Results 1 to 8 of 8
    Mar 2014
    Default Hilux 3.0D4D limp mode
    Ek hoop regtig iemand kan help.
    My 2008 Hilux 3.0D4D (handrat, d/cab, 270'000km) gaan in limp mode in sodra ek 142km/h bereik.
    Soms skakel ek my trok net af en aan en dan is hy weer reg.
    Anderkere moet ek die 25A fuse uittrek voordat die enjin liggie afgaan.
    Die fout kode wat wys is P2008 en die vacuum valve is gister vervang maar nog steeds sny my trok uit sodra dit by 142km/h kom.
    My trok is standaard met geen chip en geen enjin aanpassings/veranderinge nie.
    Aug 2019
    Thanked: 261
    Default Re: Hilux 3.0D4D limp mode
    Airflow sensor.
    Swop out with a buddy and test.
  3. The Following User Says Thank You to Tiaan Pot For This Useful Post:
    Elke keer op dieselfde spoed?
    Het jy al jou airflow sensor skoongemaak of vervang? Dit was my D4d se kwaal gewees
  5. The Following User Says Thank You to Kampies For This Useful Post:
    Mar 2014
    Quote Originally Posted by Kampies View Post
    elke keer presies op dieselfde spoed en net in 5de rat.
    ek het hom in 1ste tot 4de so hard as moontlik gery maar niks gebeur nie.
    Mar 2015
    Thanked: 618
    Maklike fix. Laat hom govern op 140 km/h. Sal nooit weer op 142 uitsny nie. Waar kry jy in elk geval so lang afdraande??
    Vat alles hierbo met 'n knippie sout. Kan dit nie 'n diesel toevoer probleem wees nie? Filters of pomp in tenk as hy een het?
    Jun 2013
    Potgietersrus
    Thanked: 342
    Quote Originally Posted by Tom13 View Post
    Diesel toevoer sal probleme gee reg deur die range. Airflow sensor klink vir my na die probleem.
    Jan 2015
    Thanked: 27
    Quote Originally Posted by Eduard Schultz View Post
    Hi Eduard
    Did Toyota read the diagnostic code and do the work to replace a vacuum valve? Also, which valve specifically was replaced?
    There is a proper diagnostic procedure which will identify exactly why you're getting limp mode with a P2008 code - I've attached it in a PDF. I would take the car to Toyota and tell them to give you a report once they've completed the diagnostic BEFORE they quote for replacing any parts.
  10. The Following User Says Thank You to TwoStroke For This Useful Post:
  11. #8
    Mar 2014
    Quote Originally Posted by TwoStroke View Post
    Hi Eduard
    Toyota did the initial diagnostic and 2 other independent mechanics as well...same code.
    My mechanic did the replacement with a genuine Toyota part.
    Not sure as to which valve specifically was replaced as he just told me it's the vacuum valve.
    But I'm definitely giving him the .pdf document.
    Thanks a lot.
