Results 1 to 19 of 19
    Apr 2012
    Jhb
    Thanked: 151
    Default LC 200 dead batteries
    I have a LC 200 SW 2010 model that comes standard with two batteries.
    Does it need both batteries to start?
    I dont want to try in case I damage something expensive!
    Please advise.
    Ron
    Apr 2012
    Jhb
    Thanked: 151
    Default Re: LC 200 dead batteries
    I was told by someone today that the Landcruiser 200 has its two batteries in series for the starter.
    So the starter is 24 V and the rest of the electrics are 12 V.
    Does anyone know if this is correct?
    Kathu
    Thanked: 3933
    Quote Originally Posted by RonS View Post
    Batteries are in parallel.
  4. The Following User Says Thank You to grips For This Useful Post:
    San Miguel De Allende
    Thanked: 573
    My understanding is that those amps are required to kick that big motor. Iíve never measured it, but my gut tells me it is 12v. The vehicle will start with a single battery if one dies, with difficulty, but it needs those extra amps.
    Gavin Pike
  6. The Following User Says Thank You to gavpike For This Useful Post:
    Dec 2010
    Thanked: 165
    Wow interesting thread. Do you'd need two cars then to jump start a 200 as you'd need to boost both batteries up to voltage?
    2019 Ford Everest 3.2 AWD
    2013 Suzuki GV 2.4 sold
    2010 Suzuki Jimny sold
    Thanked: 573
    Quote Originally Posted by GKE View Post
    That's exactly my point. You can jump start a LC200 with one vehicle and with decent jumper cables (not the P&P ones). If it was 24v you would really struggle. Have jumped a number of them with my vehicle idling.
    Gavin Pike
  9. The Following 2 Users Say Thank You to gavpike For This Useful Post:
  10. #7
    Apr 2012
    Jhb
    Thanked: 151
    OK thanks. So the starter is 12 V, also according to the circuit diagram from Grips above.
    Just tried to start with one battery but only got a click.
    Maybe a faulty battery.
  11. #8
    Apr 2012
    Jhb
    Thanked: 151
    The previous two batteries of my L Cruiser 200 SW died when I did not use the vehicle for a few months.
    Today I bought two new Raylite batteries (Expensive!) but will still only use the vehicle once every 6 weeks.
    I do not want to lose these batteries again so want to put them on a holding charge while the vehicle stands for 6 weeks.
    From the diagram sent by Grips above the batteries are in parallel.
    To put these two parallel batteries on a charger, where do I connect the charger cables?
    I was told by the battery supplier today that you cannot connect a charger to charge the two batteries simultaneously, you have to charge one at a time and change over say once a week.
    I do not understand why I cannot just connect the charger cables to the positive and negative of a single battery and it will keep both batteries charged as they are in parallel?
    Can anyone please advise.
    I have a 4 A charger I bought at Midas which has a holding charge setting.
    Thanks, Ron
  12. #9
    Feb 2012
    Thanked: 85
    The two batteries are permanently connected in parallel and therefore you only need to connect the charger to one of the two batteries, no need to charge each one on its own.
    I do the same with my LC200 for many years!
    LC200 V8 4.7 P
    LC200 V8 4.5 D
    LC105 4500EFI
    Bush Lapa (B867)
    Jurgens Exclusive
    GS1200R Adv
  13. The Following 3 Users Say Thank You to Hendrik du Toit For This Useful Post:
  14. #10
    Henties
    Thanked: 1573
    Thanks, Ron
    Probably if you would use a smart charger, it wouldn't be able to diagnose the two batteries individually and programs like de-sulfatation wouldn't work.
    But it should charge the batteries fine.
    2012 FJ Cruiser
    1983 FJ60 Landcruiser
  15. The Following User Says Thank You to HugoNotte For This Useful Post:
  16. #11
    Ellisras
    Thanked: 1071
    I was told by the battery supplier today that you cannot connect a charger to charge the two batteries simultaneously......
    That salesman should stick to selling spanners....
    2000 Patrol GU 4.2D(onkey) "old-timer" and wise at 857 000 km
    2014 Patrol GU 3.0CRD "teenager" in puberty at 123 000 km
    2012 NP300 YD2.5 D/C 2x4 High Rider "platkar" at 125 000 km
  17. The Following 3 Users Say Thank You to Dungbeetle For This Useful Post:
  18. #12
    Klerksdorp
    Thanked: 567
    A Smart Charger should only be connected to one battery at a time, in order to work correctly.
    But... having said that, my 1500W Pure Sine Wave Inverter here at home uses two Raylite 105A/Hr batteries in parallel (not the way I would have liked it, but that is all that I could get at the time) and for the first 4 years I used a Benton BX2 (7A) charger connected to them both, they kept the charge. I then replaced the BX2 with a BX-5 (25A) charger to keep them fully charged 4-5 years ago, still using the same batteries and they work for me during the 4-hour load-shedding periods.
    -F_D
    Eric Skeen is the Family Dog
    White Fang:
    1999 2700i DC Raider 4x4
    Pra Dog: 1998 Prado VX 3.4 V6
    Hound Dog: 2000 2700i SC 4x4
  19. The Following 4 Users Say Thank You to Family_Dog For This Useful Post:
  20. #13
    Apr 2012
    Jhb
    Thanked: 151
    Thanks for the replies so far.
    As mentioned I do not have a smart charger but just a normal 4A charger bought from Midas a few years ago. So not a very powerful or sophisticated charger. See pic.
    It has a float (maintenance?) setting which I think is intended to keep a single battery at full charge when not being used.
    What I would like to know is will this float charge keep both batteries (connected in parallel) charged when not being used?
    I am often away for weeks at a time so cannot charge one at a time.
    Advice appreciated.
  21. #14
    Aug 2019
    Thanked: 316
    Advice appreciated.
    Those work fine. Keep it on float charge .
    That's the whole idea behind float charge . Keeps a constant 13.5 V
    That will keep the battery full without boiling out all the electrolyte
  22. The Following 3 Users Say Thank You to Tiaan Pot For This Useful Post:
  23. #15
    Apr 2012
    Jhb
    Thanked: 151
    Thanks Tiaan.
    Will this charger on "Float charge" keep two batteries in parallel at full charge?
    That is what worries me!
  24. #16
    Apr 2012
    Jhb
    Thanked: 151
    I have had no replies to my question above regarding two batteries in parallel so will try it and see.
    Hope I dont destroy them again!
  25. #17
    Aug 2019
    Thanked: 316
    Yes it will keep them fully charged.
    Unless you have a parasitic load that exceeds the current rating of the charger😂
  26. #18
    Thanked: 959
    No problem using it on both.
    I don't know the charger but normally they will work fine.
  27. #19
    Klerksdorp
    Thanked: 567
    While it will keep them charged, it would be prudent to measure the voltage across them when the charger is connected and they are fully charged. Should not be higher than about 13.1V.
    -F_D
    White Fang:
