will have to look at each PSU circuit. Some give out 13.6-14.2V. As a minumum I would try with a 5A external power supply to increase the charge rate due to LS. Further a diode used at the external power supply to prevent the OE psu to input into the external unit. Volts to battery to be checked as some units will have a diode causing a 0.6Vdrop between the psu and battery. In this case the psu will give an output of about 14.4V. Doing no changes could at times cause the lithium not to charge to 90%+ and lead to a lower capacity.
  16. The Following 3 Users Say Thank You to ekkekan For This Useful Post:
  17. #12
    Thanked: 849
    Agree, and there it gets really technical, but does it really matter if the damn thing only gets to 90% charge? It has soo much capacity anyway compared to the stupid lead acid, so spending all that money for special chargers and modifications is just not worth it.
    In a proper home UPS installation you would definitely worry about all that, but I just don't see the point for a gate that needs a bit of battery back-up. Mine has been in there for 8 months, no modifications and runs perfect.
  18. The Following 6 Users Say Thank You to Kortgat For This Useful Post:
  19. #13
    Thanked: 1294
    I fully agree with you. That is what I will do but the other side of the coin is you suggest something for the lay man and a gadget sets off the custom smoke bomb and you are blamed
    There could be risk involved.
  20. #14
    Thanked: 1389
    I've replaced the 4 x 12v 7ah batts in my 24v APC UPS with 16 x 6ah lithium cells using 2 x BMS's - got it wrong with one BMS being too small, so I got a 2nd one. Sorted.
    Charge voltages, bleh, let the BMS sort that.
    Price was about R1360 for 2 x BMS and 16 cells, close as damn to 4 x 9ah lead acid cells.
    Political Correctness
  21. The Following 2 Users Say Thank You to the_terrible_triplett For This Useful Post:
  22. #15
    Garsfontein
    Thanked: 680
    Have a Blue Nova 11ah in my electric fence box and 2 x Blue Nova 8ah batteries in my Eaton 1500VA UPS for a year now, no problems yet.
  23. The Following 2 Users Say Thank You to supersunbird For This Useful Post:
  24. #16
    Mar 2011
    Walker Bay
    Thanked: 1537
    Could we use these batteries on our house alarms.
    I find with load shedding I am continually have to replace the standard
    alarm batteries.
  25. #17
    Thanked: 1389
    I find with load shedding I am continually have to replace the standard alarm batteries.
    I asked that question too, my alarm supplier said yes, but they need to do something about the existing built in charger, as it is not that cool.
    So just check that IF it is a factor.
    EDIT: Mine now runs off the APC UPS.
  26. The Following 2 Users Say Thank You to the_terrible_triplett For This Useful Post:
  27. #18
    Feb 2013
    Thanked: 2431
    Which BMS's did you use?
    I want to build a battery around 24 to 30 Ah 12V using the small 6 Ah sells, so will need something which could handle a combo of series and paralleled cells. Or do you just series your cells to up your capacity and don't really worry about the BMS not seeing each individual cell? So in effect the BMS only sees 4x 3.2V 24Ah cells rather than 16x cells?
    "The man who does not read has no advantage over the man who cannot read" - Not Mark Twain
  28. #19
    Thanked: 1389
    Got two of these: https://lithiumbatteriessa.co.za/col...4s-12v-lifepo4
    And connected 16 of these cells, 8 per BMS: https://lithiumbatteriessa.co.za/col...e-battery-call
    Connected them 2P4S having made tiny little busbars
    Made my own tiny busbars, like the pic, for between the parallel cells.
  29. The Following 2 Users Say Thank You to the_terrible_triplett For This Useful Post:
  30. #20
    Feb 2013
    Thanked: 2431
    Thanks, maar ek sien hy stock nou 50Ah selle ook, so dalk moet ek net met hulle gan vir bietjie spaar capacity.
