Results 1 to 6 of 6
    May 2008
    Thanked: 185
    Default Inverter Welder and Generator
    I have a bit welding to do at a remote place, but I do have a 160A inverter welder and a 6.5kw Generator, can I do this with out destroying anything? Or should I rather just go and rent a portable petrol welder from a tool rental place?
    SPOON!
    Jun 2008
    Hillrise, Kempton Park
    Thanked: 1967
    Default Re: Inverter Welder and Generator
    No
    An inverter welder cannot work from a genset. It will for a short while.
    Rent a petrol welder for the job.
    Johan Maree
    Isuzu 300 d-tec
    MB Gwagen G350 Bluetec
    Nissan NP300 2.4 4x4
    Conqueror UEV-25
  3. The Following User Says Thank You to JohanMaree For This Useful Post:
    Kriel
    Thanked: 86
    We use an inverter air cooled welder with a 5kw gen for welding work around the farm....no problem...air cooled welder use only around 0.6 units electricity for a constant 30 minutes welding work with 2.5 rods.. .i do however think you'll run into trouble if you use an oil cooled welder with a gen....
    Kriel
    Thanked: 86
    Quote Originally Posted by John.oosthuizen95 View Post
    Also a air cooled inverter welder pulls a lot less amps on the electric current than an oil cooled welder...
    Thanked: 2575
    I have done about 3000m of palisade fencing with an Afrox 140 invwerter and managed to stop this baby in the first day. We finished the job with a mig and a 650genset but that was just two 100mm welds every 20 min.
    As johan said rather hire a custom unit if you have a lot of welding to do.
    Henk
    Follow us on Facebook
    Gaborone, Botswana
    Thanked: 1459
    My 200A Matweld doesn't work off a 5kva generator.
    Kobus
