Results 1 to 5 of 5
    Jul 2013
    Thanked: 541
    Question A Garmin question
    I have a Garmin NUVI, base model, that I bought in 09.
    it has now started just giving me a map of Africa, still gives speed and what street I am on, but unless I put in a destination, the live road map is gone.
    Can it be re set? Or is it as I suspect, past it's sell by date and toast?
    Mark Backler
    09 Kyron, the Korean Snail.
    NO Meeow!
    Blanked EGR.
    Thermo Electric Cooling fan.
    Johannesburg/Prague
    Thanked: 84
    Default Re: A Garmin question
    You can reset to factory default Hold power switch and bottom right corner of screen at the same time.
    Normally these older Garmins one needs to clear out your saved destination as the memory gets full
    Pajero 3.2 DID Gen 4 Standard for now
    Platcar Alfa Giulietta 1.4 MA
    Swambo Volvo S40 T5
  3. The Following 3 Users Say Thank You to 12richardk For This Useful Post:
    4 Ways
    Thanked: 37
    Download Garmin Express on computer... Connect nuvi and update
    Who Dares Wins
    Logic will take you from A to B
    Imagination will take you everywhere
  5. The Following User Says Thank You to eagle eye For This Useful Post:
    Johannesburg/Prague
    Thanked: 84
    Quote Originally Posted by eagle eye View Post
    Worth a try but generally the updates are for location areas but you can see what the update are
    Swambo Volvo S40 T5
  7. The Following User Says Thank You to 12richardk For This Useful Post:
  8. #5
    Jun 2008
    Terenure, Kemptonpark
    Thanked: 195
    Go to settings, maps, and then at the bottom, map info.
    Maybe the map set is not ticked?
  9. The Following User Says Thank You to LouisXander For This Useful Post:
