Results 1 to 4 of 4
    Feb 2018
    Look behind you...
    Thanked: 247
    Default How long can I leave radiator flush in the system?
    I want to add a bottle of Wynns Radiator Flush to my Jeep's cooling system to help clean it out thoroughly before I replace the viscous fan clutch, water pump and thermostat.
    I was thinking of tackling the above-mentioned over the weekend...
    Would it be safe to pour the radiator flush in now, and leave it in until the weekend, or should I rather put it in Saturday morning, run the car, and then work on it?
    Thanks in advance!
    Jul 2017
    Louis Trichardt
    Thanked: 238
    Default Re: How long can I leave radiator flush in the system?
    Quote Originally Posted by Kalahari Vegmot View Post
    Thanks in advance!
    No don't put in in now. Rather put it in on Saturday. Bottle says something about 20 minutes if I remember correctly? Or was that a 20km drive, it's fun forgetting these things
    My Life Loving It
    Feb 2018
    Look behind you...
    Thanked: 247
    Quote Originally Posted by Chris G View Post
    Yes the bottle says to run at fast idle for at least 10min or up to 20km..
    Thanked: 49
    Be sure to use HOAT antifreeze/coolant additive. Mopar is the best bet (and fairly reasonably priced) but otherwise a decent branded product.
    Andre Louw
    4 XJs, 2 TJs, 2 KJs, 2 WJs, 2 WKs, 1 XK
    2010 JKU Rubicon
  5. The Following User Says Thank You to Changa Bulanga For This Useful Post:
