Results 1 to 20 of 23
    Bellville CapeTown
    Default Bent frontdiff casing on a Jimny !
    I had the bad luck of hitting a ditch at not such a high speed and bending my Front diff casing .
    Has this happened to other Jimny owners , or was my casing just a bad one ?
    I was still accerarating in second when a very bad little dich cought me out .
    Funny thing is my wheels are still running true , and I only noticed it when someone pointed it out to me . Even on tar I do not feel any difference in the steering.
    But according to TWT's machine my chambers is out by Negative 2'30deg left front and 3'30deg right front .
    Now busy trying to source a new Diff casing .
    2015 Ranger T6 3.2 4x4 Auto (Making the long roads short)
    2014 Kawasaki KLR 650 ( Work and Play )
    2010 Jimny : 1.5" lift , 29mhz , Custom Roofrack & Bullbar (Comfort + Fuel economy)
    2006 Mazda Drifter X LWB ( Work )
    1999 Kawasaki KX 250 ( Adrenalin is my drug of choice )
    1981 Land Cruiser 2H Bakkie ( The legend ) Sold
    2006 Kawasaki KLR 650 ( Touring and Farm transport ) Sold
    1986 SJ : V6 , 300mm lift & 32" BFG muds ( Long time dream build ) Sold
    1985 SJ 410 ( Still to be modified )Sold
    Just point it and plant it !!!
    Thanked: 75
    Eina!!!! Good luck! Where you on a track and 4x4ing or was it on a dirt road?
    Bellville CapeTown
    Quote Originally Posted by cruzer244 View Post
    Just a mild sunday morning 4x4 drive .
    May 2008
    Thanked: 304
    Ouch, hope you get sorted.
    What did you hit in the ditch? The other side dirt wall? Or a rock?
    Flip
    Awesome: Suzuki Jimny;
    Bellville CapeTown
    Quote Originally Posted by Flipside View Post
    Yes the other side of the ditch . Suzuki qouted me R6900 exc Vat for a new DIff casing .
    Jul 2009
    Thanked: 568
    Before you buy a new diff casing, take it to Mark @ Maniac. He's has sorted quite a few out.
    Jun 2007
    Thanked: 77
    Any good engineering shop will sort it fot you. Time foe a truss
    V51JP
    Namboyz Rule
    Jul 2009
    Thanked: 568
    Her is the truss he made for mine.
    Jul 2010
    Thanked: 15
    Jimny needs all the ground clearance it can get. A truss like that will turn Jimny into a stootskraper.
    Bellville CapeTown
    Quote Originally Posted by XJ Junkie View Post
    That would work nicely , but I do not think Suzuki would like that while the Jimny is still under warrenty.
    Jul 2009
    Thanked: 568
    Quote Originally Posted by superduper View Post
    You might get away with having it on top, like my last one.
    Quote Originally Posted by bernard.visser View Post
    how much do they like replacing axles under warrenty? :-)
    andre` Guest
    I am fitting sleeves inside my JK`s diff. Can it be done for a Jimny diff?
    Bellville CapeTown
    luckily my diff is sorted !
    There is a Guy in Somerset west that repair stock cars , and he also have the tools to straighten any diff .
    R3800 per diff
    He did mine For R2800 , says that it was way easier to do mine as the Landcruisers and Landrovers he did before .
    Dropped it off at 11 , and was done by 5
    Very nice guy , made space for me , so I could leave on my Honeymoon the next day .
    If anyone need his details , just PM me and I will send it on .
    Mossel Bay
    Thanked: 428
    In the spirit of learning, and with that the use of the correct terms, I want to clear something.
    I suspect you bend the axle tube where it joins the diff casing, not the diff casing itself, which is rather difficult to bend, dent yes, but bend, nie sommer nie.
    Could you confirm.
    Cobus
    Jimny
    Bellville CapeTown
    Could you confirm.
    I actually bent both , but it is only by 2.3 left and 3.3 Deg Right!
    The diff casing bend in the middle at the welding , probably due to the welding causing the metal to be a bit weaker .
    May 2008
    Thanked: 304
    Great to hear you got sorted, congrats and enjoy the trip
    Flip
    Bellville CapeTown
    The honeymoon turned out very nice !
ID:	192037   Click image for larger version.
ID:	192038   Click image for larger version.
ID:	192039   Click image for larger version.
ID:	192040   Click image for larger version.
ID:	192041   Click image for larger version.
    Norway
    Thanked: 355
    Awesome!
    Glad the Diff got sorted.
    Mitsubishi ASX AWD top spec. - stock
    Land Rover Defender 90 2.8i - OME lift on 33" muds, bullbar, racks, freeflow.
    Jeep Grand Cherokee 3.0 CRD WK - Mud terain 32's, Spacers, Lift kit, GDE Tune.
    Jeep Wrangler Rubicon 3.8 JK - Mud terain tyres. Aftermarket mufflers.
    Jeep Cherokee
    3.7 Sport KK - 40mm EFS lift, Mud terrain tyres, Spacers, skids.
    Jeep Cherokee 3.7 Extreme Sport KJ - 40mm spacer lift
    Suzuki Jimny ジムニ - EFS lift, ARB bullbar, Custom Maniac Rocksliders, Mud tyres, etc etc.
  19. #19
    Mossel Bay
    Thanked: 428
    Nou wonder ek maar net oor daai gebuigde diff, en wat lyk soos 'n duik op die bonnet, en voetspore op die bullbar en daai foto van die windpomp.
    Cobus
    Jimny
  20. #20
    May 2008
    Thanked: 304
    Hmmm, ja, nou begin die prentjie beter inmekaar steek
    Flip
  1. Jimny gravel travel the pulpit
    By vise in forum Suzuki
    Last Post: 2014/01/12, 07:59 PM
  2. Help me compare a D90 Puma to a Jimny
    By DCR in forum Land Rover
    Last Post: 2014/01/07, 10:56 PM
  3. Jimny 5dr 1.5d
    By 4x4tjie in forum Suzuki
    Last Post: 2011/07/15, 10:48 PM
  4. First road trip with Jimny
    By Nys in forum Suzuki
    Last Post: 2011/05/17, 09:42 AM
  5. 40th anniversary of the Jimny
    By wizerd in forum Suzuki
    Last Post: 2010/04/23, 08:38 AM
