Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 121 to 140 of 153
  1. #121
    Undisclosed
    Thanked: 2226
    Default Re: Project 2: Defender 130 V.3-Amigos ??
    Quote Originally Posted by Scheepers85 View Post
    instead of Donaldson, why not just see if you can get a used Defender TDI or V8 filter. They both came with Donaldson clones. The V8 is a much bigger can, but the TDI filter should be sufficient.
    I don’t know how Land Rover thinks they made an improvement going to the silly plastic box and panel filter after the great filtration they had on older models
    The challenge is to get a box with the correct inlet and outlet orientation for the mounting position.
    But yes, generally the round filters are all Donaldson concepts. Works the same way.
    “The price of stability is unpreparedness.”
  2. #122
    Undisclosed
    Thanked: 2226
    It is really hard when work interferes with so much higher priorities.
    I am currently working my butt off as I work a notice two months, so there is a lot that needs my attention.
    As I pushed 7 days a week for months now, I could not put in a full Saturday and Sunday again and we did about 4 hours each day this weekend.
    This week was again a bit of a dead week, but Cobus managed to tidy up many of those patient little bits.
    Over the weekend, we fixed all the remaining parts and too patience to route the wiring harnesses so that there is as little spaghetti as possible.
    All the radiator pipes, accept for one is fixed (another pipe not supplied...) and we are very close to swing the motor for the first time.
    All that still remains is that the wire to the crank position sensor broke off as it was brittle, and the plug has to be replaced.
    Holding my breath for this week.
  3. #123
    Robertson/ Larissa, Greece
    Thanked: 5114
    Are you changing jobs Koos or something completely new?
  4. #124
    Undisclosed
    Thanked: 2226
    Defender 130 is your clue.
  5. #125
    Undisclosed
    Thanked: 2226
    Almost there.
    Yesterday everything was filled up.
    Fuel pump runs, Motor swings, but no fire yet.
    Battery on charge over night.
    Lets see today.
  6. #126
    B-gowrie Randburg
    Thanked: 422
    Quote Originally Posted by biltong View Post
    Almost there.
    Lets see today.
    I only start on 3,
    ... but I think the glows pull 20A each ...
    though that load may fade at/b4 starter calls ... ?
    2002 Defender 130 DC HCPU. :
    Own the road... Any road ...
    ‘1981 R-Rvr Classic 2-Dr 3.5L V8 :
    The Greatest Rover.
    ‘1975 Series3 88 PUP :
    Simply ... Classic ...
    ‘2017 Metalian Mini ...
    A Home from Home
  7. #127
    Apr 2021
    Thanked: 155
    Almost there.
    Lets see today.
    fuel bleeding is a bit of a pain on TD5s.
    While on charge to make sure the battery lasts, bridge the terminals for the fuel pump relay, and leave it to run for about half an hour. This is far more effective than doing the normal “pump the pedal to the floor 5 times bleed”
    then, once you are pretty sure there is no more air, turn the ignition on, pump the pedal to the floor 5 times slowly, but on the 5th keep your foot to the floor, and keep it there while cranking the motor over.
  8. #128
    Dec 2014
    Thanked: 3159
    The 2 times I did my head, I did the 5 pumps trick a few times, and then used a squirt of Quick Start. Worked a treat.
    Cheers,
    John Kilfoil
    Rover P6
    Range Rover P38 HSE
    Moto Guzzi LeMans
    Aprilia Tuono V2
  9. #129
    Undisclosed
    Thanked: 2226
    Nope. No Start yet.
    We had to trace some pipes and the previous owner messed around at the fuel filter.
    We only get flow on the LP side of the pump.
    Today I will get Cobus to remove the fuel filter housing and make sure the orifice in there for the one return line, is open and that the fuel filter is new.
    If that does not work, then we will have to remove the tank and take the fuel pump out.
  10. #130
    Mar 2015
    New Germany
    Thanked: 985
    Nope. No Start yet.
    have you got the white air bleed off in the outer back barb fitting
    also there is a red beak not return valve also in the filter, normaly that is on the inner front barb, where I seen them, this is on the return line from fuel cooler, some say it should not be installed there but on the inner back barb, which is the LP supply to filter, so when you stop engine it helps stop fuel running back to the fuel tank in the LP line
ID:	616779   Click image for larger version.
    2005 Defender TD5
  11. #131
    Undisclosed
    Thanked: 2226
    I have no problem with a "Boer maak 'n plan"...
    But FFS, it can't be the standard permanent repair.
    I still cannot figure out how this TD5 got diesel. The pipes were totally misconfigured - and butchered for that matter.
    We will replace all the fuel hoses with a high quality 8mm hose this morning, all the way from the tank to the engine bay, as well as all the pipes between the filter and the tank.
  12. #132
    Undisclosed
    Thanked: 2226
    Fuel circuit sorted!
    Pump is silent now.
    Waiting for battery to charge.
  13. The Following User Says Thank You to biltong For This Useful Post:
  14. #133
    Thanked: 4042
    Waiting in antici..................pation!
    Ettienne de Kock
    1998 Disco Tdi
    1959 SII 88"
    197? RRC
  15. #134
    Undisclosed
    Thanked: 2226
  16. The Following 5 Users Say Thank You to biltong For This Useful Post:
  17. #135
    Jul 2015
    Kloof
    Thanked: 2362
    That was a lovely, prompt start. Well done.
    2015 Suzuki Grand Vitara Summit M/T
  18. The Following User Says Thank You to Ian.McM For This Useful Post:
  19. #136
    Jul 2010
    Pinetown
    Thanked: 2592
    Perseverance wins again.
    Peter Hutchison
    Platkar = Chevy Spark 1.2
  20. The Following User Says Thank You to Peter1949 For This Useful Post:
  21. #137
    Thanked: 2850
    Bliksem n Td5 klink darem mooi. Wonder of ek plek het langs die nuwe Series
    Disclaimer - All my posts on this forum is without prejudice, is based on my fair assumptions or perceptions, might not be factually correct, is in no way intended to cause harm to anyone and is acted upon at your own discretion.
  22. The Following User Says Thank You to George For This Useful Post:
  23. #138
    Undisclosed
    Thanked: 2226
    Low by my standards. I want that half turn start...
    Quote Originally Posted by Ian.McM View Post
  24. #139
    Undisclosed
    Thanked: 2226
    Baie plek. Maak plan.
  25. #140
    Apr 2021
    Thanked: 11
    Bliksem, dit was nogal 'n mooi klankie na al daai werk.
  26. The Following User Says Thank You to biltongjr For This Useful Post:
