Results 1 to 5 of 5
    Jan 2010
    Gauteng
    Thanked: 95
    Default Why are my tweeters tweeting in my FL2
    The little speakers, or tweeters located at the top of the door panel are tweeting......it sounds like a "tick tick, tick....." one every second. I only hear it when the radio is on, and only if the volume is very low.
    Anyone evee had this problem before? I presume the little speaker is toast and needs replacement.
    And secondly, how do I remove the cover or pannel to get to it. it seems to be connected to the plastic frame that goes around the window?
    Sep 2018
    Thanked: 38
    Default Re: Why are my tweeters tweeting in my FL2
    This is normally caused by bad wiring, not the tweeters but the radio as a whole.
    https://www.crutchfield.com/S-e9S51w...ion_guide.html
    There are no excuses in life, only yes!
    2002 Land Rover Defender 110 Td5
    2002 Lada Niva 1.7 Carb
    Apr 2018
    JHB
    Thanked: 171
    As above, bad wiring. But it could also be the insulation of the wire was either poorly done or has worn through. This normally manifests itself with a high pitch zing and increases with acceleration. But I have seen it where it caused a similar ticking noise but also high pitch. So may be worth to check out if you are going to look at all the wiring.
    2018 Suzuki Jimny - Expedition vehicle
    2002 Land Rover Defender - Daily Drive
    Jan 2010
    Gauteng
    Thanked: 95
    are u referring to the wiring between the radio and the speaker?
    Sep 2018
    Thanked: 38
    Quote Originally Posted by WayneMan View Post
    Negative, the power to the radio itself.
  6. The Following User Says Thank You to Travisty For This Useful Post:
